  • July 07, 2025, 03:39:41 AM
Author Topic: Design parameters for a .010 powered profile stunter  (Read 1522 times)
« on: December 14, 2011, 06:28:21 AM »
Hi All,
As the title says, a .010 powered profile stunter.  I am thinking along the lines of the Goldberg Goodyear profiles suitably reduced in size.  I believe the profile fuselage will be a bit better for handling instead of a full fuselage ship.  Others are under speculation, but I need to know some some parameters, target weight, etc.  Might be a case of some of that super expensive 3 lb wood from Campbells! LOL!!
Big Bear
Offline Larry Renger
Re: Design parameters for a .010 powered profile stunter
« Reply #1 on: December 14, 2011, 10:25:45 AM »
I would hazard a guess that about 80 sq. in. and 3 ounce weight would be good.  I had a 1/2A Snapper at 4 ounces and 105 sq.in. with the .020 and it was indeed "snappy".  Look up Randy Heydon's Lil Bit, as it was competition capable.
« Reply #2 on: December 14, 2011, 10:28:27 AM »
Thanks, Larry!
Big Bear
Offline Jim Thomerson
« Reply #3 on: December 14, 2011, 01:57:52 PM »
I built a profile with, probably, a 12 x 3, 1/8 sheet wing.  I made the bellcrank out of a plastic picnic knife. I flew it on thread lines, about 12 ft.  It would loop and do figure 8's. I later put a PeeWee 020 on it and flew on a little longer lines.
« Reply #4 on: December 15, 2011, 07:36:40 PM »
  I would guess that you probably don't need to bother with a prop, or actually starting the engine. These teeny-weenies are easy to just whip up to speed.
« Reply #5 on: December 15, 2011, 11:47:09 PM »
But .010's serve a purpose!  Mosquitos are attracted to the sound and stick to the oil! (REALLY!!!) They provide a vital service to mankind!  And to think of the millions of $ that have been spent on mosquito eradication research when such a simple solution is available!   %^@
Offline pat king
    • PDK LLC
« Reply #6 on: December 17, 2011, 11:47:29 AM »
Here is a Micro Ringmaster Stunter for the Cox .010 engine. It has a built-up wing with a 17 1/4" wingspan and 53.5 square inches of wing area. That is 56% of the wing area of a Baby Ringmaster. It is not Larry's recommended 80 square inches, but I think the size and wing area are OK. My Micro Ringmaster is a 1/4 scale Ringmaster with a slab wing. It has 23.8 square inches of wing area. it will not really stunt, it is more of a rocket than a stunt airplane. Let me know what you think.
Thanks, Pat
Pat King
Monee, IL
AMA 168941
« Reply #7 on: December 17, 2011, 03:57:16 PM »
Looks like fun to me!  ;D  I hope someone builds one and lets us know how it goes!  It certainly will fly!
« Reply #8 on: December 17, 2011, 05:28:27 PM »
Brother Pat!
That makes me want to consider a Micro Super Ringmaster Stunter! ;D
(a Micro Ringmaster Imperial Stunter would be the bomb! )
