  • July 31, 2025, 08:07:02 AM
Author Topic: Cox .049 fuel  (Read 12966 times)
Cox .049 fuel
« on: January 22, 2007, 02:01:43 PM »
HI All,
Boy do I feel dumb!
This a question about fuel for my Cox engines.  "Back in the day" I could get teh Cox fuel in the local hardware store.  It's long gone!
I have various "full size engine" fuels.  One is a gallon of Cooper 20% nitro, mostly synthetic oil.  I took some of that and added a good bit of castor to it.
I do have the Sig Champion 10% 1/2-1/2 fuel.
What is "usuable", and which would be best?
Thanks!
Bill <><
Offline frank carlisle
Re: Cox .049 fuel
« Reply #1 on: January 22, 2007, 02:41:38 PM »
Bill...........Jan and I have been using Norvel Fuel....It comes in different amounts of nitro. We have 25% nitro 18% oil.
The Cox engines we have seem to like it pretty well.
Frank Carlisle
Offline James Lee
Re: Cox .049 fuel
« Reply #2 on: January 22, 2007, 02:57:10 PM »
Around here we've found the Sig 25% Champion fuel to be a good 1/2 A fuel.  The Cox has to have a fair amount of castor to keep the piston ball socket from coming apart.  That was from Dale Kirn, many years ago...  I think the old Cox fuel was all castor, but I don't know what percentage.
Jim
Re: Cox .049 fuel
« Reply #3 on: January 22, 2007, 09:01:04 PM »
Thanks, guys.  Main problem is that I don't have a really "local" source of anything, fuel or otherwise.  I CAN, however add castor to fuel that I have.  Or mix and match.  That is why I referenced the Cooper, it is 20% nitro.  Everything lse is not over 10%, basically.
I was thinking that the Cox needed castor from some long forgotten bit of memory......
I finally got me a Davis "rod setter" for the Cox engines and took a couple apart to check them.  All of them had rods that were getting loose in the pistons!
Bill <><
Offline George
  • Love people, Use things.
Re: Cox .049 fuel
« Reply #4 on: January 22, 2007, 11:22:51 PM »
Bill,
I believe Cox fuel was 15% nitro and their Racing Fuel was 25% nitro (perhaps 30% at one time). I believe it was either 18% or 20% all castor lube.
George
George Bain
AMA 23454
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Cox .049 fuel
« Reply #5 on: January 23, 2007, 01:38:07 AM »
Bill <><
Happens to every Cox.  If left untouched, the rod will eventually drive itself through the top of the piston.  I had a really cool picture ("had"--since lost) of one of mine that did just that, broke out a circular piece that left a hole so perfect it looked like it had been drilled.  That was my introduction to the Cox loose-rod syndrome.  A rather poor piece of engineering in my opinion.
--Ray
--Ray
AMA902472
