  • June 17, 2025, 04:55:15 AM
Author Topic: replacement hemostats on bladder tanks  (Read 3231 times)
Offline Steve Thornton
« on: March 12, 2015, 01:55:49 AM »
I've been looking at bladder tanks and the use of hemostats/clips has bothered me a little because I don't like to rush things around a 18,000 RPM prop.  Bill Bischoff has a great idea on his rat racers that may offer a solution to the problem of keeping the engine from flooding until you get it running. Take a look at this post:
http://stunthanger.com/smf/index.php/topic,36568.0.html
Go down to the photos of his device.  It would work great with a very slight adaptation. What do you think?
"Most of us won't make it out of this world alive."
Steve Thornton
Offline mike londke
Re: replacement hemostats on bladder tanks
« Reply #2 on: March 12, 2015, 10:39:38 PM »
I like the control horn idea.  But I made one up the opposite.  I have a hook holding it closed for start, then slip it free to release clamp on fuel to let it flow.  This control horn setup seems much easier than the hook setup I did.
Tags: 1/2A  hemostats
