  • August 04, 2025, 03:08:32 AM
Author Topic: Sky Streak #1 at the Knights' Joust!  (Read 1103 times)
Offline Larry Renger
« on: June 27, 2011, 05:27:22 AM »
Also, it happens, #2 and #3 as Warren Walker busted his plane in the first round and Al Shorey wanted to fly.  So I loaned the plane out to both of them, then beat them with it!   VD~ #^ ~>
Several top flyers were very complimentary after seeing how the model flies.  I certainly am happy with it!
I think that just a touch less nose weight and 2' shorter lines will improve it still more!
Re: Sky Streak #1 at the Knights' Joust!
« Reply #1 on: August 15, 2011, 10:12:50 AM »
Sky Streak strikes again!
I took 2nd and Scott Dinger took 3rd in 1cc Aerobatics at the Valley Circle Burners "Hot August" stunt meet.  John Wight took 1st with a conventional model.  (He could fly a hollow log model and win!)
Everyone who has flown the model or seen it fly is very favorable, even a couple that said "That can't work!" before seeing it fly.   VD~
« Reply #2 on: August 16, 2011, 09:23:23 AM »
Great news.   Now you need to reverse John's lines sometime. H^^
