  • June 17, 2025, 05:44:45 PM
Author Topic: 1/2A Arrow  (Read 5390 times)
1/2A Arrow
« on: February 17, 2014, 04:04:44 PM »
Several years ago there were a couple guys building the 1/2A Arrow.  Minnesota Modeler and Frank, maybe??  (search didn't produce anything)
Where these finished and how did they fly?  What engines?  Pictures if possible.
I have a Fierce Arrow 400 and while I am getting back to flying, I am kinda wanting a few "small" planes in the .049-.061 size that will be decent flyers.
Thanks!
BIG Bear
Offline Roger Vizioli
  • CLiner
Re: 1/2A Arrow
« Reply #1 on: February 17, 2014, 09:16:39 PM »
Hi Bill,
another subject - I did answer your e-mail.
I was one of the guys building the 1/2A Arrow. Still on the shelf, partially complete.
If you want a really great flying 1/A, check the Bob Baron Barecat. I use a Norvel .061 on mine, 6x2 APC and 48' .008 lines w/ Renger handle.  It will outfly the 1/2A Pathfinder.  I guess it is time to dust it off and have some fun!  to see a pic of mine, go to the photo gallery section here, district 5, second line of pics, from the bottom on the left side. plans avail from AMA.
Take care
Roger V.   H^^
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Andrew Tinsley
Re: 1/2A Arrow
« Reply #2 on: February 18, 2014, 08:39:10 AM »
The Bob Baron Barecat sounds an interesting build, Presumably plans are available?
Andrew.
BMFA Number 64862
  • CLiner
Re: 1/2A Arrow
« Reply #3 on: February 20, 2014, 08:45:57 AM »
Article and pic of plans - See Model Aviation, June 1999, page 34 ......see AMA plans, under B for Bare Cat.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: 1/2A Arrow
« Reply #4 on: February 21, 2014, 04:13:54 PM »
Yup, I was one.   Pix included.  Engine = Norvel .061, APC 6x2 prop.  It flew very well after I limited the elevator travel so it didn't stagger completely out of the sky.  Takes a fairly long takeoff run, maybe I have the gear set too level.
Fancied it up quite a bit, tip-weight box, adjustable leadouts, just like the big guys...
I designed a really sexy cowl/air-exhaust system I thought, then had to cut it off when the engine kept overheating.  Oh well.
And yes, that's a Lego Frankenstein piloting...
--Ray
AMA902472
Offline Larry Renger
Re: 1/2A Arrow
« Reply #5 on: February 22, 2014, 09:44:46 AM »
I love the tip weight box idea. Water bottle cap and neck. Devilishly clever!  H^^
    • Minnesotamodeler
Re: 1/2A Arrow
« Reply #6 on: February 22, 2014, 11:54:02 AM »
Why thank you, Larry...it works really well too. A little piece of foam rubber  CAed to the inside keeps things snug.  Nickels fit perfectly; properly-sized washers will if you're a purist.  But they cost more than a nickel.
--Ray
AMA902472
Re: 1/2A Arrow
« Reply #7 on: February 23, 2014, 07:51:36 AM »
That is so true about washers costing more than a nickel.   But, would I get in trouble drilling holes in nickels?
    • Minnesotamodeler
Re: 1/2A Arrow
« Reply #8 on: February 23, 2014, 12:08:28 PM »
Why would you need to drill a hole?  Nickels fit nicely into the bottle neck.
Oh...use the nickel for a cheap washer...never mind.
--Ray
AMA902472
