  • June 17, 2025, 10:18:40 PM
Author Topic: Baby Ringmaster Twin  (Read 928 times)
Offline pat king
    • PDK LLC
« on: December 04, 2011, 09:20:25 AM »
If you have a couple of Cox .020 engines looking for a home this will fill the bill. y1 The drawings for the Baby Ringmaster Twin are complete. The airplane is for Cox .020 engines. It can use the TD 020 or the Pee Wee 020, or one of each. The airplane has a 28" wingspan (7" C/L fuselage to C/L fuselage)with 131 square inches of wing area. The rib profile is Eppler 479 in the straight section and modified Eppler 479 in the tapered outer portions. The wing is built with a partially formed leading edge and a spar with spar caps. The kits will be laser cut with landing gear wire, steel straps for the landing gear, bellcrank and control horn, and music wire for the pushrod.
Thanks, Pat
Pat King
Monee, IL
AMA 168941
