  • August 01, 2025, 08:21:48 PM
Author Topic: cox reed  (Read 1690 times)
Offline bob whitney
cox reed
« on: November 13, 2018, 12:34:00 PM »
owhat is a good RPM target for a cox Reedy on 10% nitro
rad racer
Online Steve Berry
Re: cox reed
« Reply #1 on: November 13, 2018, 12:53:29 PM »
Depends on which one it is.
Baby Bee might get to 13,000.
Black Widow can get to around 17,000.
The Venom & Killer Bee can get upwards of 20,000.
It mostly depends on reed material & age/wear, cylinder (porting & such), glow head (high compression vs regular), head gaskets, temperature of the air, humidity, phase of the moon, and whether or not you've saved 15% by switching to GEICO.
Sorry it's not more specific. I'm going to guess you're talking more about a Baby Bee or product engine, where the top end may be around 12,500 or 13,000. Larry should be able to give a better answer.
Re: cox reed
« Reply #2 on: November 13, 2018, 05:50:47 PM »
interesting question. I can't remember trying one (on purpose) on 10% fuel.  Unless maybe it was a Mouse II?  You might want to play with the head shims a bit to get back what you are giving away. I suspect it will be touchy.  Are you doing this to pick up some mileage on a stunt setup?
Divot McSlow
Offline bob whitney
Re: cox reed
« Reply #3 on: November 13, 2018, 06:18:35 PM »
just getting some break in time on it
rad racer
Re: cox reed
« Reply #4 on: November 13, 2018, 09:45:49 PM »
Gotcha. But if you just up the nitro later, it may still be tight.
Offline Larry Renger
Re: cox reed
« Reply #5 on: November 14, 2018, 07:36:47 AM »
What prop are you using?
