  • July 06, 2025, 02:39:23 PM
Author Topic: blank  (Read 1472 times)
blank
« on: June 26, 2019, 08:59:41 PM »
blank
« Last Edit: September 14, 2021, 01:04:20 PM by Motorman »
Offline TDM
Re: Full Size to 1/2a Size
« Reply #1 on: June 27, 2019, 06:37:28 AM »
I would thin out the airfoil to some 15% root 13% at tip to help with penetration. It will still have plenty of lift.
To make a light fuselage you might want to consider laminating two layers of 1/32 balsa over a foam plug to make the fuselage shells. Maybe cut the number of ribs in half.
Offline Larry Renger
« Reply #2 on: June 27, 2019, 09:07:41 AM »
Generally, if you are at an in-between wood size when scaled down, use the next smaller size.
« Reply #3 on: June 27, 2019, 09:15:38 AM »
So if I just go to the copier and scale down a Thundergazer to 1/2a size will it fly ok or does it need a bigger tail or something?
Motorman 8)
Having flown a gazillion 1/2 A's and also free flight when I was younger I don't think that weight is that much of a factor (within reason).  If you have ever seen a TD .049/051 lift a 300sq" free fight (that weighs probably twice what you are about to build) straight up accelerating as it goes you know what I mean.  IMHO line tension is the #1 problem in 1/2a.  Too light and it doesn't stay out on the lines or you have to use lines too short to do a respectable pattern.  I wouldn't change the design at all.  I had plenty of planes with thick airfoils and they flew just fine although only a few had flaps.  If I did anything, I would build it so that I could move the engine forward or back to get the CG.  Every full body 1/2a I have ever built ended up tail heavy.
Good Luck - Ken
« Reply #4 on: June 27, 2019, 09:22:28 AM »
Heman Lee's Half Lite stunter is awesome, although it's not full house.  https://www.aeromaniacs.com/Freeplans.htm
I'd use a more modern engine than a Cox, and if I were serious about performance with a Cox I think I'd start with a TD, or I'd talk to Paul Gibeault about what he uses on his scale models.
