  • June 17, 2025, 10:04:31 AM
Author Topic: Hoping some kids show up for fly-a-thon  (Read 6173 times)
Offline Bill Smith
« on: September 25, 2014, 09:25:56 PM »
Built one for the kids to fly.
Re: Hoping some kids show up for fly-a-thon
« Reply #1 on: September 27, 2014, 02:51:45 AM »
Looks cool!  How much does it weigh?  And how does it fly compared to a balsa Beginner's Ringmaster?  Your hinge system is AWESOME!  Why didn't I think of that?  Its gotta move much more freely than just cutting away one half of the flute surface.
Mark
Offline Bill Smith
« Reply #2 on: September 27, 2014, 08:41:52 PM »
It weighs in at 6 ounces, which is a little heavier than it's balsa counterpart. if you look closely you can see I reinforced it by pushing bamboo skewers through the holes in the Coroplast and that is what I used for the hing pin.
I put the skewer in the stabilizer first and push the corners of the plastic against a counter to make the holes round so the skewer turns freely.
this is a test of glue for the most part. I am trying Shoe Goo adhesive, it's made to stick sneakers back together and I have used it to make my own sanding belts.
you can see the 1/2" basswood that is glued to the fuse and stabilizer if the does not hold I can put screws thought the Coroplast into the basswood.
Haven't flown it yet but it should loop and take a hit.
I have built other Coroplast planes but they were heavy and meant just as trainers and though very stable would not do anything more than a big wing-over.
Just a note I do not think the paint will survive more than a day.
« Last Edit: September 27, 2014, 08:59:47 PM by Bill Smith »
Online Larry Renger
« Reply #3 on: September 28, 2014, 06:55:11 AM »
Do a search on the ET-1, as it is a Coroplast trainer. We built 4 of them about 3 years ago, and the paint is still just fine. They were painted with Painters' Touch enamel. Yesterday we trained 46 kids at the EAA Fly-in at the Compton airport. We only had to use one model for the whole day. Lost one prop, otherwise no damage.
However, I feel like I have been beaten with a stick!
Offline Bill Smith
« Reply #4 on: September 28, 2014, 08:54:28 AM »
this is painter touch. but testing with raw 25% after four days drying it came off.
not fast but it did come off.
« Reply #5 on: September 28, 2014, 01:45:06 PM »
Bill, what did you do to reinforce the bolt holes for the engine mount in the coroplast?
Mark
Offline Bill Smith
« Reply #6 on: September 28, 2014, 01:51:34 PM »
the nose is filled with short pieces of skewer. The screws go between them. the filler pieces are of varying lengths going back over the wing.
one long one goes to the tail. there is a small piece of ply to bring in to 1/4inch.
« Reply #7 on: September 28, 2014, 06:06:58 PM »
Two last questions:
1)  Are the dimensions the same as the standard balsa Beginner's Ringmaster?
2) Do you mind if I steal replicate your design principle?
Mark
Offline Bill Smith
« Reply #8 on: September 28, 2014, 06:19:01 PM »
steel away it not my design and I don't think the people at sterling care anymore.
the more people flying them the better.
the fuselage and tail feathers are correct to the baby the wing is an inch smaller due to the size of coroplast I could find.
the CG ended up right on the bell crank center which maybe a little too far back, but plumbers solder works great in coroplast for balancing.
« Reply #9 on: September 29, 2014, 10:07:11 AM »
I have discovered by experience that 3 or 4 days is not enough time for the spray can paints to cure.   I usually wait two weeks or more before I ever think of fueling up a plane sprayed with Rustoleum Gloss paints.   So far no problems.  Forgot the Gotcha Streak Stunt is sprayed with plain Rustoleum Grey as I wanted a matte finish.  So far paint is holding up well, even where raw fuel has gotten on the surface.
Offline Duke.Johnson
« Reply #10 on: September 29, 2014, 12:57:56 PM »
I build this one for last years RM flyathon. I didn't get as fancy, but I did make it electric.  Flew great level laps, you could put a new guy/kid on the handle and if they kept their handle neutral, it would take off, fly level laps, then land it's self.
Offline john vlna
« Reply #11 on: September 29, 2014, 01:12:45 PM »
Very nice. Should be about indestructible.
Offline Bill Smith
« Reply #12 on: September 29, 2014, 02:41:38 PM »
I like it Duke
But I need to compare notes.
How did you bond the fuse to the wing?
Before I have incorporated ply and screws but this time I am just using glue .
Offline Bill Smith
« Reply #13 on: October 04, 2014, 08:26:01 AM »
today 10/4/2014
 its raining and 37 degrees and blowing a bit hopefully tomorrow is better.
I will be out flying tomorrow regardless of the weather
Offline Phil Krankowski
« Reply #14 on: October 04, 2014, 09:47:58 AM »
That hinge is awesome!  I will be using that idea.
I have had really good luck with painter's touch, but 14 day minimum cure time is required (OK, I never tried on plastic, but it is meant for plastic too).  It will discolor and rub off with fuel exposure, but the color will go back after a few hours, and if you blot it instead of rubbing it the color won't come off. (Use windex if it gets too oily, but wait till the next day, then it should take light rubbing again.)
Phil
Offline Bill Smith
« Reply #15 on: October 04, 2014, 06:27:13 PM »
cool I'll try that
thank you
Offline Bill Smith
« Reply #16 on: October 05, 2014, 03:42:03 PM »
Got well over 30 flights on the 1/2a today with winds gusting up to 23 mph.
It loops great, very maneuverable.
CG could move forward about a 1/4 inch, the takeoffs were a little touchy.
Only one kid showed up.
but most of the 52 (30+) flights put in before I had to leave were done with the coroplast plane.
It bounce numerous times and NO damage except for 2 props.
the old guys had fun with it.
5 planes not pictured.
« Last Edit: October 05, 2014, 07:08:21 PM by Bill Smith »
Offline fred krueger
« Reply #17 on: October 05, 2014, 11:01:43 PM »
Chris Rudd, Steve Riebe and Mike Riebe added 11 more flights later in the day.
Our Tree Town group and friends got a total of 63 flights in rather bad conditions.
 :D
Fred
Offline Bill Smith
« Reply #18 on: October 06, 2014, 07:14:49 PM »
cleaned it up today and only a small amount of paint came off. Not bad.
just a little yellow on the rag.
So painters touch Rustolium given 2 weeks to dry will stick to Coroplast and is fairly fuel resistant.
Shoe Goo glue works (given enough surface contact) on Coroplast.
Bamboo skewers make good stiffeners.
« Reply #19 on: October 07, 2014, 09:53:19 PM »
I like it Duke
I believe I just used CA, others say hot glue works the best.  I cut a slot for the wing like a normal slab wing and glued it.  I also cut the rudder and fuse as one piece.  I usually use a wood dowel to stiffen the wing in the leading edge and one in the flute under the bellcrank.
Offline HugoW
« Reply #20 on: December 08, 2014, 05:16:35 AM »
Hi guys,
I'm considering the Coroplast build, as it is more me-proof than the balsa. What thickness Coroplast do you use? I have some 2mm = 5/64" thick, but it seems too flimsy even for such a small plane.
Cheers,
Hugo
Offline Bill Smith
« Reply #21 on: December 08, 2014, 08:06:58 PM »
 don't have a piece in the house to measure right now but I believe it is 4mm that I used.
It was a blank sign from menards.
