Building Tips and technical articles. => 1/2 A building. => Topic started by: Jerry Bohn on September 14, 2007, 08:11:29 AM
I am going to fly a Blackhawk "Stunt Trainer" w/Cox Baby Bee .049 35' lines and wish to know about substituting wire cable or dacon lines with Spider Wire fishing line. Seems to have great strength and no streach. Only major question is what weight Spider Wire should be used as I could not find specs on dacon flying lines as far as weight rating.
Perhaps I am barking up the wrong tree, but I have spider wire on hand but also wasn't sure if I should use it.
I use 14 lb., I think it says something like "8 lb. diameter, 14 lb. test" or some similarly silly thing. Pkg calls it "fusion", not sure what that means. I use it up to 52' for .061-powered stunters, 42' for 75mph combat wings, also .061-powered.
--Ray
I'm using Spiderwire "Stealth" braided line. 20lb test at 6lb diameter. I can't really say how it compares to other currently available products, but compared to the old stretchy nylon and dacoron its "the bomb." I like it so much I'm considering using it for fishing.
Hey High Flying Guy,
Dont forget to use the palomar knot!
http://www.fish4fun.com/palomarknot.htm
H^^
Yes...thanks Tom. Standard overhand knot WILL slip. A couple different "fisherman's knots" will work; Palomar seems simplest to me.
--Ray
Tom, Gotcha on the knots. I'm a old Bass fisherman and fly fisherman. I have always used surgons knots for fishing but polomar looks better to me, also I may use it next time fishing, easy enough.
Thanks, Jerry
I've found the Spiderwire fairly abrasive and wold not reccomend it be used with metal line guides on your fishing pole. Seems OK with ceramic or agate guides though. Since it dosn't streach like the monofiliment lines it take some getting used to as far as setting the hook. y1
Tom, Thanks for the warning, I only used it a short while and only fly fish now. It's leftover from a several years ago. I keep it around for projects that need strong string. Used it and epoxy to bind the fittings on a carbon fiber push rod, seemed to work OK.
What seems to be the best way to get the lines in equal length?
Practice tying the knot. LL~ LL~ LL~ I have been watching the videos hoping to get an idea. I guess bet bet is to get as close as you can and use a clip making tool for different lengths. D>K
This seems like the biggest hurdle to using the Spectra lines.
One "solution is to use a handle that has the sliding wire.
I figure that you are gaining so much on the lack of play using the Spectra, a little flex in the handle cable won't kill you.
A mini hard point handle with mini differing clips would be GREAT.
Or, if the line spread is acceptable, one of the combat handles with the thumbscrew for "on-the-fly" adjustments.
So many options, I guess just get them as close as possible and then use any of the above solutions.
