  • June 16, 2025, 05:29:30 AM
Author Topic: Half A Pathfinder  (Read 3527 times)
Offline Casey
Half A Pathfinder
« on: June 10, 2016, 05:32:38 AM »
I plan to recess a 2 oz circular fuel tank with external diameter of 1-3/8" into my profile Half A Pathfinder fuselage. Will the fuselage be too weak to accept a recessed circular grove that is 2- 3/4" long
or would a 1 oz circular fuel tank with external diameter of 1-1/4" external diameter and 2-1/8" length be better
Offline Roger Vizioli
  • CLiner
Re: Half A Pathfinder
« Reply #1 on: June 10, 2016, 09:29:50 AM »
Please post your contact info. for a related reply and picture.
roger v.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #2 on: June 10, 2016, 09:53:03 AM »
I have used recessed fuel tanks for years.   Just be sure to re-engineer the front end with enough hardwood & plywood to do the job.  I would have hardwood/plywood going back past the high point of the wing.
Offline Casey
« Reply #3 on: June 13, 2016, 07:16:34 AM »
Thanks Paul, for your reply
  • CLiner
« Reply #4 on: June 13, 2016, 01:49:29 PM »
Hmm, no contact info posted for Casey.
Wont challenge Paul's input, wood removal and replacement for strength "might" result in a heavier plane. I've seen Paul's Baby Clowns fly and they are super.
Adding weight to a 1/2 A P'finder is not recommended.
Mine have weighed ~11 oz. each. Hundreds of flights on 48' lines. Have some ideas, next one will be lighter.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Target
  • C/L Addict
« Reply #5 on: November 24, 2017, 09:20:21 PM »
I'm interested in your ideas, Roger. I sent you a pm. I have a kit coming my way.
R,
Target
Chris
AMA 5956
