  • June 18, 2025, 10:44:31 PM
Author Topic: FOX .049 F A I  (Read 1442 times)
Offline Robert Mathison
FOX .049 F A I
« on: January 12, 2010, 08:22:45 AM »
I am trying to locate head's that will use standard glow plugs for a FOX .049 F A I engine .
Thank for any help.
         Bob
Offline david beazley
Re: FOX .049 F A I
« Reply #1 on: January 13, 2010, 03:55:33 PM »
You might try Henry Werner at Virginia Hobby Sport.  I got a couple Fox .049's off him last year. He may have a solution.
AMA # 2817
Offline Jim West
Re: FOX .049 F A I
« Reply #2 on: February 18, 2010, 05:18:51 PM »
How are these engines compared to a Cox .049?
Jim West
Engine collector
Re: FOX .049 F A I
« Reply #3 on: February 26, 2010, 06:35:28 PM »
I am not an expert by any stretch.  I have 2 Fox .049's 1-an FAI version and 1-Sport with FAI crankcase (nostalgia legal).  I have bench run both and flown the sport one on a Musciano/Blackhawk Flightmaster.  As far as the numbers I don't have data.  Next time I run them I will document and post.  I my seat of the pants feeling is that while they are still breaking in they run much better than a reed cox but not up to a potent (modified with, pressure back plate, cylinder shimmed KK needle and bored out venturi, Globee head) TD.  Time and break in will tell.  I feel there is more in them but they need more running.  I have run them with Sig 10-20 Powermaster 15-18 with added castor and Sig Champion.  My overall opinion is that they have good potential and are a well made engine.  I got mine from Henry Werner at VA Hobbies.  They are assembled from NOS Fox parts by Doug Martin and have been run prior to shipping,
AMA # 2817
