  • August 01, 2025, 06:39:28 AM
Author Topic: Can you cover a 1/2 A wing with monokote  (Read 7201 times)
Offline rich gorrill
« on: November 25, 2016, 11:34:22 AM »
I recently scored an older Brodak P-51 on the bay. Kit was is great shape. Our club has 1/2 A fun flys so this will be my entry. Noticed that the wing is built without any spars, top or bottom. Can I safely use monokote without warping the wing? The kit came with silkspan so this is also an option.
T I A
Rich
Offline Dane Martin
  • heli pilot BHOR
Re: Can you cover a 1/2 A wing with monokote
« Reply #1 on: November 25, 2016, 12:17:08 PM »
No, it pulls too hard. I'll get you a list of iron on options,  but ultra cote light is a great one
Offline kenneth cook
« Reply #2 on: November 25, 2016, 12:50:03 PM »
               Rich I do it all the time, Monokote is all I use. I never had an issue even with light wood. Never had a weight penalty issue either. Apply with iron both sides and then shrink with a heat gun.
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: November 25, 2016, 01:27:33 PM »
I would certainly trust what ken says. Perhaps it's been too long since I tried it, and my technique sucked back then!  ;D
« Reply #4 on: November 26, 2016, 05:25:43 PM »
          Dane, your very correct that it will pull the frame and twist. Covering the other side before completely shrinking and evenly shrinking is key.
Offline Andre Ming
« Reply #5 on: November 26, 2016, 10:16:55 PM »
Have used Monocote on 1/2 A combat airplanes since the late 1970's. (This includes Combat Kittens.) Zero issues.
I may have inadvertently covered as per Ken was explaining, from the habit of trying to keep the shrinkage/pull even as I used to do in my days of silk n' dope.
« Last Edit: November 27, 2016, 04:17:34 PM by Andre Ming »
Offline Roger Vizioli
  • CLiner
« Reply #6 on: November 27, 2016, 08:11:07 AM »
I always use Ultra Cote light on my 1/2A's. As mentioned below - even shrinking top and bottom.
Roger
« Last Edit: December 26, 2016, 07:17:57 PM by Roger Vizioli »
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline James Holford
Re:
« Reply #7 on: November 27, 2016, 08:25:44 AM »
One day I'll be able to cover as.good as yall lol
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Skip Chernoff
« Reply #8 on: December 15, 2016, 06:34:59 AM »
Ken is correct .Attach covering to perimeter top and bottom without shrinking then shrink evenly both sides. I've even covered a Guillows "Giant Scale" (lol) Hellcat with Monokote.
« Reply #9 on: December 15, 2016, 10:09:41 AM »
Here is my latest 1/2A covered with Monokote.
Offline Russell
  • ACE
« Reply #10 on: December 16, 2016, 02:02:48 PM »
T I A
Rich
Sure can. Lil Satan and Lil Jumpin' Bean both have NO spars and cover with MonoKote just fine, I should say cover with excellence.
« Reply #11 on: December 16, 2016, 10:06:34 PM »
My Baby Ringmaster came out fine and straight using Monokote.  Still  straight four years later.
Mark
Offline Larry Renger
« Reply #12 on: December 21, 2016, 06:55:42 PM »
Try Microlite, it is about half the weight.  A bit of a pain to use, as it will stick irretrievably to itself if you don't watch out!
I also love Litespan from Tower or Hobby People. Japanese tissue without needing dope and more durable.
« Reply #13 on: December 21, 2016, 09:56:33 PM »
I use only the iron and shrink one bay at a time, starting with the innermost bay, and alternate top/bottom as I move out toward the tips. I've had good luck with that method. I prefer the iron with no sock because I can finesse it with a quick light touch better than I can with a gun.
Rusty
Offline badbill
« Reply #14 on: December 26, 2016, 02:56:23 PM »
Certainly you can. The best I have tried is the Horizon Hobby Parklite- That's what the little Bipe is covered with.
« Last Edit: December 27, 2016, 08:33:55 AM by badbill »
Bill Davenport
AMA 28141
Offline Chancey Chorney
« Reply #15 on: December 26, 2016, 04:27:54 PM »
Certainly you can. The best I have tried is the Horizon Hobby Parklite- Thant's what the little Bipe is covered with.
Nice. Two things of beauty!
« Reply #16 on: December 27, 2016, 09:52:21 AM »
And Bill's cool silver flames can be applied with Windex, slid into position and will adhere just as if they'd been cooked on. The ammonia activates the M'kote glue, but it will NOT activate U'cote glue. I seal the edges with a little brush and dope or Lustrekote. Clear fingernail polish later turned white when I cleaned it with alcohol.
I don't know if Parklite has the same adhesive or not.
Rusty
Offline badbill
« Reply #17 on: December 28, 2016, 06:46:05 AM »
Rusty
OR, just iron down the stripes, it works great, no mess no fuss. Put in place and tack down one end ( I do the wider end ). Run your thumb across it down the piece, then iron down it. No bubbles, no wrinkles no tears  LL~
Bill Davenport
AMA 28141
« Reply #18 on: December 28, 2016, 11:35:05 AM »
Hope you remembered to clean the surface before putting stripes on.   Looks good and I like that kind of paint scheme.  But, I'm getting lazy in my old age. H^^
Offline badbill
« Reply #19 on: December 28, 2016, 11:42:30 AM »
I did Sir  #^ Man, I have got some hours in this little plane !
Bill Davenport
AMA 28141
« Reply #20 on: December 28, 2016, 05:04:04 PM »
Bill, I had trouble ironing Monokote stripes because it takes such a high temp to kick the glue, then I got some shrinking that botched it all up. Ultracote should iron on easy though, because it's adhesion temp is way lower than the shrink temp. Maybe Parklite is the same way. The two Monokote temps overlap. Just my experience.
Rusty
« Reply #21 on: December 29, 2016, 10:52:25 AM »
When I do graphics like stripes and numbers after cutting them out,  I turn the heat on the iron down where I can hold it in my hand.  Yes this is after putting them in place with the Windex and paper towels to get them rubbed down.
