  • August 01, 2025, 08:15:50 PM
Author Topic: fliteline "lil bomb"1/2A c/l  (Read 4881 times)
Offline rudi de causmaecker
« on: May 28, 2012, 02:57:41 AM »
Good morning,
Is there someone here who recalls the "lil bomb" from fliteline?
It was a c/l 1/2A flying wing constructed from a massive plank of balsa..
I'm trying to find a drawing with some dimensions on it,to construct one myself;I'm going to teach my kids how to fly c/l
and those "flying wings"are nearly indestructible!!
Greetings,
Rudi. H^^
Offline Larry Renger
Re: fliteline "lil bomb"1/2A c/l
« Reply #1 on: May 28, 2012, 08:53:02 AM »
Minnesotamodeler (Ray Stone) makes something like that as a kit.
Offline riley wooten
« Reply #2 on: May 30, 2012, 07:18:43 PM »
Lil Bomb - 18" wingspan      Root cord - 6"      Tip cord - 5"      Root cord was same 6" for about 4" in center  The pieces cut
from wing made fins and as I remember the so called booms were 3/4" square of same thickness as wing... The stab was
about 1-1/2" x 6". There was a 3/32" x 2" x 6" doubler running from l.e. to t.e. in center of wing.  Can not believe that we
sold them retail at $.99 in 1964 but we sold a lot of them.   They would be better if you added tips to extend span to 20" to
24"
« Reply #3 on: May 31, 2012, 11:12:37 AM »
Hi Riley,
This is very helpful,thank you very mutch H^^
I think it will be a very fun machine to fly,would a black widow be a good choice,or would it be wiser to go with let's say a medallion perhaps?
It will be used for training purposes mainly(the goal is to learn the kids how to fly c/l)... y1
Thanks again!!
Rudi.
« Reply #4 on: May 31, 2012, 12:29:22 PM »
They were designed around the Cox Babe bee, Golden Bee, Blk Widow series engines, but any 1/2A would work..
rw
« Reply #5 on: May 31, 2012, 01:48:47 PM »
There's one more thing i need to know,Riley...
How about the balance point?
Maybe on the leading edge?
Were there leading edge fortifications of some sort?
Rudi.
« Reply #6 on: May 31, 2012, 02:59:19 PM »
Rudi.
It was very simple sheet balsa construction (one sheet of 3" x 36" for wing)  Remember, it was designed to
sell in a plastic bag for a buck.  CG from 15 to 20% of cord.... Forward for trainer - back to stunt....
rw
« Reply #7 on: June 01, 2012, 03:30:13 AM »
I've just found a picture of a Lil bomb-does this one look original to you Riley?
If so,then it will be of great help to build one myself to your spec's..
Rudi  #^
I hope the picture comes thru this time!
« Reply #8 on: June 01, 2012, 10:52:03 AM »
Rudi  #^
It has been a long time but I think it is very close...If not original it is a close copy! Good luck with your project..............
rw
Tags: lil bomb fliteline 1/2A c/l
