Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 20, 2025, 05:28:07 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
JB Weld
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: JB Weld (Read 1550 times)
david beazley
2017
Trade Count:
0
Captain
JB Weld
on:
November 20, 2009, 02:14:13 PM »
I have a Norvel .061 with the 2 front mounting lug holes busted out after a nose in. I am contemplating using JB Weld on them. Has anyone had any experience or luck repairing mounting lugs with JB-Weld?
Logged
AMA # 2817
Alan Hahn
Guest
Trade Count:
0
Re: JB Weld
Reply #1 on:
November 20, 2009, 04:02:26 PM »
If I am imagining this correctly, I don't think it will work. JB Weld just isn't strong enough to provide a mounting structure. It will probably just crack off where it connects to the remaining part of the lug.
What might work---and I am really unsure of this-- is to use some of that aluminum welding rod (or whatever it is!) and braze on an extension that you can then shape with a file and redrill the mounting holes. I have seen commercials which show them doing what you are describing--but on a larger piece. But like I said, in a commercial/infomercial, everything looks easy and works great!
Logged
George
Trade Count:
0
Admiral
Love people, Use things.
Re: JB Weld
Reply #2 on:
November 20, 2009, 08:59:03 PM »
Three brands I have heard of is alumaweld, alumalloy, and HTS-2000. Of these, I have used alumaweld purchased from Eastwood.
If you go this route, make sure you practice on something else before repairing the engine.
George
Logged
George Bain
AMA 23454
goozgog
Trade Count:
0
Captain
Re: JB Weld
Reply #3 on:
November 21, 2009, 04:56:30 AM »
I have tried this on the mounting
lugs of a L.A. .25.
I left the break rough and cleaned
it well beforehand. The J.B. weld
sanded down smoothly and looked great,
but it only lasted a few flights.
FWIW - Morgan
Logged
Keith Morgan
dssit
Trade Count:
0
Ensign
Re: JB Weld
Reply #4 on:
November 21, 2009, 06:51:17 AM »
I made two sub mounts of 047 steel drilled to match originale holes. filled the voids with jb weld. I forgot the steel goes on top.
Logged
dssit
Trade Count:
0
Ensign
Re: JB Weld
Reply #5 on:
November 21, 2009, 06:55:43 AM »
I spelled original wrong and forgot to tell you the steel goes on top of both holes front and gack.
Logged
dssit
Trade Count:
0
Ensign
Re: JB Weld
Reply #6 on:
November 23, 2009, 09:55:02 AM »
david. did any of the ideas help or were you to busy to read them.
Logged
david beazley
2017
Trade Count:
0
Captain
Re: JB Weld
Reply #7 on:
November 25, 2009, 06:18:20 AM »
Thanks for the replies.
Work has kept me too busy for modeling lately, but I have figured out that in today's world
A
job is better than
NO
job so I am intending to hang on to mine as long as possible.
I am going to try your suggestion of bucking up the lugs with another piece of metal and then trying to JB Weld it, I will post results when I do it.
Logged
AMA # 2817
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
JB Weld
