  • July 06, 2025, 09:45:31 PM
Author Topic: Focke-Wulf 190D Stunter Build - Flight video  (Read 13109 times)
Offline goozgog
« on: January 18, 2019, 01:16:59 PM »
Flight Video is at;
https://www.youtube.com/watch?v=rDfcimUYEP8&feature=youtu.be
Flight Report below at post #47
Christmas is over and the forecast is heavy snow.
Good time to build something !
  My previous posts about building the
Cox Spitfire Replica and the Top-Flite
Form-Flite P-47 show my enthusiasm
for molded 1/16" balsa.  It's light , stiff,
crash resistant and straight forward.
  Check out those posts for the details
about molding.
The Focke Wulf 190D is a perfect subject
for this technique. I've decided to build a
stunter but a scale FW-190 would be even
easier.
  The first picture shows the concept
drawing and the plug.
  I have always found conceptualizing
with a pencil let's me think more freely
so since the fuselage is more sculptural
I just nail down the dimensions then
have fun making it pretty.
  Carving the forms to mold the fuselages
is simple.  I just use lots of pencil lines,
carve a little, then more pencil lines,
sand and more pencil lines.
Nothing fancy.
  Notice that the bottom of the plug is flat
and straight at the wing root. This gives
me a datum line so that I can set the
incidences at 0-0-0.
  The other thing I've learned is to
NOT cut out details like the cockpit and
wing/stab mounts from the plug.
It makes molding the wet 1/16" impossible.
  So the big deal here is the wing.
It didn't take much addition to realize that
a 1/2A stunter with 210 sq/inch wings
has to be super light if a Cox .049 is
going to pull it.
   Looking at Other designs (Thanks Larry!),
12oz. has to be the absolute maximum.
I have considered everything. Foam, Foam board,
traditional built up, Millennium, I-beam and even
(very briefly ) Coroplast.
What I have decided on is a molded "D-tube"
like a Nobler but without a traditional leading edge.
The picture says it all.
I used the "Blend" tool in Adobe Illustrator
to generate the NACA 15 wing ribs.
Just draw the root foil and tip foil and...
Push the button Max!
  A technique I have used constantly for many
years is to design everything in CAD and then
print it out and glue the paper to the balsa.
Keep the #11 sharp, cut to size then sand to
the printed outline.
  The parts I hand cut are amazingly accurate.
Everything fits together like magic.
The pictures show how the molded leading
edge fits accurately over the ribs and the
main spar. It is tight and straight!
  The trailing edge will be carbon rod salvaged
from Brad Lapoint's combat casualties.
God bless those Russians!
More to come..  - K
« Last Edit: June 22, 2019, 06:38:02 AM by goozgog »
Keith Morgan
Re: Focke-Wulf 190D Stunter Build
« Reply #1 on: January 18, 2019, 03:14:22 PM »
How did you mold the leading edge sheet?
Mark
Online 944_Jim
« Reply #2 on: January 18, 2019, 05:09:02 PM »
You mean to tell us you HAND cut each of those rib-lightening circles?
I'm sitting tight waiting for this one to be finished. If it is anything like the spit and P-47, this HAS.got to be good.
Subscribed!
Offline Chancey Chorney
« Reply #3 on: January 18, 2019, 06:47:33 PM »
Another quality model taking shape! The work is simply amazing.
Offline goozgog
« Reply #4 on: January 19, 2019, 08:32:38 AM »
Hey Mark.
  Molding the wing leading edge was
simpler than molding a fuselage.
  I made a mold out of 3/4" x 3"  pine.
  Cut it to length including the tip and
root angles then marked the center
lines and glue the paper foil outlines
on the ends.
Lots of effort to plane and sand it
STRAIGHT !
  Something interesting in the 1st picture
is how the computer generates the ribs
for a tapered wing. All I need to do is
draw the root and tip foils, specify the
number of ribs and let the computer do
the rest. It's dead accurate.
  Jim.  I do make the holes individually
but with a Forstener bit on the drill press.
I get a clean hole by cutting half way
through them flipping the rib over to
get all the way through.
Thanks for your interest guys!
Keith Morgan
« Reply #5 on: January 19, 2019, 09:43:37 AM »
I really like seeing your work.    H^^
Online 944_Jim
« Reply #6 on: January 19, 2019, 11:59:55 AM »
Keith,
Thanks for the answer. I have a drill press, but rarely use it. I think it is going to see more use!
What software are you using to render the ribs between root and tip?
Offline Skip Chernoff
« Reply #7 on: January 19, 2019, 12:06:34 PM »
Nice work ,keep us posted!
Offline goozgog
« Reply #8 on: January 24, 2019, 09:00:21 AM »
  Hey Doc, Thanks for that.
I value your opinion.
Skip's too!
  Part of the reason I'm doing this post
is because of the 1/2A Stunt at Brodak's.
( If it happens)
Maybe knowing the weights of these components
will be useful for other builders.
  The picture shows the "Gift Card" bell crank
I made for the FW190.
   It's 2-7/8" x 0.5" between holes mostly because
that span fits in the wing.
  I didn't scrape the graphics off the card this time
and I just sandwiched it between the two layers.
I did a test with CyA and it bonds the plastic well.
  These cranks are decently stiff and strong but
because this will be buried in the plane I took the
time to add bushings made from some K&S
aluminum tube. Probably wasn't necessary.
  The entire assembly with the axle and spacers
weights 2 gm - 0.1 oz.
  I'm very pleased with the wing.
Attaching the molded leading edge was straight
forward and it naturally wants to build straight.
  I was planning on using Carbon fiber rod
for the trailing edge but I did a test and, believe
it or not, the built up balsa box spar T.E. is lighter
and stiffer.
  The complete wing assembly including the controls,
gear mounts, adjustable leads and 0.2 oz of tip
weight is  49 gm - 1.7 oz.
That doesn't include more tip weight, LG legs or
any covering.
  I'll probably cover it with Polyspan.
  I am still amazed at how well molding fuselages
works.
  The pictures show the half shells clinging to the
plug and overlapping before I cut through them
both to get a tight seam.
  I haven't weighed them yet but they are very
light.
The stabilizer picture explains itself.
  As I'm building this I'm thinking that this plane
might be better with a tapered plug like the P-47
so that the fuselage could be finished still on the
mold. It wouldn't be as FW-190 but obviously this
design could be painted to look like anything.
Fun fun fun!  - K.
« Last Edit: January 24, 2019, 11:15:48 AM by goozgog »
Keith Morgan
Offline goozgog
« Reply #9 on: January 26, 2019, 09:11:56 AM »
Hopefully this will be entertainment for
a cold January day.
  It's time to consider the power system
for this plane. The beauty of a Black Widow
is that it just bolts on and runs, but for
a real stunter there isn't enough fuel for
eight minutes.
  My ideal would be that this design is light
enough for a Cox production engine to be
able to pull it through a good pattern.
I'm going to play with 35% nitro and high
compression glow heads and see what RPM
I can get.
  I'm starting with my very fresh TD.049 on
a custom mount and a 1-1/2 oz tank.
  I have had excellent results with the
Mail Box tanks I make for my 60 size stunters.
I plumb them Uniflow with a third vent
for easier filling.
They run great, give a subtle warning then
quit cleanly.
Hopefully this will work scaled down for the
TD.
   The picture shows  the 3/4" x 1.375" x 3.0"
tank. It weighs 25 gm/0.8 oz before I cut off the vents.
That's lighter than any small plastic tanks I have.
I'm going to use it as a stressed member to help
offset the weight.
  I get steel for all my tanks from the Belgian
cookie tins that Wal-Mart sells at Christmas.
It's 0.009" ( nine thousands ) thick after I wipe
the paint off with thinner. It cuts easily with scissors
or a box cutter knife  which can also be used to
score it for clean  straight folds.
  The picture shows the aluminum forms I use
to make the end caps. I sandwich the sheet
between them with about 3/32" hanging
out all around the form, then I peen the edges
over to give the caps a nice lip that fits tight.
I think it looks good.
   The second picture shows the mount for the
TD that I made from a 1" x 1" aluminum
"L" extrusion. It weights 5 gm / 0.15 oz.
  I tried to use the same mounting hole spacing
that will allow me to mount a product engine
as an alternative.
  The entire engine/mount/tank assembly
(no prop) weighs 2.65 oz.
A black widow weighs 2.1.
Keith Morgan
« Reply #10 on: January 26, 2019, 05:01:16 PM »
Nice job on the tank and motor mount. I like the idea of the forms. When I built a couple tanks, I just free-handed the bends and folds, and they looked nowhere near as nice as yours. Thanks for the ideas and tips.
Offline Larry Renger
« Reply #11 on: January 26, 2019, 05:11:11 PM »
Kudos on tank construction and the engine mounting!
Also excellent photos and explanation.
Thanks!  H^^
« Reply #12 on: January 27, 2019, 03:00:18 PM »
That is what I need is the forms for end caps.   I like the engine mount. D>K
« Reply #13 on: January 27, 2019, 05:18:12 PM »
How much oversized do you make the end cap forms?    ???
Offline Target
  • C/L Addict
« Reply #14 on: January 27, 2019, 06:54:17 PM »
I'm also loving the tanks construction, because there really isn't a great selection of tanks for 1cc and under, especially uniflow, and for a built up fuselage....
Do you think the TD will have enough draw for running on uniflow? I've heard not, and that the Medallions have a lot better draw. I would guess you could swap the TD piston and cylinder to a Medallion case and still have power mid-way between the two??
I plan to circum(uni)vent that problem by running the Big Mig .049/.061's on my 1/2A planes.
Please looks great.
R,
Target
Chris
AMA 5956
Tom Vieira
« Reply #15 on: January 28, 2019, 07:07:17 AM »
so....
how long 'till you talk someone with a laser in to making a couple kits?
Offline RK
« Reply #16 on: January 28, 2019, 11:52:52 AM »
Or You could make several kits, start a sign up sheet with my name on TOP!!
Thanks for posting your work, R.K.
If you come to a fork in the road,,,,Take it!
Offline RK
« Reply #17 on: January 28, 2019, 03:50:00 PM »
After making the form what do you use to bend the wood?
Do you soak it in some type of liquid or steam ? I have used Windex with ammonia but I can never get a real tight bend like you have.
Offline goozgog
« Reply #18 on: January 28, 2019, 04:11:29 PM »
  OK Guys.. Here is a picture post of
how I make tanks.
 The trick is making the wood form first.
It defines all of the dimensions.
  Making the end caps is ridiculously easy
too.
https://stunthanger.com/smf/12-a-building/metal-tank-making/
Hey RK.  Thanks for the compliment.
   I just use hot water from the tap and
let it soak for five minutes.
  How I mold the balsa is explained in detail here...
https://stunthanger.com/smf/12-a-building/top-flight-form-flight-thunderbolt-18'/
and here...
https://stunthanger.com/smf/12-a-building/cox-spitfire-replica-build-flight-video/
  There isn't much to it. Carving the plugs
could get complicated but I just draw lots
of pencil lines and use my little Stanley Plane.
Cheers!  - K.
« Last Edit: February 02, 2019, 10:15:31 AM by goozgog »
Keith Morgan
« Reply #19 on: January 28, 2019, 07:26:24 PM »
[/quote]
Tee Dee top end and Medallion bottom makes,a great engine! The restricted venturi and mild crank combined with the better Tee Dee bypass system is killer.
Offline goozgog
« Reply #20 on: January 29, 2019, 03:36:26 PM »
Hello Larry,
  I mounted up the tank and the TD with
a 6-3 prop and ran it on 10% Richie's Brew.
It turned 15,500 and pulled hard.
  I waved it around and it kept running
for almost eight minutes.
  Of course, it might run different in the air.
I'm sure you've been down this path
more than once before.
I'm listening to you closely.   y1
   I'm making another metal tank and taking
pictures to explain how I do it.
I'll start another thread since it's a
long topic.
  A few pictures of the Focke Wulf.
To get accurate bulkheads measured off
the plug, I cut approximate holes in
cardboard and use tape to give a tight
measurement.
  I wasn't sure how I was going to join
the shells because the plug is a double
taper with no release angles.
It's much better to CyA the sides together
on the plug since it keeps everything straight.
  I put both shells on the plug and cut
through both together for an accurate seam.
then I glued the top seam completely
but only glued the bottom seam half way
from the tail.
  The plug slid out like a hen laying an egg.
Then I installed four bulkheads and the tank
from the front.
It's like building a ship in a bottle.
More soon. - K
Keith Morgan
Online Paul Smith
« Reply #21 on: January 29, 2019, 05:31:04 PM »
I run TeeDee's on suction with no problem.  There is no reason a Medallian should suck better, other than an oversize venturi on the TeeDee.
You can downsize a TeeDee venturi easy enough by gluing it shut with JB and redrilling it to a smaller venna concocta.
Offline goozgog
« Reply #22 on: February 02, 2019, 10:04:18 AM »
Hey Paul.
  I have several TD venturis. I'm going to try your
technique and narrow the bore and have it ready
if I need it.
   As the pictures show, I have the fuselage together
and Now I have to consider a way to install the controls.
  My plan is to insert the wing then cut open the cockpit
for access to the flap horns. That means I need a dead
simple way to link everything up.
   I started weighing material for suitable control horns
and all together it was going to be almost an ounce.
That's about 20% of the air frame so far.
No way!
    I'm taking a small chance with these aluminum horns
and bushings. I did some destructive testing and they
seem to have enough torsional strength  but I'm not sure
about fatigue and bearing wear.  It seems reasonable though.
  A funny thing is that I once met an old German machinist,
Herr Hippe, who told me about making controls for FW190's
in 1945. In better times FW190's had ball races in the control
linkages but by 1945 the life expectancy of the plane was
so short that young Herr Hippe was just machining them out
of bare aluminum.
Life is a funny old thing.
  My plan is to use JB-Weld to allow me to slide the rods
and center the controls. I need to get it right the first
time so wish me luck.
Cheers! - K.
Keith Morgan
Offline goozgog
« Reply #23 on: February 02, 2019, 03:55:04 PM »
    I didn't get much done today but
I decided to face the music and pile
everything on the scale at once.
6.8 oz before covering and dope.  y1
Not bad for a 35" span - 210 sq/inch plane.
   Of course weight has a way of sneaking
into the mix.  If I can bring it in under
10 oz I'll be happy.
Cheers! - K.
Keith Morgan
« Reply #24 on: February 03, 2019, 07:53:26 PM »
If I am seeing correctly, you have the aluminum flap horns running in aluminum bushings.Bad potential for galling and seizing. The bushings should be brass or steel!
« Reply #25 on: February 03, 2019, 08:56:01 PM »
Wow, she's looking good. And the weight sounds very good too.
Online Dave Hull
« Reply #26 on: February 03, 2019, 09:14:20 PM »
I would not worry much about fatigue of the aluminum horn. I would worry about the contact stress where it contacts the clevis pin or pushrod. The contact area is small, and aluminum that you likely are using does not have much strength. (If it was real high strength, you wouldn't be bending it like that, or hammering it flat.) Hopefully the wire is pretty hard, but if you fly it much, it may wallow out from excessive contact stresses in bearing. (That's what engineers call that type of applied load.) You probably are using K&S tubing (alloy 3003-H14), which has poor galling resistance. If you use a Sullivan clevis with gold plating, the gold may save you from galling, as it is excellent. But not from deformation from exceeding the yield strength of aluminum from bearing stresses.
If the horn and your aluminum tube (journal bearing) are lined up really well, so that the load is well distributed, I'd gamble that it will work out. Your odds go up if the materials are harder, because galling (metal transfer) occurs earlier with softer (more ductile) materials.
You might consider lubricating this with something like Tetra or Break Free synthetic gun oils. Even a "wipe on, wipe off" treatment using a silicone grease is better than no lubrication. I think a thin film would be helpful.
Nice project--thanks for sharing it with us!
Offline goozgog
« Reply #27 on: February 06, 2019, 11:42:13 AM »
Thank you for the seriously considered replies.  y1
    Dave, I think if you saw how small and light this
plane is you might agree with me that the loads
on the controls are going to be minuscule.
   You are correct, the bearing surfaces are small.
I feel they are reasonable.
   My experiences with offshore yachts has made
me paranoid about aluminum parts and dissimilar metals.
The old time remedy against galling is lanolin.
( Insert Sheep Grease joke here).
I have pre-lubricated the bearings with Teflon
grease.
  I know I'm taking an educated risk with this
but the weight benefit might be worth it.
Cheers! - K.
« Last Edit: February 07, 2019, 08:15:46 AM by goozgog »
Keith Morgan
Offline goozgog
« Reply #28 on: February 12, 2019, 12:06:42 PM »
  It's blowing a hoolie out there today.
Probably 35 knots and gusting with
heavy snow. I should have two anchors
to windward to keep the house from dragging
through the anchorage.
  Nice weather for building.
  Assembling the controls was good practice
for a future career in bomb disposal.
   I usually take a full day to get the controls
into a stunter, but this little plane has been
a new experience.
Sixteen hours to set up the controls using
tweezers and swearing.
  I am happy with the result. Everything is
adjusted and smooth. Hopefully sealing the
hinge lines won't stiffen them up.
  The pictures show the plane complete
except for fuel line and wheel retainers.
With three coats of Butrate it weighs
exactly 8oz.
  The covering is Polyspan.
  I think I should be able to decorate it
and still keep it under 9oz.
Cheers! - K.
Keith Morgan
Offline Target
  • C/L Addict
« Reply #29 on: February 12, 2019, 03:33:35 PM »
Regular polyspan or light polyspan?
Where do you buy the light stuff?
Looks great!
Chris
AMA 5956
« Reply #30 on: February 12, 2019, 04:18:52 PM »
That looks just awesome. If one day I could ever build like that, I would leave it as it sits to show off the great craftsmanship! Thanks for the update.
Offline goozgog
« Reply #31 on: February 13, 2019, 07:58:00 AM »
Hello Target,
  I use the Polyspan that Tom Morris sells.
I checked the info sheet but it doesn't show
what weight it is.
  It feels slightly lighter than the SIG medium
silkspan paper that I covered the rest of the
FW-190 with.
  Last winter I covered my Wildman.60 sparky
with the same Polyspan. The Super Cyclone
shakes like a paint mixer but the wing hasn't
shown any effects. This stuff is light and strong.
  The only thing that isn't perfect is that it won't
bend around wing tips or fuselage details so
I use silkspan for those areas.
  Hey Chauncey,
My wife said the same thing. "Too bad you're
going to paint it and hide the structure."
  IMHO the best builder I know is Dan Banjock.
His planes are gorgeous and original.
( Bob Hudak photo.)
We could all copy his designs and build the
exact same plane, but not to his standards.
Our efforts would be somewhere on the curve
between awful and Mr. Banjock's.
I am slowly moving up that steep curve, step by
wobbly step.
 n~
Keith Morgan
« Reply #32 on: February 13, 2019, 09:12:03 AM »
Dan is a big guy, that plane is HUGE!
Offline goozgog
« Reply #33 on: February 22, 2019, 08:14:31 AM »
   The weather has been miserable here
so I've been working on the Focke-Wulf.
  Military markings are designed to be simple
to apply and since the Dora is a late war
austerity plane, the color scheme is very
simple. Gray on Gray!
Could it possibly look any more German?
  I never intended this  design to be a scale
model so I didn't try to accurately represent
the details of the full size plane. Besides, the
stretched out proportions of this stunter
convinced me to just make it pretty.
  I eyeballed the lettering and hand rendered
them with blue masking tape and a sharp pencil.
The small size didn't make it any easier.
  I used a cheap detail spray gun to apply the blotchy
grey coloring and it looked awful until I added
the sharp edged crosses that made things logical.
  Any place where the gray just looked muddy,
I used a HB2 pencil to draw the panel lines.
It really helps detail the plane before the final
coat of Brodak Crystal Clear dope.
  Modeling a WWII German aircraft always gives
me a moment where I have to consider the swastikas.
  My family is from the East end of London and my
mother was in the RAF, so I am prejudiced.
Thankfully Rick Huff solved this dilemma for me.
I was admiring his ME 109 stunter that has an
unadorned tail.   His suggestion was that a
scale model should have the swastikas but there
is no reason for a stunter to have them.
  Thanks Rick.
Keith Morgan
Offline goozgog
« Reply #34 on: February 22, 2019, 08:25:48 AM »
    I'm very happy with the final weight and
balance.  Bench trim is just a trifle nose heavy
and I might have a smidgen too much tip weight
but good enough until it has flown.
Final weight as shown but dry is 8.8 oz or 248 gm.
 I'm happy with the weight and I'm sure the
TD.049 will pull it, but it might be just a little
too much for a product engine.
I will experiment with high compression heads
and nitro. It might work.
« Last Edit: March 19, 2019, 05:22:12 AM by goozgog »
Keith Morgan
Offline goozgog
« Reply #35 on: February 22, 2019, 08:49:21 AM »
   I was tempted to put tiny Fritz in the cockpit
complete with monocle and mustache but his
Pickelhaube woudn't fit under the canopy.        <=
  Just for the record here are the numbers
and stats I used designing this plane.
- Finished dry weight - 8.8 oz / 248 gm
- Wing span = 34.5"
- Wing area including flaps = 207 sq/inches.
   Root chord 7",  Tip chord 5" including flaps.
   Root chord 6", tip chord 4.5, no flaps.
- Flaps 12.5% of wing area.
  Outboard flap is 17% larger than inboard
-  Stabilizer span is 15".  Mean chord is 1.625"
   Area is 24.375 sq/inches.
- Elevators 7" x 1.375" ea. . Total area = 18.2 sq/inches
  75% of stabilizer area.
-  Stab and elevator area = 20% of wing area.
- Tail moment, hinge line to hinge line = 9.75"
- Nose moment flap hinge line to prop boss face = 11.5
  LE to prop boss face = 5.5"
- Wing foil is NACA 15
- Engine Cox TD 0.49 with HC head.  6x3 prop.
- Tank capacity = 1.5 oz.
- Cowling and canopy are molded using the bottle trick technique.
« Last Edit: March 19, 2019, 05:22:27 AM by goozgog »
Keith Morgan
« Reply #36 on: February 22, 2019, 11:08:39 AM »
Looks nice and I bet looks better in color.   I remember when Don Still went over seas to compete in the World Championship he had his Stuka in a white color and no swatiska's.  Some people never forget what the symbol stood for. D>K
« Reply #37 on: February 22, 2019, 03:04:11 PM »
Simply amazing and great job on the paint, and markings. Another one for the books. I really like the picture in the snow. I had to do a double take as that is when I realized the snow. So, without being too pushy...... What's next? ;D
Offline goozgog
« Reply #38 on: February 23, 2019, 04:03:44 PM »
Hey Doc ,
  Yup.  It's like looking at pictures of
Neil and Buzz on the moon. The Kodachrome
film picked up absolutely no color except
the Flag.
   I put the plane on the snow for the pictures
because it makes it look extra bleak.
   I know it's illegal  in Germany to have
swastikas on anything, even planes in
museums.  I think I can understand that,
but......
 Chauncey,
  It's good to see you building. I have a
Jr. FliteStreak that I'm refurbishing and the
only appropriate engine I have is a Fox .15.
It's equivalent to your Jr Ringmaster.
I'll let you know how it goes.
   What's next?
I think I have enough 1/2A's for now and
a big part of the reason I built the 190 is
to try some more advanced balsa molding.
  I have been slowly adapting these techniques
for my full size stunters to mold turtle decks,
cowls and fuselage bottoms, but I want to
try fully molded fuselages.
  I use 1/2 oz glass and epoxy over molded 1/16"
balsa and it's very stiff and fuel resistant.
These planes have a Ro-Jett .65 and a .67
up front and the molded parts take all that
power nicely.
   Most of the top guys near me fly Yatsenkos
since they focus on the FAI Worlds.  Anyone who
is remotely serious has to have a serious plane.
My goal is to build my own.
(and learn how to fly it. )
Cheers! - K.
« Last Edit: February 24, 2019, 03:56:25 AM by goozgog »
Keith Morgan
Offline Target
  • C/L Addict
« Reply #39 on: February 23, 2019, 05:17:41 PM »
What swastikas? All i see are iron crosses.
Chris
AMA 5956
Offline Target
  • C/L Addict
« Reply #40 on: February 23, 2019, 05:21:26 PM »
Can i ask if you have pics of the wing mounted main gear?
Is the wire attached to a spar, or a platform running between ribs?
If the latter, are the ribs reinforced?
If so, with 1/64th ply?
Thanks in advance.
R,
Target
Chris
AMA 5956
Offline kenneth cook
« Reply #41 on: February 23, 2019, 10:41:26 PM »
            The main problem which leads everyone to not thinking that the TD is suitable for suction is the way it's typically used. Keith's tank will be close and directly behind the engine. When the TD is mounted on a profile, the tank unless customized has the pickup too far outboard which can be problematic for the engine run. It's not that the TD won't work, it's the tank that's causing the issues. To use it on a profile may just require a longer narrower tank. Paul has mentioned and has also posted how he narrows down the venturi using JB weld. My hats off to you Paul as you certainly do a nice job at doing it. This would lead me to believe that while it does provide better fuel draw, I can only think it does rob a little power in doing so. Ken
Offline Target
  • C/L Addict
« Reply #42 on: February 23, 2019, 10:58:27 PM »
What advantage is there to using a td on suction vice using a td top end on a Medallion case/crank?
Is the power difference going to be that noticable, if you have to choke down the venturi on the td to get a similar draw, anyway?
R,
Target
Chris
AMA 5956
Offline goozgog
« Reply #43 on: February 24, 2019, 04:24:27 AM »
Hello Chris,
  I decided to leave the swastikas off this plane.
Doc and I were discussing why in posts # 33 and #36.
  Pictures of the wing mounts for the landing gear are shown in
post #8 "FW190 Center" and post #22 " FW190 Fusefit"
  The landing gear wire is just the standard "Z" bend,
torque spring configuration.
What you can't see is the 1/16 I.D. aluminum tube
that receives the 1/16" wire to anchor it to the spar.
    Most of the energy is being absorbed by the molded
D tube leading edge. I used 1/32" ply to distribute the
forces. The ribs in this area look inadequate until you
consider the cap strips and Polyspan covering.
Cheers! - K.
Keith Morgan
Offline goozgog
« Reply #44 on: February 24, 2019, 04:44:10 AM »
Hello Ken,
   Thanks for your thoughts on the TD.
Obviously you know more about them than
I do.
  My TD is dead stock but fresh.  I checked it
with the tank on a test stand and waved it
around. It seemed OK and ran over seven minutes.
With a 6x3 prop it turned 15,500 rpm on 10% nitro.
I am amazed how hard it pulls.
  Larry is suggesting a Medallion crank for
a stunt friendly run. I am keeping that option
open since the cranks are cheap and available.
Will I also need the red plastic Medallion venturi ?
  I have several TD venturis to work with, so I'm
going to use aluminum tube to sleeve one down
as Paul Smith suggests. I have a set of index drills
to measure and adjust the bore.
   I suspect TD's were designed to be high performance
Free Flight engines. I'm going to try running them like
a modern piped engine. Let them spin and be happy
and I'll use flat props to soften the effects.
Cheers! - K.
Keith Morgan
Offline Target
  • C/L Addict
« Reply #45 on: February 24, 2019, 06:43:28 AM »
Thanks Keith!
Chris
AMA 5956
« Reply #46 on: February 24, 2019, 10:15:06 AM »
          Chris, Paul like Keith is a very experienced builder and partakes in many events. He mentioned 1/2A scale and for that you probably are not in need of a engine as powerful as the TD. Necking down the venturi calms the engine down and improves fuel draw which is what is desired. More than likely uses them due to what he has on hand. It's always better to have more power than not enough as it's easier to tame a engine down vs extract more power. Seeing that the Medallion is a single ported cylinder, I would expect even a choked down TD is still going to offer more power. Many years back I recall Tom Hampshire using a TD with a Medallion carb body on a Scout. I have to say it was a jaw dropping flight as that plane just impressed all of us standing there. A very worthy flying plane with a terrific engine run made entirely from a bunch of pieces he had laying around. To date, I believe Tom still has this plane and I would love to see him fly it at Brodak's.
         I have seen the discussions on here and another forum in regards to switching and mismatching parts on the TD and Medallion. I have several of both and I would prefer not to do that. More power can be extracted from the Medallion with a high comp head, Sure Start cylinder, etc. The TD though in my opinion can be made to work quite well, Keith's suggestion of letting it wind up or adding more head gaskets, I personally wouldn't address fuel draw prior to seeing if it's a problem and go from there.
Offline goozgog
« Reply #47 on: April 08, 2019, 08:42:46 AM »
First Flight Report
 The snow is off the circle and it was 50 F Saturday.
Time to test the Focke-Wulf.
  Traditionally, I have Chris Brownhill pilot the first
flight on my smaller airplanes. He has a lot of experience
with small and hot  team racers and he has an uncanny
ability to land with the shiny side up.
  I did a lot of testing with the TD .049 so it fired right up.
Well!
  Chris did most of the pattern maneuvers on the first
flight except the clover and hourglass. Modesty prevents
me from raving about how the 190 flies, but wow!
  Full disclosure. I have never seen a serious 1/2A CLPA
plane fly before and I didn't know that they could be
this capable.
  I had the second flight and except for the lightness
of the controls it flies just like any good stunter.
I wasn't as adventuresome as Chris but managed some
decent wing overs, square eights and triangles.
  I need to say something about the TD.
(I.5 oz uniflow, 10% Riche's brew, 6-3 Master airscrew,
restricted venturi, H.C. head with one gasket, fine thread NVA,
15,500 rpm. )
   We only had three flights but the engine ran steadily
without any noticeable RPM change through the maneuvers .
1.5 oz of fuel gave about eight minutes and the engine
had no problem drawing it to the last drop. It was easy to
needle and start.
Lots of power for the 9.0 oz Focke-Wulf.
  I took Paul Smiths and Ken Cook's advice about restricting
the venturi except that I ground off the mesh screen and used
K&S aluminum tube to sleeve down the throat.
   I might be missing something but I can't imagine what
more I can expect from an .049 or any engine.
Our circle is at 567 feet elevation and it was a cool dry day.
Things might change at other circles.
  Now I just need to learn to fly but I couldn't be happier
with this plane.
Cheers! K.
« Last Edit: April 08, 2019, 08:59:36 AM by goozgog »
Keith Morgan
« Reply #48 on: April 14, 2019, 06:33:11 PM »
Congratulations on yet another awesome project completed.  Wish I could see the model fly. Maybe get some video?
By the way, my Skysport is 190 sq. in, no flaps and 10.5 oz. It flies just fine through a competitive pattern on 38' lines. You have a LOT of margin of performance by comparison. I also have a Baby Nobler at 165 sq.in. and 11.5 ounces. With flaps it turns great. (Sadly it has a simply awful control setup and is a demon to fly)
Offline goozgog
« Reply #49 on: April 16, 2019, 03:24:07 PM »
    Thanks Larry for the info.  It sounds like
I'm in the weight bracket if it gets windy.
  I was flying the Focke-Wulf on 45 foot,
10 lb Spiderwire lines and that seemed usable,
but the SpiderWire tangles very easily.
I didn't like it.
  Previously I had good success flying the
Spitfire on 38 foot PowerPro 10 Lb braid.
My local supplier doesn't have any in stock
so I went for a long drive to a (very) serious
Hunting, Shooting, Fishing store and let
the people there tell me what to try.
  I came home with a 150 yard reel of
Sufix  832 braid 12 lb.
  The fiber is "Gore" , whatever that means
but It's supposed to be very low stretch and
resistant to tangles.
Maybe the magic word is "Braided"
I will report back !
Cheers! - K.
Keith Morgan
