  • June 15, 2025, 02:48:46 AM
Author Topic: Need Tee Dee .049, .09 and .15 NVA  (Read 1212 times)
Offline frank mccune
« on: April 25, 2015, 06:39:43 AM »
   Hello:
   I need some of the above NVA to get some old Team Race engines running again.  If you can help with parts or sources or parts, kindly contact me.
        Tia,
        Frank McCune
Offline Dane Martin
  • heli pilot BHOR
Re: Need Tee Dee .049, .09 and .15 NVA
« Reply #1 on: April 25, 2015, 03:53:44 PM »
You should be able to contact Cox directly at-
http://coxengines.ca/
Or texas timers at-
http://www.texastimers.com/
for the fine thread ones.
Offline Phil Krankowski
« Reply #2 on: April 27, 2015, 06:57:03 AM »
That will get you .049 parts, for the larger engines it will be more difficult.
If you want a STOCK TD set, with clicker spring I have one I can part with.
Phil
