  • July 15, 2025, 03:49:43 PM
Author Topic: Something a little different (added: flight report)..  (Read 3166 times)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« on: May 04, 2009, 03:09:43 PM »
Here's what's been occupying my time and keeping me out of trouble lately.  A rather large--but light--stunter using a Norvel .061; call it "3/4A".
The "different" aspect:  Using that Droopy Diamond airfoil I first tried on a couple of combat wings, where it performed spectacularly...I wanted to see how it would do at slower PA speeds.  The principle, remember, is to use diamond-shaped extra-tall ribs widely spaced with no surface spars, and let the covering droop between them, assuming a more typical curved airfoil.  The airfoil varies from about 25% at the ribs to around 14% at lowest point between.  The last picture shows the droop of the covering.
Span = 34", area 250 sq. in., weight RTF a skosh over 10 oz.  Floppy balloon tank inside the cheek.  At least 42' lines to start out, I'll probably end up using longer. Check it out.
« Last Edit: June 01, 2009, 02:01:28 PM by minnesotamodeler »
--Ray
AMA902472
Offline afml
Re: Something a little different...
« Reply #1 on: May 04, 2009, 05:51:51 PM »
WOW! Great job Ray!   #^
Where did the end of the main spar go??   n~
Expect a full flight report.
Great looking plane! Well done!   y1
"Tight lines!"
Wes
Wes Eakin
Offline Robert McHam
« Reply #2 on: May 04, 2009, 06:40:03 PM »
I like it!  :)
I look forward to your maiden report.
Robert
    • Minnesotamodeler
« Reply #3 on: May 04, 2009, 07:58:05 PM »
"Tight lines!"
Wes
HMMMMM, I thought I answered this post...the interior spar ends at the first rib in from the tip, a kind of philosophical wave at weight savings.  All the stress is at the root of the wing, not the tip...no need for reinforcement there.
Fer shur, there will be a full flight report whenever it happens.
--Ray
AMA902472
Offline Larry Renger
« Reply #4 on: May 04, 2009, 10:41:11 PM »
Way cool, MM!  The size is right, the power perfect, I'll bet you end up between 46 and 48 ft lines.  Keep up the good work!
    • Minnesotamodeler
« Reply #5 on: May 05, 2009, 12:56:52 AM »
Thanks Larry, I suspect you're right--I use 48' with my LittleAxe.
--Ray
AMA902472
Offline John Crocker
« Reply #6 on: May 05, 2009, 01:27:25 PM »
I WANT ONE!  That is a cool plane Ray!
    • Minnesotamodeler
« Reply #7 on: May 05, 2009, 03:50:09 PM »
Now don't start hollering "kit it!" until I have at least flown it...
--Ray
AMA902472
« Reply #8 on: May 05, 2009, 04:22:20 PM »
Front view sure looks strange.  The other pictures look great.  Spring time should be in your by the end of the month.  Let us know how it flies.  DOC Holliday
    • Minnesotamodeler
« Reply #9 on: May 05, 2009, 08:46:28 PM »
Front view is a little controversial; something I've wanted to try for awhile, now that I've tried it I'll probably put it to rest. Didn't come out quite as I envisioned it.
"Strange"...I appreciate your tact.
--Ray
AMA902472
« Reply #10 on: May 05, 2009, 10:42:22 PM »
It is a little 'strange' but I have envisioned this more than once just to be different. Don't be surprised if I have some of mine have the same 'low profile' front end.
Robert
    • Minnesotamodeler
« Reply #11 on: May 06, 2009, 09:17:37 AM »
By the way, I neglected to give credit where credit is due...John is the gentleman who first utilized the "droopy diamond" airfoil concept.  Show us your green machine, John.
--Ray
AMA902472
« Reply #12 on: May 06, 2009, 05:54:11 PM »
Hey Ray,
Thanks for the props, but I must say your lines are a lot cleaner than mine.  Here's the "Green Giant".  Was one of the better planes I ever flew.
And my favorite plane ever with diamond wings, "The Confederate".  Both of these planes were stolen and recovered in pieces.  The confederate was powered by 2 .061 AP Wasps and was a joy to fly.
    • Minnesotamodeler
« Reply #13 on: May 06, 2009, 08:17:45 PM »
You gotta build another Confederate, that's a cool plane.
--Ray
AMA902472
« Reply #14 on: May 07, 2009, 04:43:56 AM »
I've thought about it, but I'm down to only one engine and money's tight right now.  It was a fun plane to fly, it had the prettiest takeoffs and landings of any plane I ever built, guess I got the ballance just right on the trike gear.  I think it had a 42" span and weighed in aaround 17 oz.
« Reply #15 on: May 22, 2009, 11:22:33 AM »
Flight report?
    • Minnesotamodeler
« Reply #16 on: May 22, 2009, 02:56:52 PM »
Not yet, been too windy here, now that it's finally settling down I have honeydo's to do...
--Ray
AMA902472
« Reply #17 on: May 27, 2009, 05:07:14 PM »
you are supposed to do the honey do's when you can't fly.  DOC Holliday LL~ LL~ LL~
    • Minnesotamodeler
« Reply #18 on: May 28, 2009, 05:52:57 AM »
Tell my wife, John...on second thought, let's not rock the boat.
Still haven't got out.  Thought I would yesterday but the weather didn't cooperate, windy and cold and damp.  High was 53 I think.  And here it is nearly June!  Maybe Saturday if it warms up and stays calm.
--Ray
AMA902472
    • Minnesotamodeler
« Reply #19 on: June 01, 2009, 02:00:55 PM »
FINALLY--FLIGHT REPORT!!!
Got the Droopy Diamond out today...must say, it exceeded my expectations.  VERY stable, to the point I was concerned at takeoff, when it settled into a very deep groove, it must be noseheavy and unmaneuverable--but not so,  turns extremely well and tight.  That extreme stability enables really nice square corners, no overshooting, coming out of a wingover just square and back into that deep level groove. Makes even MY corners look good.
I used 48' lines, and will try 52' next time as it is too fast--under 3.5-sec. laps, on 48' lines that's over 60 mph.  This is a big plane I thought, 34" span, 240 sq. in. wing, but I guess that droopy airfoil lends itself to lotsa speed.  It's probably 10 mph faster than my LittleAxe--I flew them back-to-back for comparison. The LA still flies very well but I think I'm gonna prefer the Droopy Diamond stunter once I get the speed under control.  (I'm using a 6x2 prop now, can't get lower pitch than that!) I may switch out the .061 for an .049 just to see how it works with the smaller engine.
All in all, I count it a huge success. couldn't be more pleased with it.  Thanks for the innovative airfoil  Mr. Crocker!
--Ray
AMA902472
Re: Something a little different (added: flight report)..
« Reply #20 on: June 04, 2009, 10:17:01 AM »
Sounds great.  DOC Holliday
