  • July 07, 2025, 06:07:01 AM
Author Topic: Cox baby bee 049  (Read 2023 times)
Offline Bootlegger
Cox baby bee 049
« on: December 11, 2020, 04:46:20 PM »
 I am puttin one together, and it has a plastic back plate, and only one fill/vent place for fueling it up, where does it vent?  Obliged for y'all's help...          H^^    :! n~
8th Air Force Veteran
Gil Causey
AMA# 6964
Online 944_Jim
Re: Cox baby bee 049
« Reply #1 on: December 11, 2020, 05:22:57 PM »
I know the metal ones with only one nipple had a hole on the opposite side of the needle valve.
Offline Wayne Collier
« Reply #2 on: December 11, 2020, 05:30:20 PM »
There should be a small hole near the needle valve.
Offline Larry Renger
« Reply #3 on: December 12, 2020, 08:52:24 AM »
Actually, there is a small hole next to the nipple. That is so the overflow can not “squirt”. It will be blocked by the end of the filling hose.
« Reply #4 on: December 18, 2020, 11:41:51 PM »
The hole can be hard to see on the black plastic backplates. I came out to the field on day and saw a couple of guys trying to fly a Cox-powered Something-Or-Other. They were going thru an awful lot of gyrations while prepping it to fly, so I went over to see if they needed anything. No, they were fine, just fueling up. Turns out, they remembered the old "Two-Nipple" metal backplates and thought this plastic one was defective. So they were pulling the needle valve out each time in order to let the fuel in.....
The Divot
« Reply #5 on: December 19, 2020, 07:19:27 PM »
Hoo boy, flood city!
I remember my boss, Bill Selzer, recounting a tale of seeing a dad and kid trying to start a Cox engine. The dad would hook up the battery, pull off the clip then start madly flipping the prop. Oddly enough, it wasn’t working well.  LL~
« Reply #6 on: December 19, 2020, 10:00:28 PM »
That seems odd, Larry. I have a ST C.35 that uses that exact technique and it has started every time I tried it. Hmmm
I was test flying a rebuilt MouseMotor two weeks ago. It had a Golden Bee tank and a Baby Bee backplate. We ran short on laps but we left a nice contrail as the fuel siphoned out of all those vents....
The Divot
