Building Tips and technical articles. => 1/2 A building. => Topic started by: minnesotamodeler on July 14, 2008, 04:25:35 PM
Title: Flight report...Otto the Junior Gyro
Post by: minnesotamodeler on July 14, 2008, 04:25:35 PM
OK, I finally got the shrunk-down Otto the Gyro out today...pic below to refresh memories.
Official report:  It flies!  Makes you laugh out loud just to see it.  Rotor just singing away, about as much a blur as the prop is. I don't know what rpm it must be turning, but it appears pretty much like a disc.
Urban Legends exploded (things I was cautioned about while building it):
"Launch man must give the rotor a spin before launching." No he doesn't. I used a stooge; prop blast had the rotor turning, only about 60-80 rpm but turning, and as soon as it released the rotor spun right up, within just a few feet.
"It'll taxi nearly a full lap before it gets off." No it doesn't.  Takeoff run about the same length as winged airplanes.
"It won't glide at all; will need repair after each flight (flips and breaks rotor)."  Uh-uh.  Not much glide, granted, but enough to get it down in one piece. On its wheels.  In the grass.
"You can nurse it through a loop."  I don't think so! Not sure the rotor would take it; a gentle climb increases the rpm alarmingly. You can feel it thrummmming (is that a word?) in the lines.
"The rotor AoA is 'way too extreme--it needs maybe half what it has (7.5 d. rather than the 15 d. shown on the plans)." This one is right; in level flight the tail was noticeably high. I plan to reduce the rotor angle before I take it out again.
All in all, this thing's a blast.  I count it a complete success!
Oh, the Norvel .049 is plenty of power; no need to go to the .061.
Title: Re: Flight report...Otto the Junior Gyro
Post by: Robert McHam on July 14, 2008, 06:41:17 PM
Beautiful!
And to be a myth buster at the same time...What a guy!
Thanks for sharing
Rober
Post by: john e. holliday on July 19, 2008, 08:04:23 AM
Sounds like your having too much fun.  Glad to hear it works.  DOC Holliday
