Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 17, 2025, 02:03:11 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
A Nairplane -- a nupdate
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: A Nairplane -- a nupdate (Read 1126 times)
Tim Wescott
25 supporter
Trade Count:
0
Admiral
on:
April 01, 2010, 07:01:22 PM »
Done (quite a while ago, but I've been having fun flying it). Note the repair on the "fuselage" -- that came early on, learning how to sleeve launch in the horse field.
Final weight includes 0.4 ounces of tail weight -- if I do it again the engine's going way back!
Thumb down to the bottom:
http://www.ccwebster.net/robintim/anairplane/
It flies much better than this one:
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: A Nairplane -- a nupdate
Reply #1 on:
April 02, 2010, 09:35:34 AM »
Yep, not enough up or forgetting to give down on launch to level off. I like the layout.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
April 02, 2010, 09:38:36 AM »
Quote from: john e. holliday on April 02, 2010, 09:35:34 AM
Actually it was recovering from the surprise of 1/4 a circle's worth of slack lines. You have to make sure it's headed _up_ right after it comes out of the sleeve, so it'll still be flying when the lines get tension -- and then you have to have the elevator roughly right, or you break the plane in two.
Logged
John Crocker
Trade Count:
0
Commander
Reply #3 on:
April 02, 2010, 12:59:05 PM »
yep, those el cheapo stick planes are a blast, just like I said. Whats really fun is to do full contact combat with them. You only have a buck or 2 in each plane, ramming your buddies in the combat ring is a blast.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
