  • August 01, 2025, 08:10:19 PM
Author Topic: Hardware for beam mounted 1cc models?  (Read 3394 times)
Offline Target
  • C/L Addict
« on: February 17, 2019, 04:49:15 PM »
Gents-
What is everyone using to mount their little I/C demons to their planes?
I measured up the lug holes of a Cox Medallion .049 and the Norvel .061 (much larger).
It seems that at least in the Norvel, a 2-56 machine screw gets lost in the hole (like what I told my ex wife, "It's like throwing a hot dog down a hallway!"), and yet a 3mm or 4-40 is too big for the Norvels.
Looks like a 3-48 would be perfect for either though, but....
Another pretty substantial issue is that blind nuts seem lightly available for 2-56, and completely non-existent for 3-48 or 2.5mm. Blind nut aren't easily available until 4-40 or 3mm. I DID find some blind nuts in MPJet's catalog for 2.5mm, that might be an option....
What are folks using? Anyone have a source for the 3-48 blind nuts??
Thanks in advance!!
R,
Target
« Last Edit: February 17, 2019, 05:09:07 PM by Target »
Chris
AMA 5956
Offline Chancey Chorney
Re: Hardware for beam mounted 1cc models?
« Reply #1 on: February 17, 2019, 04:56:08 PM »
Funny you ask that. While a bit different, I am not having any luck finding six(6) 3-48 cap screws to use in rebuilding an engine. However, I did find 3-48 blind nuts. Du-Bro makes them. One of my LHS has them. But there is no 3-48 machine screws.....
https://webstore.eliminator-rc.com/du-bro-3-48-blind-nuts
Offline bob whitney
« Reply #2 on: February 17, 2019, 05:21:24 PM »
what length 3/48 allens do u need   for what engine
rad racer
Offline Target
  • C/L Addict
« Reply #3 on: February 17, 2019, 05:29:05 PM »
Chancey- AWESOME!!
Wish they were in bulk, but what the heck at least available!!
I have always had the best luck on fasteners (in general) with McMaster Carr….
Have you looked there?
91251A096 is the part number for 1/2" long, they have every length from 1/8" to 1".....
R,
Target
Chris
AMA 5956
« Reply #4 on: February 17, 2019, 05:35:28 PM »
RTL and Micro both have 2-56 T-nuts.  I'm not sure which of the two I bought mine from, but I'd trust either of them.  I think 2-56 would be plenty strong.
I tried, and a 4-40 would fit through the holes of a Norvel Big Mig 049.  It was snug, though -- there'd be no room for messing up the holes in the crutch, and I really don't like the idea of chewing that much wood out of a 1/4" square bearer.  I suspect they're designed for 2.5mm -- for which I can't find T-nuts.
I think I'd use 2-56 nuts, and figure out a way of positioning the engine that didn't depend on the screws.  Or I'd order up some M2.5 hardware, and just use regular nuts on the back side.
Offline Target
  • C/L Addict
« Reply #5 on: February 17, 2019, 06:05:08 PM »
MPJet has the 2.5mm insert nuts, Tim....
Chris
AMA 5956
« Reply #6 on: February 17, 2019, 06:30:32 PM »
Hmm.  Thanks.
Offline dennis lipsett
« Reply #7 on: February 17, 2019, 07:42:54 PM »
Micro fasteners and RTL both sell 3-48 socket screws in a bunch of lengths. Washers, t nuts and  regular and safety nuts the smaller packages are quantities of 50 and they are reasonably priced
Micro fasteners list  3/16, 1/4 3/8 1/2 and 3/4
Go on line and type in the  supplier closest to you and you will be able to get almost any size  bolt,nut or washer t-nut up to 1/4 and 6mm
additionally they sell 5-40 screws for the Cox engines and 3 mm for the Norvels prop nuts
Offline Target
  • C/L Addict
« Reply #8 on: February 17, 2019, 11:07:19 PM »
Micro fasteners and RTL dont have 3-48 t nuts. If either of them does, PLEASE post the part number, i really want to buy some!
In fact, no place has them that i can find.
The Dubro #134 item mentioned is no longer listed in their catalog, and it appears they assigned that number to a red spinner, lol.
Thats not a good sign, but i did send them an email incase they have some hidden somewhere.
« Last Edit: February 18, 2019, 12:34:21 AM by Target »
Chris
AMA 5956
Offline 944_Jim
« Reply #9 on: February 18, 2019, 07:12:43 AM »
I hate to say it, but 3-48 T-nuts appear on the 'Bay from time to time. I bought a few bags from a vendor when had several. They will be recycled when the model no longer flies.
Since that is an orphaned size, I find myself using 2-56 in their place during construction. My Mosquito with twin Big Mig .074s uses 2-56 all over...engines, tanks, landing gear straps. I do use a thread locker (blue) on engine hardware and landing gear.
I wish I could buy a bag of 100 3-48!
« Reply #10 on: February 18, 2019, 10:25:14 AM »
I am wondering if by any chance that the SKU number listed is that of their own, and not a Dubro part number? Just a thought. However, I will not be going there anytime soon that I see, but if I will be in the area, I can check it out and pick some up if interested. I would know a day or two in advance so I could give you a heads up.
Online Trostle
« Reply #11 on: February 18, 2019, 11:38:13 AM »
If you actually find a source for 3-48 blind nuts, please let me know.
Offline Target
  • C/L Addict
« Reply #12 on: February 18, 2019, 12:05:37 PM »
No, I contacted Dubro, and that IS the correct Dubro part number. But they said that they no longer "make" the 3-48 hardware and have none in stock any longer. That's a dead end.
I did by a couple cards of the Dubro #134 off Ebay in a lot, as Jim mentioned. And your source has (2) cards of the t nuts, but the shipping turned me off from buying them there. You should buy the two they have left if the shipping is reasonable....
R,
Target
Chris
AMA 5956
Offline Target
  • C/L Addict
« Reply #13 on: February 18, 2019, 12:05:59 PM »
Will do.
Vr,
Target
Chris
AMA 5956
