  • July 12, 2025, 04:44:52 PM
Author Topic: cox engine question...  (Read 1412 times)
Offline jim gilmore
« on: July 21, 2013, 03:27:52 PM »
Wiith the standard 8cc thank on a golden bee how long will the engine run for on a full tank ?
and does changing the fuel mix change the run time ?
Offline david beazley
Re: cox engine question...
« Reply #1 on: July 21, 2013, 03:38:50 PM »
Jim, I'll start by saying I'm no expert on reedie engines but there are a variables to run times.  RPM, prop, fuel, compression, all effect run times.  Nitro content will have a big effect and changing one or more of the above will change run times.
AMA # 2817
Offline jim gilmore
« Reply #2 on: July 21, 2013, 03:41:30 PM »
So the next question is would it be able to run a full ama pattern with one ?
« Reply #3 on: July 21, 2013, 04:11:30 PM »
No, 8cc, full out screaming will probably get you 2-3 minutes, depending on the prop and compression as Jim said. Even less if you have a bored venturi and a dual bypass cylinder. More if you throttle it. But that 8cc built on tank will suck air in your loops and overheads way before you're finished. When I do stunts with those, I do all of them early in the flight. But I'm just a sport flyer so it doesn't matter what order I do them in.
Offline Larry Renger
« Reply #4 on: July 21, 2013, 09:01:32 PM »
Using a Kavan tank extender, small venturi and short lines, it is just barely possible to do a whole pattern, but it isn't worth the effort. I was trying to milk my way through for flying my "Tech Terror" at VSC. I couldn't manage it with adequate reliability using every trick I could think of.
Go with an external tank.
« Reply #5 on: July 22, 2013, 09:08:19 AM »
I believe Cox made the tanks for the sport flyer who was not worried about competition.   The competition engines were the TeeDee and Medallions.
« Reply #6 on: July 22, 2013, 09:18:39 AM »
Yep, once you go Tee Dee, you'll never go back. I fly them on pressure bladders, it makes a wonderful easy and reliable combination. I just hang the bladder under the wing(and sometimes over) in a sexy black fishnet sack anchored to the rear fuse with a string.
