CLICK HERE--><--CLICK HERE
Cox .049's: Please School Me
Started by Andre Ming, October 07, 2023, 04:55:06 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
944_Jim
#25
Mr. Dan,
It's funny you posted the Lil Satan link. I did those pattern tracings decades ago. I don't know who I scanned them to, but they attributed the scans back to me.
The one on my CEF avatar is actually a scratch-build one from Flying-Lines.org's Widow Satan.
Something I never validated but always suspected...the Combat Kitten wing looks a lot like a Baby Flight Streak wing. Get the baby flight streak pattern and you should have the parts for the Kitten.
Andre, either of the combat models with be pretty tough birds. Finding a plane with a bit of room between the wing and stab will leave you with a slightly smoother, less twitchy flier.
Mark has a point. There is no real advantage to winding up one of these little engines for all it's worth. Faster running engines drink fuel faster. They break faster too.
John Skukalek
Where does the Venom stack up with the Black Widow and Golden Bee in terms of power?
Quote from: John Skukalek on December 06, 2023, 04:29:23 PM
     If you have both in stock form, just start them up on the same fuel and prop and listen!! I debuted mine at our club's Golden Age Races many years ago. I sat on the ground getting the model ready and things prepared while others were doing the same thing and a few flights were put in, and then when I started it up and everyone stopped what they were doing and looked my way!!  it's definitely a step up from a Black Widow. Larry Renger has stated here a few times on how to build your own Venom using standard Cox parts. If you do some of the standard fit and maintenance things in Paul's performance tips with out drilling anything, you will still have a better engine. That's the neat thing about messing with these things, you don't need to be a machinist or own a machine shop in order to have a better running engine. You just need to pay attention to details and put those in the correct order.
   It's really the same with ANY engine.
Andre Ming
Quote from: Dave Moritz on December 06, 2023, 10:28:32 AM
Andre
If I may prevail upon you for advice. I'd like to lay my hands on the plans for your combat trainer pictured above. I have a fledgling flyer and builder under wing and that model would be perfect for him.
Thanks.
Dave Mo...
Dave M:
Is this the combat/stunt trainer of which you speak? If so, then here's the same photo w/dimensions...
Mark Mc
Andre, thanks for the photo with the dimensions.  I don't need another plane at the moment.  Especially a plank wing which I have sworn off.  I have too many already.  But looking at your plane, it gives me a couple of new ideas for building such a plane that would save me a lot of build time.  I may just build one if I have a free afternoon and the will to set aside other projects.
Mark
Dave Moritz
Dan and Andre:
You both came through in flying colors! Thanks. The young guy I've in mind for the ship will be able to plow it into terra firma and then still come back for more.
Dave...
" In a world of ready-made fiction, truth requires work."
D. Andersson
kenneth cook
              John, there's a lot of differences between the Black Widow and the Golden Bee. It also depends on the years each one was made. The early Golden Bee with the black drive washer typically used a #2 cylinder which is a single port like a Babe Bee. However, the early style also came equipped with a thin wall cylinder. I've always found this style cylinder to be a good performer. The Black Widow was introduced in and around 1973 which offered a dual bypass cylinder dictated by the #1 stamped onto it. This new cylinder was known as the stepped wall cylinder which was beefed up to prevent warping and twisting which the early thin wall was susceptible to. This immediately offered much more power over the Babe Bee and the Golden Bee. What also changed over the years which is the size of the venturi. Early Golden Bee engines had a very small venturi on the tank and the backplate. Later 70's version of the Golden Bee offered the venturi similar to the Black Widow. Black Widow backplates came with a .082" and sometimes as large as a .093" opening.
            To further confuse things, some of the early Golden Bee engines didn't come with sub piston induction. These engines were offered with a #6 cylinder which had no SPI which could be used with a muffler similar to the early QZ Bee. It was noted that exhaust gasses that were spent would be scavenged back into the engine unless SPI was eliminated. Cox raised the height off the deck of the case to block off the space under the piston skirt. For those engines that didn't offer this feature, Cox offered a shim that went under the cylinder prior to being screwed in. As to not make this difficult for users, Cox had a ingenious idea which wouldn't allow the muffler to be tightened onto the case unless the shim was in place. Once in place, a little snug offered just enough tension to hold the muffler in place.
         One of the last Cox offerings of the Golden Bee was the R/C Golden Bee. This engine came with a throttle ring and a high compression head. The throttle ring I believe was a bit restrictive not too mention it probably retained a bit more heat. I believe the high comp head was to restore some lost power due to this feature.
Andre Ming
Ken: That's some good info right there. Thanks.
Mark Mc and Dave Moritz: You're welcome!
This n' That...
The Combat Kitten vs Lil' Satan:
Having had and flown good examples of both, given the engines are the same, the Satan is faster (especially if you use the recommended lines and length on the plans), but the Kitten is a better flyer on the same lines. (Less twitchy and turns tighter due to lighter wing loading.)
I think what would be a mean little mohicky would be a Kitten on a bladder-fed Tee Dee ,049/.051 on what used to be the standard lines for 1/2 A combat: 35' stranded wire lines. (Can't remember what dia.)  It would be fast, but it still wouldn't turn as good as the "state of the art" Tee Dee powered 1/2 combat planes "back then".
1/2 A combat: Shame the Tee Dee fell from grace and the Norvel-type 1/2 A engines on larger airplanes with 42' lines became the thing. With the demise of Tee Dee 1/2 A, up went the cost to be competitive.
Andre
John Skukalek
Andre Ming
Quote from: John Skukalek on December 08, 2023, 07:37:58 AM
Thank you Dan and Kenneth.
Ah yes... in my response I forgot to include Dan and his excellent tips. Mea culpa.
In fact, this entire thread is filled with good replies with good stuff therein! Thanks to all that have participated!
Andre
kenneth cook
            Andre my son and I were present when you were New Jersey Circle Burners. You flew your Demon. I think you had a Combat Kitten with you or maybe it was mine and you chimed in on it. I love the Satan, I just do and it might be the decal who knows. However, it really flies poorly in my opinion. It's fast but not maneuverable like the Kitten is. My first Kitten with a strong Black Widow impressed me to this day.I believe it's due to wider wingspan than the Satan and wider chord. I since converted my Kitten to a TD on bladder. I do it more for a gimmick. I use 65% nitro and it hauls the mail. It's a bit aggressive on plugs but damn is it fun to watch.My son flies it and makes it appealing but he would rather fly the modern 1/2A's.
Mark Mc
WHAT?!??  Fell from grace???  Norvel is to Cox:
As is:
Class never falls out of grace!
kenneth cook
#37
               One airframe that I've always found to be impressive is the Baby Flite Streak. How many in regards to this post actually flew a match of combat using period airframes and Cox Bees? If you think back on it, you probably would have more fun smashing yourself in the crotch with a sledge hammer. Integral tanked bees are plagued with air leak issues yielding not so successful back to back runs. I'm not saying one can't work their way through the issues because I do it all the time. The difference is when you do go up for a match, NOTHING works. Engines want to run backwards, engines that typically yield one to two flip starts don't want to start etc.
         While not combat related, I've tried and tried to successfully do a full stunt pattern which flies just like the big counterparts. This is quite difficult. I mean a judged pattern with definition and all maneuvers easily recognized. This is not possible with a Bee of any kind due to capacity so I've utilized external tanks and product backplates. Applying all that I learned in doing so,  I've found this to be very useful on combat planes . However, many designs such as the Satan and Kitten are tight for space.
          I did put a tank into my Kitten and it was the worst thing ever. For starters, the engine was constantly fuel starved and without running rich, fuel draw was always a issue. Running rich on a combat plane is pretty unproductive in terms of what one is trying to achieve. Hard maneuvering would make the engine quit. Therefore, it was quite obvious early on that bladder pressure resolves this problem. It's not that a tank won't work but certain factors assist in fuel draw.
               Old timey upright engine combat planes utilize their fuel tanks directly behind the engine and as close to the back of engine as possible. This alone is a key factor in successful engine runs. I've found square tanks to feed exceptionally well when mounted directly behind the engine whereas profiles like a coffin shape or pinched back outside corner. Many of the designs however don't allow for a tank installation directly behind the engine. Usually, the bellcrank platform is in the way resulting in a redesign if necessary. Another factor which also helps in fuel draw is uniflow. I know of no commercially available 1/2A tank. Therefore, making your tank uniflow is important and understanding design,  cleanliness,  technique is critical to success.
           If this isn't your thing and your hard pressed to use integral tanked bees, which I still do, there's a few things to watch for. Obtain a 5 oz's luer lock syringe and use small fuel tubing on the tip. Take the tanked engine apart, hook the fuel tubing to the back of the tank with the syringe retracted. Press the syringe and it should go down easily, however your shouldn't be able to retract it backwards AT ALL!!! If you can, the reed is leaking and it's not going to work successfully. Before going any further, place a drop of oil on the reed and insure it wicks under it and try again to see if it passes the suck blow test.
          Assemble the engine and now carefully tighten down the needlevalve enough to block it off. Using the syringe, place the fuel tubing on one of the filler pipes and with a spare finger hold it firmly against the overflow filler and press down on the syringe. Lend a ear to the engine, if the plunger immediately depresses, listen to where the air is leaking from. If you hear air directly from the rear of the engine such as the intake screen, the venturi gasket is leaking. The stock Cox gasket is a POS!. Obtain throwing dart o-rings, they're cheap, they're actually round and they work great for this application.
           Other air leaks can occur at the screws, place a drop of oil on each screw and repressurize t and check for bubbles.These are a bit difficult to fix. Some use sealers, I prefer a cotton swab. I tear off a piece and use the cotton similar to Teflon tape using it the same way as to not unscrew it when tightened.  Place a drop of oil on the tank to tank back connection and let it wick around the tank while keeping pressure on the tank. Air leaks can develop here as well which can be remedied by inserting dental floss into the v-groove of the tank. This is a pain in the rear to do but it does fix the problem. A drop of oil can hold the dental floss while laying it in there. I've found nitrile gloves good for this because the floss right when I get it all the way around sticks to my fingers. Only overlap a minimal amount. Also with oil check for bubbles at the case to tank joint where the gasket is, I prefer to lap the back of the case with 400 paper on a piece of glass using a little oil . The screws tend to pull material and raise the surface which I like to make absolutely flat prior to installing.
             Also check your needle valve assembly, this can leak where it's installed into the backplate itself and also around the threads where the needle screws in. I've successfully removed the threaded body out of the die cast tank back and carefully reassembled once clean with JB weld if the leaks were present at the assembly to tank back. The needle leakage can be remedied by using small tubing on the threads with a washer on the needle.
          Most importantly, is the plug. While it might glow and it looks bright, this always doesn't equate to the fact that when you fly it , it becomes unpredictable. These things are nearing $15 a piece and more from others. It's hard to not use the old ones.New plugs just seem to have a very overall positive impact on engine run.  Look for the warning signs, rpm drops after igniter is removed, Roughness when running and inconsistent rpm's. Many times I've discovered the Cox engines when mounted in the traditional laid over profile fashion with cylinder to outboard tip can cause burping in outside maneuvers similar to the Fox.35. While it might some non traditional, I tried the inboard mounted cylinder like the Hyper Viper and it really seemed to me to improve the run.
Andre Ming
Thanks Ken!
Yes, that was my Combat Kitten. I still have it and shared a pic of it in this thread.
Thanks very much for your great tips.
This thread is turning into a really good one with lots of good information therein!
Andre
Larry Renger
A great truth. If you make it go faster, it won't live as long. Just like people.  HB~>
Actually, most engines die of dirt/dust ingestion. If you use enough oil of the right type in a clean environment,
you will wear out before the engine does. Two examples: Cox ran a Tee Dee .049 for 400 hours. It needed an electric starter to get going then, but still ran fine. Duke fox ran 55 gallons through a Fox stunt .35. And then gave up because it still ran well.
Sadly, we don't fly in a clean lab. 😢
If you must choose between two evils, pick the one you've never tried before. 🤠
Mark Mc
Quote from: Larry Renger on October 09, 2023, 05:52:04 AM
Slit exhausts work just fine.  H^^
More important is the orientation. Fore and aft is best because then the bypass flutes are not restricted by the reed housing and crankshaft.
Was just looking through old posts for ones with Hyper Viper in them, as I'm cleaning up my workroom and I have a left over Hyper Viper wing that I'm gonna make a balsa fuse for.
Anyway, I've heard people talking about indexing cylinders for better performance, but this post is the first on to succinctly state that it's because of the bypass not being blanked out by the reed housing.  I'll have to remember this.
Larry Renger
As stated above, unless you are flying in competition, the stock engines are all you need. That is what I normally run.
Just for background information, I was responsible for both the Black Widow and Venom engines. With major input from Paul Giebault on the Venom.
If it really mattered I could easily tweak things, but don't. 🤠
On a Cox 049 rebuild no one has talked about tightting  up the ball joint with a resetting tool. In the past that has worked for me.
Larry Renger
Yes, tightening the ball socket is important whether you fly sport or competition. I find that it usually only needs to be done once after break in for casual flying. In competition, checking and correcting the fit should be a part of regular maintenance
Do reed valves actually wear out due to long use?  Or do they just get dirty or maybe damaged.
944_Jim
I had a reed valve get damaged a few weeks ago. Not only the reed, but the circlip and backplate were damaged, and the crank pin pent. Truth be told, the reed didn't cause the damage. But it was damaged none-the-less. The guys in CEF have played with making replacement reeds from floppy disks.
Quote from: Paul Smith on June 19, 2025, 07:52:18 PM
    Reeds most certainly can wear out, break, and be deformed. Many different materials have been tried to see what gives the best performance. The reed has to be able to flutter, but still be strong enough to withstand the extremely rapid pounding they take. Original reeds were a beryllium copper, I believe, and work very well in the older engines. More modern versions had stainless steel reeds. I was working with a 1/2A Baby Clown last year powered by one of the last production engines, the ones with the gray choke tube, that also have the high performance cylinders on them. That one came with a stainless reed, and after 5 flights it became deformed around the seating ring and would not run correctly. I replaced the reed , and again, after a few flights it also became warped and deformed. Mylar reeds were another possibility and I tried those with nit much success. I even tried the original cross shaped  beryllium copper reeds and it also didn't last. I finally tried some plastic shim stock that I had that was .005" thick and it has lasted the longest so far, with good, repeatable performance. I think it all depends on what you are trying to achieve, and what version of the Cox reed engines you are using, and there are several different vintages, and not all parts interchange, have different clearances, and might require different thicknesses. Most guys are racing them and looking for all out speed and have to rebuild them often. I was looking for consistent, reliable and repeatable runs to fly 1/2A stunt, and I think I got to where I wanted and needed to be.
Larry Renger
Reeds should not degrade that quickly. Check the reed seating area for roughness or other distortion. The stainless steel reeds were used in the Venom and proved pretty bulletproof.
Quote from: Larry Renger on June 20, 2025, 08:11:03 AM
    That's what I remembered about the SS reeds, and was surprised to see what I saw after taking the engine apart. The seating surfaces were smooth, and flat as a pancake. I replaced the reed with another SS reed and got the same results. These reeds were only about .002" thick, though, and I wonder if doubling that would help, but I haven't looked for any material to make them from. Does the .002" thickness sound correct you you? I meant to check the remaining ones i have to see if they are the same but haven't gotten around to it yet. I'll have to send some photos I took of them to illustrate what I'm seeing. It's like there is so much force slamming the reed back against the surface, that they get formed around the round ring, and it leaves a polished witness mark behind also. I tried the plastic shim stock that I mentioned, which is .005" thick and have had no issues, but haven't run the engine yet this year. That will be a good test, to see if the engine picks up where I left off and starts and runs like I wanted it to. PM your email to me and I'll send you the photos and maybe you can post them. I still haven't learned the technique  for doing that as yet. The email address I have for you is from 2021 and not sure it is still good for you.
Mark Mc
Dunno.  I've never run one long enough to find out.  I run an engine a few times, then move on to another engine I've acquired that needed rebuilding.  Conservatively, I'd say I probably don't have more than 25 flights on any one reedie in the recent past.   But I did put exactly 200 flights on one Silver Bee back in 1990.  Assuming about 3 1/2 minutes on an 8cc tank, that engine got a little over 11.66 hours.
Longest time I know that I've put on one engine in one sitting, was 3 hours and 45 minutes that I put on a product engine about six years ago for a CEF contest to see how long an engine would run on a quart of fuel.
