  • June 17, 2025, 01:05:31 AM
Author Topic: @@@xxxx!!!!!  (Read 5515 times)
Offline Ken Burdick
@@@xxxx!!!!!
« on: November 08, 2015, 04:01:45 PM »
So excited over the lil jumping bean, that I found the templates I had made for the Wee Duper Zilch.
Things have ben going pretty ok so far and then I decided to use some nice ff wood, that was between 1/16 and 1/32  for ribs and T.E. well.....It's hard when you are all thumbs but the wing was looking pretty ok too. I was holding the T.E and butting a "small drop" of thin CA onto the edge of the wingtip piece to the T.E. ......glued my thumb and index finger to the T.E. and oh so thin rib......NOW LOOK WHAT'S HAPPENED! repairs to be initiated later. HB~>
Offline Chancey Chorney
Re: @@@xxxx!!!!!
« Reply #1 on: November 08, 2015, 05:34:29 PM »
That sucks. Been there before, gluing oneself to the aircraft. Albeit, better than gluing yourself to, yourself....
Re: @@@xxxx!!!!!
« Reply #2 on: November 08, 2015, 06:40:28 PM »
Ken,
It's not a true aircraft until you have a) glued yourself to the airframe, thus becoming truly one with your plane, and 2) cut yourself and bled on the airframe, making a suitable sacrifice to the airplane gods...
Mark
  • Gravitywell
Re: @@@xxxx!!!!!
« Reply #3 on: November 09, 2015, 04:25:39 PM »
I once glued my thumb to the building board, then my other finger to that thumb.  Then cut myself trying to get both apart....does that count? n~
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Dane Martin
  • heli pilot BHOR
Re: @@@xxxx!!!!!
« Reply #4 on: November 09, 2015, 05:01:35 PM »
that's actually pretty impressive. I would have to say that that counts!
Offline Ken Burdick
Re: @@@xxxx!!!!!
« Reply #5 on: November 11, 2015, 04:13:33 PM »
Rule # 1.....never-EVER build anything out of 1/32 ff balsa.
first pix before, 2nd is after.......
Offline Ken Burdick
Re: @@@xxxx!!!!!
« Reply #6 on: November 11, 2015, 04:17:29 PM »
looks like the 1st pix didn't go....just looks like a wing except for the warpanage in the TE from adding the cap strips. You might say I was surprised when I got through and looked at the trailing edge. When I fly it....might looks like one of Wilks cartoons of me running and it chasin.
K
Offline Ken Burdick
Re: @@@xxxx!!!!!
« Reply #7 on: December 07, 2015, 11:03:52 AM »
I added some angular spars and then straightened the warp. Covered it with tissue and then dope. Once the wing was nice and stiff from all that, put on the covering so I could actually work on the rest of the model without breaking ribs etc. It began as a 1/2A but then the engine somehow turned into an Enya .09. If that is under powered, I have a green head .15 that will also fit.
The wing has d-tube sheeting and cap strips. A fun project that I've been 'gonna do" for a few years.
K
Offline Dane Martin
  • heli pilot BHOR
Re: @@@xxxx!!!!!
« Reply #8 on: December 07, 2015, 01:14:21 PM »
Darn you Ken! Now i need to build one!
Looking sweet man
Offline Ken Burdick
Re: @@@xxxx!!!!!
« Reply #9 on: December 07, 2015, 03:01:38 PM »
buldright sells the kit which must be 30 or 40m times easier than building mine.
Offline Ken Burdick
Re: @@@xxxx!!!!!
« Reply #10 on: December 16, 2015, 10:26:13 AM »
The latest on my 1/2-a we tethered zilch-drone. I've looked and looked but cannot find a battery hatch to put "secret code"
Offline okcub2015
Re: @@@xxxx!!!!!
« Reply #11 on: December 16, 2015, 12:27:14 PM »
At my age, i was born in 1942 BC, i have four thumbs and numerous index fingers all of which seem to get glued together. I curse
and swear bit it does no good.
Bruce
Offline Fredvon4
  • Central Texas
Re: @@@xxxx!!!!!
« Reply #12 on: December 16, 2015, 01:29:16 PM »
Hummm...Boris
seems to me battery hatch to put "secret code" was but one suggestion describing an area that is easily accessible
there be some others you might consider easily accessible with no tools
What THEY said:
Methods to display aircraft identification: To ensure that the small unmanned aircraft can
be identified, the FAA will require that the unique identifier must be maintained in a condition
that is legible. The unique identifier must be affixed to the small unmanned aircraft by any
means necessary to ensure that it will remain affixed to the aircraft during routine handling and
all operating conditions.
For small unmanned aircraft registered under this part, the FAA does not specify a
particular surface upon which the unique identifier must be placed. Rather, recognizing
commenters’ concern about the small size of many of the small unmanned aircraft that must be
registered, the FAA simply requires that the unique identifier must be readily accessible and
visible upon inspection of the small unmanned aircraft.
In accordance with Task Force recommendations, a unique identifier is deemed readily
accessible if it can be accessed without the use of any tools (e.g., battery compartment). This
flexibility is expected to resolve the concerns of the television and motion picture industry and
preserve the authenticity of a replica if so desired, given that the unique identifier need not be
displayed on the exterior of the small unmanned aircraft.
Note please that Legible does not specify at what magnification...grin...
I think a micro dot anywhere on the exterior may satisfy brother Boris's need for stealth
Fred von Gortler IV
