  • August 02, 2025, 04:25:28 AM
Author Topic: Some more Bob Mathison builds  (Read 2510 times)
Offline Tom Perry
« on: February 25, 2008, 09:08:23 AM »
Bob asked me to put these picture up for him.
The blue one is a half a twister with a Big Mig .049.  The blue body yellow winged one is an Excalibur with a Big Mig .061.
The other one is my design with no name.  It is powered with a baby bee.
The last one is Molly the dog guarding the twister.   LL~
Bob chime in here if I missed anything.  :)
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Joey Mathison 9806
Re: Some more Bob Mathison builds
« Reply #1 on: February 25, 2008, 04:10:33 PM »
how long is the lines on the molly
200 mph man ama#9806 joey mathison
Offline Larry Renger
« Reply #2 on: February 25, 2008, 05:41:56 PM »
Those all look good.  What are the sizes and weights?  What line lengths do you intend to use?
The reed engine looks like a Texaco, not a Babe Bee.
Offline Tom Perry
« Reply #3 on: February 27, 2008, 04:32:39 PM »
Actually a Texaco Jr. tank on a Baby Bee.  Good eye thogh.    :)
At this point in time with all the mixing and matching one can never be sure.   LL~
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Robert Mathison
« Reply #4 on: February 28, 2008, 02:19:58 PM »
 Larry, the EXCALIBUR 1/2A,
  WING IS 33"
  THE WEIGHT IS 13.9 OZ
   THE LINE LENGHT IS 52'
    THE ENGINE IS A BIG MIG .061
   THE TWISTER
   THE WEIGHT IS 10.4 OZ AND THE WING IS 29''
  THE LINE LENGTH IS 52;
  THE ENGINE IS A BIG MIG .049
  TOM'S DESINE
  THE WEIGH  7.25 OZ
  THE WING IS 261/2"
  THE LINE LENGTH  35" TO 40" WITH A COX .049
                      BOB
Offline Tom Perry
« Reply #5 on: February 29, 2008, 09:55:08 AM »
Not sure of length or diameter but am pretty sure its a monoline.   LL~ LL~ LL~
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #6 on: February 29, 2008, 05:37:16 PM »
yes that sounds like my dad he always did very well with one line
« Reply #7 on: March 01, 2008, 05:37:51 AM »
 JOEY,  DID YOU EVER RUN THAT  AME .049 I SENT YOU?  I JUST FOUND [3] MORE  NIB .049'S SO LET ME KNOW.
                      DAD
« Reply #8 on: March 01, 2008, 07:00:40 AM »
i have been trying to use it on a foam wing combat plane and it is not giving good engine runs always goes lean after about 30 seconds i will continue to play with prop and fuel combos untill i make it happy.
« Reply #9 on: March 01, 2008, 08:22:46 AM »
 JOEY, YOU SHOULD TRY A SMALL BLATER TANK, JUST A SLIGHT PRESSURE . YOU COULD TRY A BALLOON TANK AND IT SHOULD RUN OK.       DAD
« Reply #10 on: March 01, 2008, 01:07:20 PM »
dad the foam winged combat plane is using a bladder tank
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #11 on: March 01, 2008, 03:56:30 PM »
I have found a common problem with Norvels of most any stripe--crankshaft fit is a little too tight.  As it heats up (that first 30 sec.) it gets tighter; your engine is not going lean, it's binding up.  I actually had one seize in the air; turned OK after it cooled down.  I tore several of mine down and lapped the shafts in with toothpaste and an electric drill. Seems to solve the problem, at least so far. Time will tell if I've shortened their lives any.
--Ray
--Ray
AMA902472
« Reply #12 on: March 01, 2008, 08:08:06 PM »
thanks ray i will give that a shot
