  • July 18, 2025, 12:24:32 AM
Author Topic: Handles  (Read 1355 times)
Offline John KruziK
Handles
« on: October 18, 2009, 10:58:46 AM »
What type of handles are you guys using for 1/2a's    Thanks John
AMA 874027
Re: Handles
« Reply #1 on: October 18, 2009, 11:58:54 AM »
I use the same one I fly stunt with.  Have fun,  DOC Holliday
Offline Roger Vizioli
  • CLiner
Re: Handles
« Reply #2 on: October 18, 2009, 12:31:59 PM »
No offense to "Doc".
I have also used full size stunt handles and various plastic handles (old and new designs) and have decided the best one is the offering by RSM, as follows:
Renger 1/2 A Handle from RSM, designated  R-12A     y1
Very light, exponential control rate and inexpensive @ $5.95.
Used for over three hundred flights and cant find fault with it!
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Larry Renger
Re: Handles
« Reply #3 on: October 18, 2009, 10:15:41 PM »
Aw shucks, it 'twarn't nuttin.  I needed the handle for my own models, and Eric up and kitted it!
Anyway, the handle is currently availible in 3 sizes, original, +10 and +25.  My current preference for 1/2A is the +10 as it allows a better grip.  I really did cut the original a bit too close, even for my small hands.  Anyway, the +25 is great for up to .35 models, and if you reinforced the main panels with fiberglass, you could fly anything.
The expo function was intended to tame un-flapped models, and I have found that with flaps, you need to reshape the inserts to reduce the expo.  A full radius is the first step, then you can go all the way down to a point to make the handle completely conventional.  Since the inserts are pretty simple 1/8" ply, it is easy to make a vareity of shapes and widths to perfectly tune in your model.
  • CLiner
Re: Handles
« Reply #4 on: October 19, 2009, 07:03:34 AM »
Larry,
When you say +10 and +25, may I assume you mean % of original size?
And, does RSM offer them? If so, what are the Part Numbers?
I only see one other handle listed, R15A, not sure which this is.
Thanks, H^^
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Re: Handles
« Reply #5 on: October 21, 2009, 06:14:31 PM »
I don't keep up with Eric's catalog, I am sure he will answer your questions with an e-mail to Eric1@rsmdistribution.com  .  I expect the .15 size is the +25.  He may have made the +10 standard by now.  I will have to ask him what is the status so I know.
