  • August 01, 2025, 05:11:02 AM
Author Topic: Best Wing Construction for 1/2a  (Read 4233 times)
« on: January 11, 2020, 03:37:13 PM »
blank
« Last Edit: August 17, 2021, 01:37:54 PM by Motorman »
Offline 944_Jim
Re: Best Wing Construction for 1/2a
« Reply #1 on: January 11, 2020, 10:59:36 PM »
MM,
No real input from me, but I'm dying to know where you are going with this. That is a big wing for a little engine.
You may want to look at the wing construction of the Pinto. I think it is almost as big as what you are proposing. Also look back several months here. There was a really sweet ME-109 (or was it the FW-190?) done almost as big. I think it was the guy that did a balsa clone of Cox plastic Spitfire, and the Clone Top Flite Bearcat.
« Reply #2 on: January 12, 2020, 12:59:47 AM »
MM,
In your previous thread where you asked about largest wing areas, I referred to a my largest 1/2A stunter, which I call the Spring Break Special, because that is when I built it during college. It has 201 in^2, with a 6-5/8" root, 6" tip and uses a solid LE and TE, no planking, 1/16" ribs spaced nominally on 2" centers. The covering sag is not that much, and it saved a ton of complexity and work. As you can imagine, I was in a hurry with only a week off.
On the other hand, I have an OPP (Other People's Plane) awaiting completion that is a bit smaller, but is basically constructed just like a Nobler wing, except the main gear is in the wing. The ribs are 1/32", as are the cap strips, the LE planking, and the upper and lower TE sheeting. The spars are 1/8" square. The ribs are spaced at 1" centers. It is not covered yet, so I don't know what the covering might do to it (Starved Horse) but it has no noticeable ripples in the finished planking. Tissue would not be a problem, but polyspan and dope might be. I believe you said you were not a fan of the Baby Pathfinder, so a "Mini-Nobler" would probably not be a fun exercise, either. But these wood sizes are suitable if you can work with something more fragile. I don't have a weight comparison with the Spring Break Special, so can't help there. But I'm sure the SBS survived a couple of crashes over grass while other guys tried it out, whereas the Baby Nobler construction might not.
Hope you keep chugging on this project. Will be interesting to see how it turns out....
« Reply #3 on: January 27, 2020, 11:06:00 PM »
What would you consider the easiest most effective construction for a 250 sq. in. 1/2a wing. They say foam is too heavy and warren truss requires all kinds of foam cradles and bucks, lots of work. That leaves straight ribs so the question is leading edge sheeting or lots of 1/2 ribs. I'd like to do leading edge sheeting but do you think 1/32" balsa is thick enough for 1-1/2" rib spacing?
   I built several 1/2As that size that were foam-cored and sheeted with 1/32 balsa. It's not too heavy.
Offline Fredvon4
  • Central Texas
« Reply #4 on: February 04, 2020, 12:53:02 PM »
many of the very capable winning 1/2a fast combat wings are solid foam....Core house Phil Cartier cuts good wings...
harder to get Jeff Dawson makes n sell some awesome sonic chicken and other variants
motorman pm me an address I will send a selection of both foam cores.....gratis....collecting dust here
Fred von Gortler IV
Offline ray copeland
« Reply #5 on: April 01, 2021, 02:23:07 PM »
What is the total weight with engine , wheels and tank. I am using Sig Akromaster plans for my next 1/2a, trying to keep it around 10 ounces. n~
Offline Phil J
« Reply #6 on: May 20, 2021, 04:07:41 PM »
I prefer to build I-Beam wings  Here is a picture of a 1/2A Stiletto I'm working on completing current weight 7.5 oz.
Offline kevin king
« Reply #7 on: May 25, 2021, 06:39:19 PM »
Nice job on the Thundergazer too Motorman 👍
