  • June 16, 2025, 07:14:24 PM
Author Topic: Heli fuel for 1/2A?  (Read 3932 times)
Offline John Castle
  • The Bent Pin
Heli fuel for 1/2A?
« on: May 11, 2009, 07:37:08 PM »
I just inherited a gallon of Tower Power 35% nitro heli fuel. I'm thinking that it should be good for my Cox and Norvel engines. Tower keeps it a mystery as to the castor content but by all indications it is 18% oil split between castor and synthetic. What do you think?
John Castle
McMinnville, Oregon
AMA# 589650
Online kenneth cook
Re: Heli fuel for 1/2A?
« Reply #1 on: May 11, 2009, 08:04:08 PM »
         John, I don't think that is enough lube. You might want to stay with at least 20%. You could always add some more to bring it up to par. I never saved it but there was a fuel calculator floating around the forum. It gives you exact amounts to get the desired content. You just plug in the desired numbers and your set. I personally had great results with Sig fuels and Tower Hobbies still carries it as well in quarts. I had my eye on the heli fuels as well when my local hobby shop decided not to purchase anymore Sig fuels. It was real convenient to buy it by the gallon. You didn't mention which engines your running as well. It may work for some but some of the older stuff may need a bit more lube. Ken
Offline Robert McHam
« Reply #2 on: May 11, 2009, 08:43:07 PM »
I think you can use this with no worries so long as you add only castor to up the lube. Cox engines love castor! As for the Norvel, the extra castor can do no harm either.
Robert
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: May 12, 2009, 06:09:38 AM »
ince there are 128 oz. in a gallon, to increase any portion of it (castor, nitro, etc.) by one percent you must add 1.28 oz. of whatever.  Pour off about 4-5 oz. of the fuel and replace it with castor and you've gone from 18% to about 22% lube. Really pretty simple.
I once bought a gallon of RC car fuel because it was the only thing available.  It was really dry, I don't know how they keep those car engines together, had to add about 12 oz. of castor if memory serves to get it "wet" enough to run my old Fox on.  But that was OK since it started out at about 40% nitro, it could stand a little dilution!  (The Fox sounded really good on it, kinda like on steroids.)
As far as the Norvels go, they will run a little sloppy but fine performance-wise on heavy castor.  Might even extend their life.
--Ray
AMA902472
Offline Russ Danneman
« Reply #4 on: May 15, 2009, 07:43:43 AM »
i have run it before. just added castor. ran great . no problems.
FLY LOW FLY FAST  RISKY BUSINESS
Offline Pinecone
« Reply #5 on: May 15, 2009, 09:17:21 AM »
The car guys seem to think that a few gallons is the max life an engine. Wonder why? :)
Terry Carraway
AMA 47402
Offline nobler
« Reply #6 on: May 15, 2009, 08:05:25 PM »
Minnesotamodeler is pretty close. If starting with 18% oil and you want 22% oil by pouring out some fuel and adding castor, you need to add 6.24 oz. Call it 6 1/4 oz.
You start with a known amt of oil in your gallon of fuel.
You pour out an unknown amt.  (X).
You pour in this same amt (volume) of pure castor, to get to 22%.
So:  .18(128) -.18X + X = .22(128).
X solves as 6.24 oz.
Currell
« Reply #7 on: May 15, 2009, 08:20:32 PM »
It is also important to understand that when adding oil, the other important ratio, which is the nitro/ methanol blend will not change.
this of course is what gives the energy. The oil should not burn and so you do not "weaken" the overall potency of the mix! Cool, isin't it?
Robert
    • Minnesotamodeler
« Reply #8 on: May 16, 2009, 05:27:17 AM »
Well, the oil doesn't burn (mostly anyhow) but it does dilute the mixture, so overall percentages of nitro and methane both drop a little, but yes, the ratio between the two remains unchanged.  I think.  Makes my head hurt.
If it runs OK and doesn't harm the engine I'm happy.
--Ray
AMA902472
Offline George
  • Love people, Use things.
« Reply #9 on: May 16, 2009, 10:06:14 AM »
Hmmm. If I remember correctly, both Cox and NORVEL 1/2A fuels used 18% lube, so the heli fuel should not hurt those engines as-is. It is also assumed by most of us that 20%-22% lube is better, and that it should be half or more castor oil.
With those assumptions, adding more castor should be good but not absolutely necessary.
I understand that some car fuel runs as little as 9% lube...which is another story.
George
George Bain
AMA 23454
Offline Bill Heher
  • Fix-it
« Reply #10 on: May 16, 2009, 12:44:05 PM »
A lot of the car guys ( especially novice) run high nitro / low oil and lean the needle to a screaming/ rod breaking/ piston burning/ bearing killing /maximum RPM.
This delights the high volume / flashy ad type dealer who earn very little actual profit on the initial package deal of car / engine / radio, but make up for it in spare parts, engines, upgrades, high nitro fuel in quarts, etc.
Bill Heher
If it's broke Fix-it
Offline John Rist
« Reply #11 on: May 16, 2009, 03:33:14 PM »
Are you trying to tell me U-control speed guys don't push the limit on nitro and oil?  1/2 A in excess of 100 mph.  How many runs do they get per pistion/cylinder?    LL~  LL~  LL~
« Reply #12 on: May 17, 2009, 08:06:37 AM »
Watched the record holer at one at the NATS.  He would assemble an engine an run.  It sounded like a high speed Dremel.  Tear it down and do something to it.  Reassemble it and run it again.  He put it in the plane and made one flight.  Tore the engine down again to start doing thing to it again.  I think he rebuilt the engine a dozen times to get maybe three flights.  DOC Holliday
Offline George
« Reply #13 on: May 17, 2009, 08:49:19 AM »
Then again, those events are mostly frequented by guys who understand the risks and consequences. The problem is when the average "Joe Bellcrank" runs his engine flat out and expects it to run season after season. If you "Trick out" a Sure Start, run it on a toothpick with high nitro, it ain't gonna last.
I remember the instructions for NORVEL engines expecting the engines to last for four or five running hours.
Getting maximum performance is important for competitive "class" events. For sport flying, if you need more power, use a bigger engine.
I don't mean to step on anyone's toes, just bear in mind higher performance usually means shorter life.
And of course, this is just one opinion.
George
George Bain
AMA 23454
Offline Larry Renger
« Reply #14 on: May 18, 2009, 10:32:04 PM »
With adequate oil, the limit on engine life is usually dirt.  Cox, of course ran all castor during the "good" times.  They ran a test on a Tee Dee .049 to evaluate life.  In a clean environment, the engine ran 400 hours (not 4, not 40, 400!).  At that point, it needed an electric starter to get going, but would still run!  Duke Fox ran a similar test on a stunt 35 and gave up after using up a 55 gallon barrel of fuel.
Nitro/methanol determines the run and power, oil then only affects the fuel consumption and needle setting (both of which CAN be important).  More oil means more open needle and less fuel draw, plus more fuel consumption as the oil does not contribute to the power.  However, the cooling and life improvements balance out somewhere.  As usual, you have to hit your own best result.
After (finally) reading the break in instructions for the AP Wasp, I broke it in on 28% oil fuel, and am currently running 24%.  The one with the Tee Dee .049 venturi turns 23,500 on an APC 6x2 prop, and flies 3.6 second laps on 45' eyelet to eyelet lines.  I don't, however, have enough fuel capacity in that plane to finish the pattern.  Trade-offs, trade-offs!  I will switch that engine to the more recent Sky Sport (3/4" longer tank compartment) and cut the oil down to my more usual 22%.
I will soon get back to baggie tank development, I have been trying to assure that I have at least one totally competitive plane for the next meet.  Antone Kephart won 1cc and took home the "Leprechaun Pot o' Gold" trophy at the Palmer Memorial Meet with about 460 points with a 1/2A Magician from Flying Models plans.  Antone let me fly the plane this weekend, and it is as good as I remember the original.  Smooth, crisp turns with minimum overshoot (he is still tuning it in) and rock solid line tension.  Plenty of maneuvering room to allow true vertical eights (the toughest test, in my book, you can cheat everything else).
Supposedly, Brodak is going to produce a Baby Magician.  I have no idea how good it will turn out to be.  Until then, get the plans from FM and call Eric Rule for a set of laser cut ribs.  My version is an accurate reproduction at just the right size for competition .
Offline George
« Reply #15 on: May 19, 2009, 12:27:02 PM »
Larry, do you remember what percentage they were running back then? Someone said they were running 18% more recently but they (and I) could be confusing that with NORVEL's 18% fuel.
Not to hijack this thread, but how did you make out with that Bambi .009 diesel you were restoring? I just read an .010 thread recently and thought of it.
George
George Bain
AMA 23454
« Reply #16 on: May 20, 2009, 12:51:35 AM »
I did get the Bambi running.  The crankcase/crankshaft lengths were mismatched and it was binding.  Lathes are a wonderful thing, so I was able to make a correction.  It actuall produces a breeze on a Cox 4.5x2 prop!  I had heard rumors that it just produced enough wind to keep from overheating, with nothing left over for flight.  I think I may put it in a Speedy-Built replica model for flying on .006 lines.  With modern RC equipment, it could easily fly a plane, but outdoors, it would probably blow away downwind, and I don't think the indoor RC site I frequent would appreciate the drips and smell!
