  • August 03, 2025, 11:39:11 PM
Author Topic: How's my rudder hangin'?  (Read 1167 times)
Offline ray copeland
« on: August 11, 2012, 09:45:41 PM »
Halfway thru figuring out my next 1/2a stunter build and have a question. I am wondering if there are any advantages or disadvantages as far as flying capabilities go to having the rudder stop at the end of the stabilizer so the elevator can just be one piece, or split the elevator so the rudder can continue to the back or beyond the elevator and fasten to the bottom of the fuselage. Really just wondering if the extra work is worth the effort. Hope this question makes sense!
Offline John Cralley
Re: How's my rudder hangin'?
« Reply #1 on: August 11, 2012, 10:19:46 PM »
Take a look at the venerable Ringmaster and you will see an elevator hanging in the breeze!!  y1
Ringmasters have been flying since 1950 and a barn door elevator does not seem to stop them.  LL~
John Cralley
AMA 52183
Central Illinois
Online John Rist
« Reply #2 on: August 12, 2012, 06:17:11 AM »
I am not an aro engineer but I am guessing a big rudder and a split elevator has to do with rudder authority and structural design in a full size airplane.  Control line doesn't need this so a slab rudder may be as good as any.
Offline Larry Renger
« Reply #3 on: August 12, 2012, 01:43:12 PM »
The slab elevator should have less drag for any amount of "drive" compared to a split one.  Think of 4 sets of tip vorticies instead of just 2.
Offline George
  • Love people, Use things.
« Reply #4 on: August 13, 2012, 10:48:47 AM »
Or perhaps a little of both like the notch in the rudder of a Wee Duper Zilch.
George
George Bain
AMA 23454
