  • June 15, 2025, 10:30:33 AM
Author Topic: FIRST REPORT ON NEW OK ENGINES  (Read 1739 times)
Offline LARRY RICE
« on: June 08, 2007, 01:22:16 PM »
I just received the first report back from a modeler in Virginia on the new OK .049R (reed valve) engine. He said that after a short break-in run the engine was in the same power range as the Black Widow engines. Recommends the engine as a good replacement for the Cox engines.
That is all I know!
Larry
