  • June 13, 2025, 10:38:11 PM
Author Topic: FireBaby Build  (Read 88807 times)
Offline Rick Bollinger
  • AMA 931589
FireBaby Build
« on: November 30, 2012, 11:59:34 PM »
With all the activity lately about the Firebaby I wanted to try one. The wings are made from 1/16 balsa. Clear doped then covered with a decal I was able to make from a scan from the original wing. All the aluminum parts were copied from the kit. The tan colored part at the top is a mold for the canopy. Dug out a old Baby Spitfire cleaned it up and it seems to run good. I plan on running it on a balloon like the original. There are a lot of firsts here for me so this has been a lot of fun.
Rick Bollinger
AMA 931589
Offline afml
Re: FireBaby Build
« Reply #1 on: December 01, 2012, 04:23:57 AM »
AWESOME job Rick! y1
Keep us posted on the progress!
"Tight Lines!" H^^
Wes
P.S.: So like.....
You just scanned the original wing to make a decal??
How did you keep the wing from rolling & warping from the decal application??
Gonna do the same with the stab?
Thanks for the pics!
Wes Eakin
  • AMA 931589
Re: FireBaby Build
« Reply #2 on: December 01, 2012, 06:50:51 AM »
Wes, I wet the wing put in a "airfoil" shape. Then wet the center to put in the dihedral. When all was dry I used tightening butrate on the bottom and non tightening on top. The decal is a self adhesive clear full sheet mailing label. Then I used clear lusterkote to seal it up. Rick
Rick Bollinger
AMA 931589
Offline john vlna
Re: FireBaby Build
« Reply #3 on: December 01, 2012, 10:21:55 AM »
Rick,
really nice, just like the original almost. may have to try one myself, I have a baby spitfire.
Offline fred krueger
Re: FireBaby Build
« Reply #4 on: December 01, 2012, 09:38:04 PM »
Rick,
I have one thing to say......WOW!!  You had more patience with the wing than I did.
Fred
  • AMA 931589
Re: FireBaby Build
« Reply #5 on: December 02, 2012, 08:09:26 PM »
Thanks Fred, I do need some advice on the horz stab. The original had a red cloth hinge running the length of the stab. I want to put the hinge on top of the decal. After I put 2-3 coats of clear lusterkote on. What adhesive would be best and what type of hinge material? Or should I just cut the decal out around the hinge and just put it on over the bear wood like normal?  Here is a scan from the original stab and after my wife photoshoped it for me that I will make the decal from.
Rick Bollinger
AMA 931589
Re: FireBaby Build
« Reply #6 on: December 02, 2012, 08:25:39 PM »
Rick,
Here's a scan of a Firebaby stab/elevator that I purchased a while ago on eBay.  This one has the hinge material on the bottom which would eliminate your problem.  It appears to be cloth of some type.  The stab on my 'replica' model uses fabric binding tape that I purchased at Hobby Lobby.  I glued this to the wood with Ambroid.
Fred
Offline GGeezer
    • Gizmogeezer Products
Re: FireBaby Build
« Reply #7 on: December 02, 2012, 08:35:00 PM »
Hi Rick,
You did such a good job on this replica that I was initially skeptical that you had just photographed the original! I copied a photo and enlarged it and could see that the firewall and wing mount parts were not punched for a variety of different motors like the original... so they definitely are repos.
I also have an original eBayed Firebaby that I reconditioned. The stab hinge was mostly detached and very stiff. Trust me, the FB is very light on the lines and that hinge has to be very free moving.
I removed the original cloth hinge and replaced it with a red Monocote hinge of the same dimensions ironed on. I don't know what kind of decal material you are using and whether you are top coating it but the iron on hinge may also work for you. I have done a fair amount of flying with my FB and the hinge is holding nicely.
I love the metal work you have done on your model and have some questions:
1. What type of aluminum did you use for the wing mount and firewall?
2. Did you make tooling to press form the firewall?
3. I have had difficulty finding the thin hard aluminum that was used on the original's fin, what did you use?
4. My reconditioned FB is missing the original canopy, would you consider selling me one when you form yours?
Again... great job.
Orv.
  • AMA 931589
Re: FireBaby Build
« Reply #8 on: December 02, 2012, 09:43:34 PM »
Fred, I wish my stab was in that good of shape it sure would have made things a lot easier. And you are so right. I looked closer at my old stab and the hinge IS on bottom. I am so use to the horn being on the bottom but it is on top on the FB.
Orv.I am a sheet metal worker by trade. Althow not usually this kind of work (unfortunately) A lot of the techincs are the same.
All the alum I was able to get is I believe a 50 series. It is fairly soft which is OK. I would have liked to had some 6061 for the rudder but what I got is adequate. The wing mount is .026, the firewall is.032 and the tail is .016. I got all the aluminum at my local Ace hardware store. It was in the display with the brass tubing and music wire. The firewall I made a plug using epoxy putty. I left a handle on the back so I could clamp it in a vice. Cut the aluminum about 1/8 - 3/16 bigger than the outside of the plug no more or you will not be able to form it. Use a small hammer like a tack hammer just a couple oz's. And start tapping the metal around the plug. It takes time and can be frustrating  HB~> . I have tried twice to pull a canopy with no luck yet  HB~>.
Rick Bollinger
AMA 931589
Re: FireBaby Build
« Reply #9 on: December 03, 2012, 08:21:22 AM »
Get a clear soda bottle or what ever color tint you like.  Just needs to be big enough for the plug to fit.   Looking at the picture, put pointy end towards the  neck of the bottle and pack open area under the block with scrap wood of some kind.   Grab you hot air gun used for MonoKoting and got at it.   It should shrink up/down real tight.   Mark your cut lines before removing from the block. It takes time and practice,  I went thru several/many soda bottles before I got my P-47 canopy I liked.  Still not perfect, but I am satisfied.
Offline GGeezer
Re: FireBaby Build
« Reply #10 on: December 05, 2012, 12:22:50 AM »
Thanks for the info Rick.
What is your canopy plug made of?
Although with some practice you can make the soda bottle method work to an extent but it will be challenged by the rather narrow section at the back of the canopy. Here is an option.
I have the skill and the thermoforming machine to do the job... you have the plug. If you send me the plug, I will pull as many canopies as you need and a couple for me too. I will then return your plug along with the canopies. Your only cost will be the shipping to me. I use PET-G (same as soda bottles are made of) for most of the canopy work I do.
Orv.
  • AMA 931589
Re: FireBaby Build
« Reply #11 on: December 05, 2012, 07:15:40 AM »
John, thanks for the tip. I was able to make a decent one out of a soda bottle. But I think I will take Orv up on his offer.
Orv. Pm me your address and I will get it out to you. I made the plug useing durhams rock hard water putty. There are 2 bolts comming out of the bottom. If this will be in the way I can make another no problem.
Rick Bollinger
AMA 931589
Offline GGeezer
Re: FireBaby Build
« Reply #12 on: December 05, 2012, 01:29:10 PM »
Hi Rick,
The water putty should work well. The bolts in the bottom will be needed to secure the mold to the platen.
The reason I want to make this deal with you is that you have a cast duplicate of the original canopy. I would have to sculpt one to the approximate dimensions. This would take a lot of time and wouldn't be as accurate.
Although I have a policy of not advertising on group sites, I will break this policy this time.
I am a cottage-industry manufacturer of free flight model supplies so you can send the plug to my business here:
GizmoGeezer Products
45 Kirk Crescent
Saskatoon, SK  S7H 3B1
Canada
Ship it "USPS First Class Mail International". It is real easy to do but you will have to go to a Post Office. It should ship for around $5.00. Do not ship Priority International because the price will be over 20 bucks.
Declare it as a "returned hobby part" with a zero value otherwise it will trigger a sales tax charge on my end.
Orv.
  • AMA 931589
Re: FireBaby Build
« Reply #13 on: December 05, 2012, 03:15:31 PM »
Well its done #^. I't feels heavy the scales say 4.3 oz but it feels more like 18. Will soon see if it will pull itself off the ground.
 Rick
Rick Bollinger
AMA 931589
  • AMA 931589
Re: FireBaby Build
« Reply #14 on: December 05, 2012, 03:34:12 PM »
Oh I almost forgot. The stab hinge I almost ruined. Tried the red strip cloth like the orig. Used a strip off a bandanna. Grabbed the Sig bond that was just laying on the bench without thinking. Checked on it a couple hours later and discovered not a good choice. I have always used Ambroid for this and have 2 tubes. Luckily I was able to get it apart without damage. Just ironed on some mono.If it doesn't hold up I can go back to cloth with Ambroid.
Rick Bollinger
AMA 931589
Offline Mike Keville
Re: FireBaby Build
« Reply #15 on: December 05, 2012, 08:44:57 PM »
At the risk of sounding like Doc Holliday . . .
Nice job!
Re: FireBaby Build
« Reply #16 on: December 06, 2012, 08:31:03 AM »
I feel honored now Uncle Mikey. #^ #^
Offline Bill Smith
Re: FireBaby Build
« Reply #17 on: December 06, 2012, 09:20:34 AM »
really good job.
Offline Larry Renger
Re: FireBaby Build
« Reply #18 on: December 06, 2012, 09:38:40 AM »
All I can say is WOW!  I own a replica Firebaby, but yours is more authentic.  Umm, got line guide?
BTW how did you make a mold for the canopy out of water putty (I know what it is, just not the process to make a mold from it).
  • AMA 931589
Re: FireBaby Build
« Reply #19 on: December 06, 2012, 12:44:31 PM »
Thanks Everyone, I do have a line guide. Just did not have it on for the pictures. The canopy, I have the original. I just taped off the ends of the canopy. Used a light coat of oil on the inside. mixed up the water putty a little on the thin side and poured it in. I put 2 #10 bolts head down and clamped it between 2 epoxy sticks until dry. Clamped the plug in a vice and used a Diet Pepsi bottle. I did use a paint stripping heat gun. Its not a perfect canopy but it fits pretty well and is a canopy. (Thanks Doc.)
Rick Bollinger
AMA 931589
Re: FireBaby Build
« Reply #20 on: December 07, 2012, 10:56:17 PM »
Thanks!
Offline Will Davis
Re: FireBaby Build
« Reply #21 on: December 11, 2012, 05:49:09 PM »
Wow, looks better than the original I have, very good job on the reproduction
Will Davis
"Carolina Gang"
Re: FireBaby Build
« Reply #22 on: December 11, 2012, 06:30:45 PM »
FAR outshines the original I have here.  Nice job!
Offline Bootlegger
Re: FireBaby Build
« Reply #23 on: January 02, 2013, 12:13:42 PM »
  Can I get some info on the balloon tank, such as phisical size, fuel capacity, where to get them and most importantly, how long do they last??
    Thanks, and that is a good build...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: FireBaby Build
« Reply #24 on: January 02, 2013, 12:15:00 PM »
  OOPS,something else, how do you set them up??? y1
Gil Causey
AMA# 6964
Offline don Burke
Re: FireBaby Build
« Reply #25 on: January 02, 2013, 02:28:55 PM »
They need something on the airplane to keep them from flopping around.  The canopy on the Firebaby is for this.
I used to make them this way.
Get a small balloon, probably from a party store.  Then with either a piece of hard wall plastic tube or fuel line with a piece of brass tubing inside at a place just short of the balloon length, wrap a small rubber band or copper wire to seal the balloon to the the tubing.  Hook fuel line long enough to reach the engine.   Then with the airplane vertical, nose down, fill the tank with fuel until all the air is gone.  Important, don't stretch the balloon.  Pinch the line and hook up to the engine.  Atmospheric pressure provides the "push" along with suction from the engine.
Hope this was what you were looking for.
don Burke AMA 843
Menifee, CA
Offline Bootlegger
Re: FireBaby Build
« Reply #26 on: January 03, 2013, 12:52:20 PM »
  Thanks Don, I appreciate the help.
Gil Causey
AMA# 6964
Re: FireBaby Build
« Reply #27 on: January 28, 2013, 01:28:00 PM »
Beautiful, just gorgeous!!!! I have such a deep affection for the first FireBaby, my Dad taught me to fly CL on one with a Baby Spitfire (which I still have) He put me on his shoulders and my older brother launched for me, flew a couple aided flights and soloed the same day, I was 6. That was in 1956.
Offline Mike Lauerman
Re: FireBaby Build
« Reply #28 on: April 11, 2013, 06:28:03 PM »
The only real thing I felt I missed out on, the Firebaby. 1949, asked Dad for a Firebaby, they had a large stock at the LHS.
We had been ROG'ing A-J Hornets, but Dad was of the mind that "Gas Motor Planes" were of the O.K. Super .60 variety, period.
Every time I see the Christmas Story air, Darrin McGavern's voice rings out with Dad's squelch: "You'll CUT YER FINGER off!"
Sadly, he was killed before we ever got into I.C. power... Luckily, I was 'sponsored' by kind older friends that took my Monogram and Strombecker talents serious.
I did get a repro Firebaby from Frank Macy years later, in '82. One of my most memorable characters.
Offline Garf
    • Hangar Flying
Re: FireBaby Build
« Reply #29 on: October 16, 2013, 03:04:32 PM »
I have a few copies of the original plans if anyone is interested.
Offline dankar
Re: FireBaby Build
« Reply #30 on: March 30, 2014, 09:28:58 AM »
I built a Firebaby from scratch. Plus made extra kit also. I made my own graffics and not as nice as one posted but not bad. I got copies if templates for bi-version and made parts for such.  Just need to add top wing and good to go. I also made rubber band AJ Pursuit. Did graffics also. Used good colored markers from local craft shop.
Thanks Ty for copies of templates. You da man !!
Re: FireBaby Build
« Reply #31 on: April 14, 2014, 09:44:37 PM »
That is a beaut)))))))
Offline Robert Whitley
Re: FireBaby Build
« Reply #32 on: November 21, 2020, 07:27:29 PM »
I have an original in need of restoration.
Thanks for the ideas and inspiration.
I have the original OK Cub as well as a brand new commemorative on that I was able to get just before they quit the model aeroplane business.
Online John Rist
Re: FireBaby Build
« Reply #33 on: December 03, 2021, 10:25:10 AM »
For what it's worth Ebay has new FB motor mount.  https://www.ebay.com/itm/133904795537?hash=item1f2d590791:g:S4cAAOSw~~5haaz1
Offline eric greeson
Re: FireBaby Build
« Reply #34 on: December 17, 2022, 04:28:47 AM »
Very Nice reproduction , you put a lot of Fun into the model > have you flown it yet ( i know it winter here ) but some days 50 F ant bad  n~
Re: FireBaby Build
« Reply #35 on: December 17, 2022, 12:13:49 PM »
This is what is needed to get grandkids or even beginers started.   It was my first control line plane I tried to fly on 15 foot dacron lines.  I have found my original kit of the Scientific American Boy.   May ahve to go dig it out when done with present project. D>K
  • AMA 931589
Re: FireBaby Build
« Reply #36 on: June 03, 2023, 09:04:46 PM »
Eric sorry so long to reply. I haven't looked at this thread for awhile. I have not flown it. It turned out to be a hangar queen. I did run it though. It really was a fun project.
Rick Bollinger
AMA 931589
