  • June 28, 2025, 09:30:42 PM
Author Topic: 1/2 A questions...  (Read 2212 times)
Offline Ward Van Duzer
1/2 A questions...
« on: July 20, 2008, 02:44:04 PM »
Ok, just starting to fool around with some of this 1/2 A stuff! (Lots of questions). I'm using 8 lb Spider-wire for lines on a TeeDee powered stunter. This OK? Yes I'm CA'ing the knots! But what is appropriate length? Flew this AM with about 37+ feet and that seemed a little long...Using Cox grey 6 X 3 prop. OK? D--n broke one! Not too many left...Anything better out there? Would switch to a Bolly F/G if need be. My 15-20 year old Cox Competition fuel still seems to work. (Have about 3 pints left). What formulas are you guys using?
BTW, Had a ball!   HH%%
Ward
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: 1/2 A questions...
« Reply #1 on: July 20, 2008, 08:09:54 PM »
I usually fly .049-powered planes on 35' lines, up to 42' if I want slower lap times.  8-lb Spiderwire is sufficient; I have used 12#, depending on what is available when I go to buy a reel. Can't tell much (if any) difference in performance. My .061-powered models use 42' minimum line length, up to 52', again depending on the lap time I want.  You have to be kinda masochistic to put an .061 on 35' lines, although I do it occasionally (too lazy to roll out another set of lines for maybe one flight).
You don't need to CA the knots if you use a Palomar knot, or two or three other kinds that are non-slip types. A standard double hard knot (square knot) will not hold in Spiderwire; it will slip out. (Unless CA'd I suppose!)
I don't have a TeeDee .049 so can't speak to the appropriate prop, but a 6x3 seems a little much, I would run that on an .061.  My .049s (Norvel, VA, Black Widow, Brodak) mostly use 5" or smaller props, down to 4 1/4", x3" pitch. Whatever it takes to get the rpms up, the little engines don't lug well. The Cox black plastic 5x3 broad-blade prop is sort of my base, then I whittle down the diameter from there as needed.   APC props perform better but will break, and will do more damage if you get a finger in one! I've found the APC 6x2 to be just about the ideal prop for an .061-powered stunter. APC makes a 5.5x2 that might work well on a good .049 for stunt.
Fuel, I've used everything from 10% to 35% nitro, castor oil and synthetic, it all seems to work pretty well--the higher nitro does I think result in easier starts. I don't habitually tach my engine runs, but I don't notice any real difference "by ear" in the various nitro levels.
You got pics of what you're flying?
--Ray
AMA902472
Offline Bill Adair
  • AMA 182626
« Reply #2 on: July 20, 2008, 11:28:12 PM »
Ray,
I have a roll of 8# size (12# strength) Spiderwire as well, but haven't figured out how to hang a line clip on a Palomar knot?  HB~>
The illustration shows the drop loop of a Palomar knot going through a fish hook eyelet, and then around the shank of the hook, before being pulled tight.
I've read here that using a too tight radius in the Spectra line termination can reduce the pull test to half the lines rated strength, and that seems a bit risky.
How do you connect your lines to a half A line clip?
« Reply #3 on: July 21, 2008, 11:40:54 AM »
OK, here's what I'm flying! Not real hi-tek. Actually a Red Reinhardt design from the 50's. He called it the Snapper, a design in "Variable Dihedral"! Yup, the 1/8th sheet wing flexes considerably in manuvers. I re-published this in FM 12/89 as a take apart. Plans may still be available.
As to what kind of knot am I using...Yes, I am a fisherman but that spider web stuff is so fine I do it the simple way. An overhand loop. Now you know why I use the CA!
W.   :P
Offline Jim Thomerson
« Reply #4 on: July 21, 2008, 02:21:09 PM »
I have had good success with MAS 6 x 3 cut down to 5 1/2 on TD's. The APC 5.75 x 3 also works well.  Usually used 42 ft 008 cables.
Offline Clancy Arnold
« Reply #5 on: July 21, 2008, 02:32:05 PM »
I was not ready to post my latest information on 1/4A flying lines but!!!
I have not finished a series of tests on different weight lines but at present I can state that if you use any knot directly on the line clip it will fail at about 50% of the rated line test.  I.E. 20 lb test line will break at about 10 lbs load.
BUT!!!  If you tie the line around a ferrule, like you use on bigger steel lines, with a palomar knot it will hold to almost the rated breaking strength of the line.
I will add a sketch soon.
Also do not use monofilament line!!!  Use only woven, non-stretch, line.  Ask me how I know!
Clancy
Clancy Arnold
U/Tronics Control
Offline Robert McHam
« Reply #6 on: July 21, 2008, 04:05:22 PM »
How about a source on those ferrules!
I used to do it the cheap way once upon a time. You know the little brass eyelet that was on the hanging items like Perfect and others? I would save these for my larger planes just for this purpose. Never had to buy any!
Robert
Offline Bill Adair
  • AMA 182626
« Reply #7 on: July 21, 2008, 05:53:50 PM »
Ward,
Thanks for the info. I have lots of CA!  ;D
Clancy,
Looking forward to your article.  H^^
Your earlier postings were the source of the line failures I cited.
Offline Ralph Wenzel (d)
« Reply #8 on: July 23, 2008, 11:20:02 AM »
The best, IMO, is P/N 3436T12 on page 1390 of the McMaster-Carr online catalog. Not cheap (≈ 25¢ ea. if you order 50) but almost infinitely reusable, and good for any size controllines or leadouts.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Offline Bill Adair
  • AMA 182626
« Reply #9 on: July 23, 2008, 12:21:16 PM »
Ralph,
Those look good, and the price is reasonable enough, but have you tried them?
If so, how sharp are the small open end edges, where the line would rub?
