Building Tips and technical articles. => 1/2 A building. => Topic started by: Dane Martin on July 07, 2020, 05:41:43 PM
I'm not 100 percent certain on the displacement. I've seen a few on Ebay, so I know they're not super rare. But, what's the history? Did they come on some of the ready to fly planes? Is there a way to date this engine?
I got a sweet deal on a small 1/2a lot. I got a couple royal spitfires, this Jim Walker engine and some others.
The royal spitfires
My memory is a little short but I believe that it was made by Mel Anderson and It was the largest of the small compact engines of the day that he made. He also made a special version for Jim Walker, it had a bulb controller that when you squeezed it it closed a clapper on the venturi and gave you a crude form of throttle control. We had fun doing touch and goes with one of them. It might have been 1955 or there about. As I said my memory is getting shaky.
Yea I know the deal you got
great score!
Sent from my SM-G965U using Tapatalk
Notice the resemblance of the Walker engine to the Royal Spitfire! I think I have at least one of these myself.
Type at you later.
Very cool Dennis. I think you're at least close, if not on the money.
So, probably more work than it's worth.... but this one has a broken lug, and missing backplate. What I've done in the past, was to TIG weld it back up and mill it out.
It's a threaded back plate. I can cut as fine as 120tpi. So that should be an "easy" task.
Dane,
Hope that your restoration goes well. But remember that when you run it don't be surprised when it is only about average power. He was making engines to appeal to a specific group, mainly energetic young people who wanted a fun model to fly. It really was a different generation.
Dennis
Dane,
Dennis
Thank you Dennis. With that, it'll probably just end up on a light free flight sport model. Really more of something to be able to hear it run. Sit back and admire it. They don't seem rare, so I could probably just Ebay one. But I think I like making parts and running these things more than anything right now
Check the piston-conrod ball joint play before you run it. I have one that is pretty sloppy. Does not look like it can be reset easily like a Cox piston ball joint.
-Chris
.065. the piston is three piece piston snap ring and ball cup (socket)
Would this have been used on one of these?
https://www.rcgroups.com/forums/showthread.php?4027561-Jim-walker-firebaby-arf
currently for sale.....not mine
