  • July 31, 2025, 07:56:47 AM
Author Topic: IBTW Barnstormer  (Read 26050 times)
Offline frank carlisle
Re: IBTW Barnstormer
« Reply #50 on: January 24, 2007, 07:20:32 PM »
How about posting them pictures Clancy? y1
Frank Carlisle
Barnstormer names.....
« Reply #51 on: January 27, 2007, 07:11:51 AM »
Full size:  Barnstormer
FAI:  Tool shed.
1/2 A: Chicken coop.
.020:  Bird house.
Offline Clancy Arnold
« Reply #52 on: January 27, 2007, 08:19:00 AM »
OK so far but what about the 010 size?
Clancy
Clancy Arnold
U/Tronics Control
Offline George
  • Love people, Use things.
« Reply #53 on: January 27, 2007, 11:44:28 AM »
Clancy
Fly Trap?
George
George Bain
AMA 23454
« Reply #54 on: March 19, 2007, 04:03:38 PM »
Modified the IBTW Barnstormer today.
Removed the Cox Pee We e 020 with tank and built a stunt tank to go inside the IBTW.  Modified the radial mount for the second Pee Wee 020 to mount in the space of the metal tank / mount.  The new tank is 1 x 1 x 1/2 inch.  Should give me about 5 minutes flight time.  Much better than 1 1/2 minutes.
Clancy
Clancy Arnold
U/Tronics Control
Online Larry Renger
« Reply #55 on: March 21, 2007, 10:10:24 AM »
For economy reasons, due to the relatively low volume of sales, the Tee Dee .020 and Pee Wee .020 used identical pistons and cylinders.  Tapered honing and all, I was told.  You would have to "mike" a Pee Wee Piston to verify this.
There may have been a .010 reed valve engine prototype, but the production .010 was only Tee Dee front rotary.
Early examples could turn that small prop just at 30K on 30% Nitro.  The current ones are OK, but not in that class, probably pushing hard to reach 25K.
Good show on the Barnstormer family, I want to build one eventually too!  I would be more likely to scale the big Barnstormer down to about 250 sq.in. for an APC .061 and Leprechaun competition.
 y1
