  • June 30, 2025, 08:16:22 AM
Author Topic: Favorite airplanes...  (Read 3152 times)
Offline jim gilmore
« on: July 25, 2009, 10:26:22 AM »
I'm sure we all have at least 1 or 2 or move favorite airplanes. Maybe even 1 for each phase of aircraft history.
Here are some of mine and I'll try to post them in order of era/age.
Spad 17"the one with the whopie do's on the t/e of the wing"
p-26 PEASHOOTER
pt-19 Cornell
Supermarine Spitfiire mk1
p-61 black widow
f-4 phantom
Offline Robert McHam
Re: Favorite airplanes...
« Reply #1 on: July 25, 2009, 11:43:04 AM »
There some that come to mind quickly.
First would be the Lockheed P-38 Gotta build one of the Sterling Wee 38s one day~
P-40 Warhawk
P-51 mustang both B and D models
B-58 Hustler
DR-1 Triplane
Also the P-61
Must include the Beechcraft Staggerwing!
A pile of the golden age racers...
Robert
« Last Edit: July 25, 2009, 05:26:18 PM by Robert McHam »
Online Larry Renger
« Reply #2 on: July 25, 2009, 03:35:16 PM »
That's like asking which is your favorite child or grandchild!  It is the one I'm with!
Offline kenneth cook
« Reply #3 on: July 25, 2009, 06:31:07 PM »
        I built a  baby Tomahawk that was my all time favorite plane. I believe it was kitted by Dumas. This plane with a Black Widow flew like no other plane I ever owned. I wrecked that plane more times than I can remember. I always put it back together and the last time I set it up with a Dave Brown mount and a Tee Dee. It was real tricky getting the tank height correct. I finally settled on taking out half a rib and boxing it out and sheeting around the tank. I used a 1 oz. Perfect wedge which equally projected out top and bottom of the sheeting. The feed is coming directly through the leading edge. This plane has a real short nose with only about an 1 1/4 from leading edge to firewall. I was now able to use several engines. It flew terrific with an AME .061 plenty of power.  The other plane I truly enjoyed was the Brodak f-82. It was short lived but I sure had a lot of fun showing it off and flying. I accidentally one day rolled out the wrong set of lines which were .008 52' and was completely shocked that this plane still flew remarkably on them. Ken
Offline jim gilmore
« Reply #4 on: July 25, 2009, 07:50:37 PM »
And here I was think Plane.. Not models....silly me...
Offline George
  • Love people, Use things.
« Reply #5 on: July 27, 2009, 09:15:54 AM »
Full size, in no particular order ('cept the order in which I remembered them).
Supermarine Spitfire
Supermarine S6B - Schneider Racer
P51 - Mustang
F80 - Shooting Star
F4F - Wildcat
P6E - Hawk
F4U - Corsair
George
George Bain
AMA 23454
Online Larry Renger
« Reply #6 on: July 27, 2009, 12:16:36 PM »
Also in no order:
P-38, F-86, T-38, Mustang, Spitfire, Me-109, FW-190, Fokker Triplane, Corsair, Bell X-3 Stilletto, P-40, Shoenfeldt Firecracker
« Reply #7 on: July 27, 2009, 12:33:33 PM »
Say what you will, I can't say anything bad about the Little Tomahawk! Sweet little plane.
Robert
Offline Bill Heher
  • Fix-it
« Reply #8 on: July 28, 2009, 01:23:04 AM »
  Todays list- tomorrows may be different
  Nieuport 28 ( Hat in the Ring Sq- Cap'n Eddie R!!)
  Fokker D-8
  SE-5
  Gee Bees / Laird Super Solution
  Almost any Schnieder Cup racer
  Hurricane
  FW-190
  P-47
  Me-262 ( just looks so bad arse!)
  F-86
  Super Connie ( triple tails and corncob motors- gotta love it!)
  DH Beaver
  B-47
  B-58
  Thud  ( also the sound my model make too often )
  F-27  ( unless flying in one on a hot day)
  Beechcraft Starship
Models
The one I am going to build next!
Bill Heher
If it's broke Fix-it
Offline jim gilmore
« Reply #9 on: July 28, 2009, 03:10:25 AM »
"Say what you will, I can't say anything bad about the Little Tomahawk! Sweet little plane."
Sorry I justmeant  I was wondering about the full scale ones we all fell in love with growing up. HeckI remember having a little airplane on floats with a wind up prop when we went to a lake for vacation....
Offline Jeffrey Olijar
« Reply #10 on: August 28, 2009, 06:38:15 PM »
Curtis P-6 "Hawk"
Hawker Hurricane
Grumman Albatross
F-86 "Saber"
P3C "Orion" (I worked on them while I was in the Navy)
And Many more.
If it ain't broke, fix it till it is.
Offline dennis lipsett
« Reply #11 on: August 28, 2009, 10:44:32 PM »
P-40 Warhawk
B-58 Hustler
DR-1 Triplane
Also the P-61
Robert
Don't bother to build the Sterling offering of the P-38 , it is at best mediocre. I've had about 3 of them over the years and while it is fun to fly there isn't a lot to do with it .I built 2 within the last few years and the first one had 2 FP 15's, It was a bad move simply because it was so over powered that it was more rocket then plane. It also was not that maneuverable, Did loops and wingovers, inverted was not as good as upright, flights were about 4.5 minutes but as I said they were exciting.
Next I took the kit and trashed about everything. Replaced most of the wood with much lighter stock even to 1/32 ply doublers. Power was 2 OS10/fp's. I was so smart that I basically did the same thing with the lighter weight the 10's were more then enough . Incidentally I had 2 dead engine flights and can say definitely the model didn't care which one went dead, it continued along its merry way.  Incidentally 10's are extremly fuel efficient and flights were long enough to really get tired of it.
If you have to have one then build it light and use 2 Norvel 074's that would probably be just about right,
If you really want a great p-38 profile get Don Hutchinson's plans and have a blast with it. Two 40's whats not to like.
dennis
Offline Dennis Saydak
« Reply #12 on: August 30, 2009, 10:12:02 AM »
Yes Larry, and if you can't be with the one you love, love the one you're with ... as the saying goes  ;D
Offline George
« Reply #13 on: September 01, 2009, 07:56:06 AM »
...If you really want a great p-38 profile get Don Hutchinson's plans and have a blast with it. Two 40's whats not to like.
dennis
If you want a P-38 for stunt, how about Lew McFarland's version. It used two .19's if I remember correctly.
George
George Bain
AMA 23454
