  • July 27, 2025, 04:18:40 AM
Author Topic: Cox Blue Bullet?  (Read 2036 times)
Offline Jay
  • 1 Cross +3 Nails= 4 Given
Cox Blue Bullet?
« on: October 20, 2012, 06:56:49 AM »
Become a fan of Cox on facebook.  This is what I seen.
A sneak peek at our newest Limited Edition Engine going on sale soon....but we need your help. We are choosing a name and have narrowed it down to Blue Flame or Blue Bullet....let us know what you think.
COX International To answer any questions about the engine size and specs (and like the "Xtreme" will be a numbered run of 100 only)
Cox .049 engine
High-performance glow head conversion w/ blue “Extra Cooling” head
High performance “Tee Dee” cylinder
High performance "Venom" crankshaft
Enlarged backplate venturi hole
Blue 8cc aluminium stunt tank
Blue anodized crankcase
Blue anodized drive-plate
Blue aluminium spinner
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
Re: Cox Blue Bullet?
« Reply #1 on: October 20, 2012, 10:38:45 AM »
Price?
RPM?
Offline kenneth cook
« Reply #2 on: October 20, 2012, 08:12:29 PM »
               When you check the engines available from Xenalook, they're pretty close in regards to rpm's. This is pretty much due to being basically Sure Start piston cylinders. These aren't Tee Dee pistons and cylinders but modified Sure Starts that have had the slits removed. Currently, the "Extreme" engine appears to be the same but in red which is listed at $89 US dollars.  The rpm's claimed for the Extreme  engines seems to be quite vague as it just states 18k-20k on a 5x3 and 25% nitro. Ken
« Reply #3 on: October 20, 2012, 08:48:56 PM »
Thanks.  I haven't had much success with Cox quality in the past few decades.  I bought a batch of Sure Starts and didn't get much satisfaction.  I'm afraid Mr. Cox's personal touch is the missing link.  Maybe somebody will buy a Blue Bullet and restore my faith.
Offline Andrew Tinsley
« Reply #4 on: October 26, 2012, 10:35:26 AM »
I am grateful to Cox for the ability to get basic spares for the Cox range. I am less than enthusiastic about the wide range of engines they assemble. They are all much of a muchness as far as I am concerned. I would much rather see some of the out of stock spares being manufactured. Real TD pistons and cylinders (all sizes) would be snapped up by the boxful. But I suppose the degree of precision required would be difficult to achieve unless hand fitted. The precision machinery is no more! Maybe some of the Eastern European manufacturers would be interessted?
 Sounds like I am a miserable old so and so for being ungrateful, however I do applaud the Cox operation, just not the bling engines that are mostly the same under the skin!
Andrew.
P.S. In my experience it needs some skill and knowledge to keep Cox engines running well. If you can't assemble a Cox  0.49 yourself, then maybe you should look at other 1/2A engines?
BMFA Number 64862
Offline Ron Cribbs
« Reply #5 on: October 30, 2012, 04:20:58 PM »
While I usually stick to older Cox engines myself I can say that these new Cox engines are made with cylinders that are ported the same as the late #4 TD cylinders and have an adequate SPI gap. That 5 fin head seen in the pic really bumps the compression too. I have one and had to add 3 shims to get it to run.
The reason Bernie (Cox International) can't give accurate RPM figures is every engine runs different so he just advertises an RPM band. I also know Bernie does indeed test run engines from his product line. I have also seen video of the "extreme" being test run and it turned over 19K easily.
Lastly, if the blue doesn't suit you just call CI up and tell him what you want color wise.
Hope that helps some.
Ron
Offline Larry Renger
« Reply #6 on: October 30, 2012, 11:47:54 PM »
Last year at the "Hollow Log Drag Race" my Stock Venom with an APC 4.5x4 prop on Aeordyne 65% Nitro, held together at around 25K, and from a standing start averaged 66.6 mph on30' lines.  I was one wiped out puppy at the end of the flight.  Not actually dizzy, but my feet would no longer keep up the pace.  1.9 second laps for 2 minutes are NOT NICE!!!   ~^
This year we are limiting the fuel to club provided 30% and 42'x.012 cable lines.  That should keep the fastest stuff in the 3+ second range.
« Reply #7 on: October 31, 2012, 03:53:31 AM »
Hello Ron,
The point is I don't want ANY fancy colours. It doesn't make the engines go any better! As for your comments about them having Cox TD style porting, well you may be technically correct. but TD pistons and cylinders they most definitely are NOT! They are simply Surestart parts with the bar between the slits machined out. There is no ground taper on the cylinder which is the real difference. As for spi, the piston skirt is simply machined off to suit. This combination gives a power boost, but they do NOT go anywhere near as well as a proper TD piston and cylinder. As for the 5 fin head, well many of us have been running the Galbreath head and Nelson plugs for a year or two now. These give a CR boost and the volume of the Nelson plug is so small that you don't get the usual drop in performance. This combo is still used for National free Flight Association competitions, I believe. I think that should tell you how good it is. Oh and by the way, I have yet to burn out a Nelson plug.
  I am very grateful to CI for providing Cox parts, I have spent a good few hundred dollars with them on buying bits and pieces to keep my fleet of Cox engines going! However their range of "New" engines holds zero attraction for me as they are both relatively expensive and they don't really go as well as a true TD based reedy.
Andrew.
BMFA Number 64862
Offline Wayne Collier
« Reply #8 on: November 03, 2012, 02:06:12 PM »
No clue what a "true TD based reedy" is.  If you mean a TD cylinder and piston on a reedy case, then any cylinder that physically matches the porting and SPI of the TD aught to do ok. Careful fit is important. As to color - if the performance is similar either way, what could it hurt?  I've got a plane grey OS .25, but always thought the blue ones looked good.  Personally, I may not pay extra for color, but I can't see a down side to it if someone likes it and can afford it.
« Reply #9 on: November 03, 2012, 05:05:36 PM »
Wayne,
I am just speaking for myself, I don't much rate the CI range of engines. If other people want to buy them, that is fine by me! It helps CI's profitability and that is a GOOD thing, because I can keep buying spares from them. So no quarrel with anyone, go right ahead and buy as many engines as you want, there isn't a downside to it, as far as I am concerned!
As to the "TD cylinders" on offer from CI, they fulfill all specs of a real TD Cylinder, EXCEPT it has no cylinder bore taper. This being so, they won't make as many rpm as the real thing. The taper is part of the performance increase. Tach a real TD cylinder on a reedy and then replace it with a CI TD cylinder, tach it again and you will have lost rpm! If you don't have any real TD pistons and cylinders then the CI version is better than none. I am lucky as I have a store of TD spares including p/cylinders, which I purchased many years ago. If I didn't have them, then I would buy the CI version, unfortunately they don't deliver the rpm of a real taper ground TD setup. Having said that you will be operating in a region where a reedy is getting close to self destruct! But if you want ultimate reedy performance then you will need a real TD P/ cylinder combo.
I am a fan of CI, must have spent a good few hundred dollars with them. Their service is absolutely outstanding. The only time I had a slight problem with a certain item, they responded at once and sorted it out. Their offering of "TD p/cylinders", is an excellent example of them trying to fill a need in the market. The fact that it will not run as well as a real TD cylinder, is not their fault. They have done the best they can with the means available to them
Andrew.
BMFA Number 64862
