Building Tips and technical articles. => 1/2 A building. => Topic started by: Bootlegger on September 01, 2021, 07:29:59 AM
Title: Cox 09 Medallion
Post by: Bootlegger on September 01, 2021, 07:29:59 AM
  Guy's who can tell me he venturi size of the Cox medallion size as the one I have has a spray bar thru it..  Much obliged.      H^^ y1 #^
Title: Re: Cox 09 Medallion
Post by: Dan McEntee on September 01, 2021, 10:25:04 AM
  Take the spray bar out and measure it with your dial calipers. You may be able to sneak the points of the caliper jaws in and around the spray bar as it is. You can also insert the shank of a number, letter or fractional drill into the throat and then measure that with a micrometer.
Post by: Bootlegger on September 01, 2021, 12:10:46 PM
  Thanks Dan, That makes me obliged to you, again thanks..
