  • June 16, 2025, 05:51:32 AM
Author Topic: .010 stunter how much wing area?  (Read 3840 times)
Online dave siegler
  • sport flier
    • Circlemasters Flying club
« on: February 26, 2018, 04:24:33 AM »
Going to put together a simple airplane for a cox .010.
We do a lot of demos and this would be a hit.
Just to fly maybe a loop and 8's
thinking 80  100 square inches wing a sheet of blue core foam about  12 inch span with a small carbon rod.
Lines 10 feet?   I could almost self launch it.
Any reference designs?
Dave Siegler
NE9N extra class
AMA 720731
Offline Larry Renger
Re: .010 stunter how much wing area?
« Reply #1 on: March 02, 2018, 07:15:43 PM »
what kind of structure are you planning? The plane should weigh under 3oz. The engine with original prop produces 5 oz. of static thrust.
I would aim for 100 sq.in. with a built up structure. 15% thick airfoil.
Research Randy Heydon’s Lil’ Bit. It would do the whole pattern. I think it was published in Model Builder. He did use a bladder to assure consistent power.
Offline paw080
« Reply #2 on: March 08, 2018, 05:55:43 PM »
Hi Dave, in the very early 1960's my ex-wife built a Midwest Sniffer(FF) and powered it with a TD .010.
the model has 139 sq"s and weighed about 3.5 ozs. and it climbed straight up(spiral) like a Zipper.
That was in Albuquerque,  the flying field was close to 6,00 feet.
I recommend you go to the trouble of using a built up design like the Mini Zilch or better yet, a
Southwest 1/2A Snapper.  Use 25-30 foot lines(.008"-.012" stranded cable). A 1/2oz tank or better
yet an appropriate sized balloon will do the trick. Best of luck.   For Historical(Hysterical..) reference;
Bare built a 160 sq" scaled down PDQ Lion Tamer powered with a PAW .5cc diesel; and it literally
screwed him into the ground using 35' X .012" lines.    I wish you the best of luck with whatever
you end up building and flying.
Tony G...Yes, it's me, back again after mucho health BS.
« Reply #3 on: April 10, 2018, 10:24:52 PM »
Another data point:  Frank Warburton's Mite was Cox .010-powered, span 13", 36 sq. inch area and weighed 1.75 oz.  "Does most stunts."  (ref. American Modeler, Feb. 1963)
Tom Lay also build one--perhaps a scaled down McDonald Stiletto?
Offline pat king
    • PDK LLC
« Reply #4 on: April 11, 2018, 02:28:45 PM »
My Micro Ringmaster Stunter has a 17 1/4" wingspan and 53 1/2 square inches. A Baby ringmaster has 95 square inches of wing area. That is too much for a Tee Dee .010.
Pat
« Last Edit: April 11, 2018, 03:20:29 PM by pat king »
Pat King
Monee, IL
AMA 168941
Jim Roselle
« Reply #5 on: May 08, 2018, 10:52:06 AM »
Hi Dave,
I have the plans for Lil’ Bit. PM me your address and I’ll see if I can dig it up and get it in the mail for you.
Jim
