  • July 09, 2025, 05:28:24 AM
Author Topic: Mounting a Norvel 061  (Read 1523 times)
Offline Phillip Kenney
« on: June 21, 2012, 03:08:46 PM »
Finishing up a Dick Sarpolus Mustang and had a question about the mounting of the engine. While the mounting holes will fit a 4-40 screw would a 2-56 be a better choice to go into the 1/4 square motor mount?
Offline kenneth cook
Re: Mounting a Norvel 061
« Reply #1 on: June 21, 2012, 04:54:18 PM »
          Hello Phillip, I use 2-56 for installation myself. The Norvel mount came with screws that were metric and are slightly larger than the 2-56 diameter. The 2-56 screws are completely safe and will suffice. Ken
Offline don Burke
« Reply #2 on: June 21, 2012, 05:00:29 PM »
IMO a 2-56 is perfectly adequate for 1/2A engines.  If the holes in the engine are too large a washer may be needed to keep the screw from pulling through.  I bliessed with a lathe, so in extreme cases I make a stepped washer.  3/16 OD, with 1/32 thick flange, boss diameter to match the hole in the engine with length just less than the mount lug thickness, then a through #44 (.081)  for the mounting screw.
don Burke AMA 843
Menifee, CA
Offline don Burke
« Reply #3 on: June 21, 2012, 05:01:35 PM »
oops the magic fingers messed up I meant. "I'm blessed ...."
don Burke AMA 843
Menifee, CA
Online ray copeland
« Reply #4 on: June 21, 2012, 07:21:37 PM »
Philip, glad your getting along with the Mustang,the metric engine to tank mount screws were very similar to 3-48 in size. I generally use 4-40,  2-56 might be the better choice for the 1/4 inch mounting wood, i have used 2-56 quite often i just like to check the tightness a little more often with that size just for peace of mind! Hope it turns out great for you!
Offline dennis lipsett
« Reply #5 on: June 21, 2012, 07:27:16 PM »
I have to agree with Ray as I usually use 3-48. They are not a difficult size to obtain and you can get them in many sizes also washers,lock washers,nuts and locknuts. I usually go to Micro fasteners but any supply house can fix you up. They are the correct size for a baby bee ,T,D and others I suppose.
Dennis
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #6 on: June 30, 2012, 08:04:23 AM »
I've used both 3-48 and 2-56, prefer the smaller as its blind nuts fit a 1/4" wide mounting beam better. Smaller hole surely makes for a stronger beam too. In my experience 2-56 is plenty beefy enough for 1/2 As.
--Ray
AMA902472
