  • June 17, 2025, 10:16:28 PM
Author Topic: Name that glowhead!  (Read 1505 times)
Offline Mark Boesen
    • 049 Collectors
Name that glowhead!
« on: April 26, 2011, 09:08:11 PM »
Hello,
Playing around with some engines today, I realised that there were alot of different manufactures making 1/2a's with glowheads. So I took a pic and thought I'd post it here thinking some might enjoy it.
Who can name the manufacture and model that the glowhead was designed for?
Good luck,
Mark
Offline Larry Renger
Re: Name that glowhead!
« Reply #1 on: April 27, 2011, 11:44:37 AM »
I'll take a stab at it.  Clockwise from top left:  Atwood Shriek, Fox, Holland Hornet, Unknown, Cox standard, Holland late model, Cox high compression, Unknown and Testors.
Offline LARRY RICE
« Reply #2 on: April 27, 2011, 12:42:45 PM »
The fourth one in the top row I believe is a K and B Tornato plug.
Larry
Offline George
  • Love people, Use things.
« Reply #3 on: April 27, 2011, 01:12:15 PM »
The second from left on lower row appears to be a Cub.
George
George Bain
AMA 23454
Offline Larry Lindburg
« Reply #4 on: April 27, 2011, 01:40:18 PM »
The gold one appears to be a Testors-made replacement for a Cox Babe Bee.  My experience with those was that the engine did not run as well.
AMA 95707
« Reply #5 on: April 27, 2011, 01:43:16 PM »
The plug above the gold one may be a K&B/Aurora.
AMA 95707
Offline jim gilmore
« Reply #6 on: April 27, 2011, 02:37:47 PM »
I'm,lost here Larry R.. If you go clockwise.do you start top left and end bottom left ?
so isn't the bottom right a testor's ?
Offline Mark Boesen
    • 049 Collectors
« Reply #7 on: April 27, 2011, 07:22:19 PM »
You guys made that easy...I thought the hardest to ID would be the gold Testors head for Cox engines followed by the late model Hornet head made by Dynamic.
  Top row   L-R: Atwood Shriek, Fox, Holland Hornet, K&B/Aurora Tornado & Cox standard.
Bottom row L-R: Holland (Dynamic) Hornet, Cub, Cox high comp., Testors (for Cox) and Wen-Mac/Testors.
I totally forgot to add the Gilbert .07 glowhead!
Mark
« Reply #8 on: April 27, 2011, 09:05:53 PM »
Dang, I knew that Cub head and it slipped through my typing fingers.   :P
Offline George
« Reply #9 on: May 04, 2011, 09:03:18 AM »
Mark,
Here's your Fox .07 plug on the right, sitting on...  >:D
George
George Bain
AMA 23454
