  • August 02, 2025, 04:29:45 AM
Author Topic: Finally flew my Golden Hawk -- again  (Read 2117 times)
Offline Wayne Collier
« on: September 09, 2007, 08:07:03 PM »
The kit arrived on April 20, 2007.  The plane was finished June 15, 2007.  It made its first flight early yesterday morning September 8, 2007.
The airplane flew well.  It didn't seem super maneuverable but that could have been the pilot.  Round and round, up and down was no problem.  It did seem really fast.  On 35' lines it still seemed spin me around pretty fast.  It didn't seem to have any line tension problems so I may try 42' lines next time.  I only managed one loop and it wasn't real pretty.  The plane turned so wide that I was afraid to attempt a wing over for fear that I wouldn't be able to pull out in time on the way down. I may need to make some adjustments to improve turn rate.  Inverted wasn't successful because the engine would loose power.  I may need to adjust the fuel pickup.  I know I have some trim issues but all in all the plane did well for its fist time out.  The airplane seemed not to glide well.  When the engine quit it came on down.  I didn't make a single pretty landing, but at least I didn't destroy anything.  I broke my only Cox 5x3 prop on the first attempt.  I made several flights with a Master Airscrew 6x3. Hoping to get back at it soon.
« Last Edit: September 22, 2007, 05:27:14 PM by Wayne Collier »
Offline LARRY RICE
Re: Finally flew my Golden Hawk
« Reply #1 on: September 10, 2007, 12:04:04 AM »
No0one evers reads what I write. Landings are done like this: Engine quits...nose down to maintain air speed......pull out just above the ground.
Check you balance point, a little weight in the tail will make it very responcive.
Larry
Offline Robert McHam
« Reply #2 on: September 10, 2007, 03:42:23 PM »
I was also thinking that the CG may need changing to get a better response. I agree with Larry that hardly any of the hollow logs glide well though some admittedly do a little better than others.
I just got my Golden Hawk and man -o - man am I impressed with the quality of this kit!
Robert
« Reply #3 on: September 10, 2007, 10:20:48 PM »
      "Landings are done like this: Engine quits...nose down to maintain air speed......pull out just above the ground"
I actually understand the technique.  Lack of recent practice and lack of skill combined with flying over grass resulted in no pretty landings.  I was taking off from a patch of dirt.  The airplane climbed really easy.  I found myself holding a little down elevator to keep it flying level.  Currently the airplane balances about an inch behind the leading edge.  As I think about it, I wonder if I may have been over controlling -- moving the elevator so far up or down that it was acting like a brake. Maybe a slight bit of down thrust on the engine would help the trim.  I am pleased with the airplane and hope to get some good practice with it. I am hoping that I can give it another go this Saturday.  My fourteen year old is happy to help me launch but so far he has refused to give flying CL a try.  Maybe someday.  I works out though, he tags along doing things I like and I make it a point join him in some activities that he likes.
Offline LARRY RICE
« Reply #4 on: September 11, 2007, 07:36:19 AM »
WAY TO GO...POP!!!  #^
LARRY
Re: Finally flew my Golden Hawk -- again
« Reply #5 on: September 22, 2007, 05:22:55 PM »
Finally got to fly my Golden Hawk again.  This time I used 42' lines.  I liked it much better except the plane did get a little light on the lines once or twice up high.  Several loops today and some inverted flight.  Landings were a little better right up until the wheels hit the grass. I try stunts and occasionally crash so I appreciate the grass even if I have trouble landing on it.  My brother was in town so I let him fly it also.  His first CL flights in many years.  His first landing would have been perfect if not for the grass.  He didn't try any stunts but he did get dizzy.  We laughed about how when we were kids we could fly on 15' lines.
