  • July 31, 2025, 03:46:19 PM
Author Topic: Joy Products Stunt Runt  (Read 6452 times)
Offline Bruce Shipp
« on: December 04, 2022, 07:53:39 PM »
My first kit was a Stunt Runt.  Time to revisit my youth.  The parts are cut, time to sand and glue.  I’ll try to keep this up to date.
Offline 944_Jim
Re: Joy Products Stunt Runt
« Reply #1 on: December 04, 2022, 08:31:40 PM »
Cool! Subscribed.
« Reply #2 on: December 04, 2022, 10:04:30 PM »
Any chance of getting a copy of the parts?  Looks simple enough that no plans needed. H^^
Offline Bruce Shipp
« Reply #3 on: December 05, 2022, 06:02:36 PM »
Watch your mail, Doc. I sent copies of templates. I got full size plans on eBay from airclassix.  I think he’s on here.
Offline kenneth cook
« Reply #4 on: December 05, 2022, 06:33:35 PM »
            Dan Banjock has the Stunt Runt with a Mccoy .098. For one, I extremely impressed how that engine works in this plane. Of the .098 examples I've seen they have very little compression to even start. Dan's engine runs quite well. This is a neat plane to see stunting and Dan doesn't hold back.
« Reply #5 on: December 09, 2022, 08:50:10 PM »
Thanks Bruce, the templates are here.   Now to get cutting. D>K
Offline Bruce Shipp
« Reply #6 on: December 10, 2022, 09:37:54 AM »
Glad you got them, Doc.  Enjoy.  We’ll race to see who gets done first H^^
Offline kevin king
« Reply #7 on: December 11, 2022, 12:13:55 AM »
Speaking of bi planes check this card out.  Even Santa needs some time out.
« Reply #8 on: December 16, 2022, 05:52:18 PM »
Thanks to Bruce I have gotten in the mood to go to the shop.   The heater is still working even though air flow is hampered with stuff piled up.  But I got the drawings from him and made copies to cut up.  In two days I have most of the parts cut.  Pictures will be coming.  Almost for got how to make a kit using just drawings and no instructions. D>K
« Reply #9 on: December 19, 2022, 07:47:09 PM »
Now if this key board will cooperate I will post pics of progress.  I think I have all the wood parts ready for some sanding before I start gluing.  This was harder than I remember of working off drawings and no instructions.   It will be powered with one of my Babe Bees.  Stay tuned. D>K
The last pic is supposed to be the bell crank mount.  Took a minor change in the engine mount.   Now I'm posting this I see I haven't cut the lead out guide.  Need to also round up all the hard ware. H^^
« Reply #10 on: December 20, 2022, 07:44:17 PM »
A good day today.  Got most of the sanding done, wings glued together and elevato/stab hinged.  Glue the wings to the fuselage as well as the stab/elevator.  This has been kind of fun. D>K
I know, not a good shot of the pilots view. H^^
Offline Bruce Shipp
« Reply #11 on: December 23, 2022, 10:30:39 AM »
Nice work, Doc.
Mine is ready to start assembly. I need to find more time at home when I’m not covered up in Christmas prep. This week hopefully.
« Reply #12 on: December 23, 2022, 06:26:22 PM »
Don't feel lone some.   We have been hit with sub zero temps and with the little heater working the floor temps were too cold according to Prissy my Chiwawa.  My feet were cold also.   Got some work don on bell crank mount and engine mount also and called it quits.   2 degrees F outside. D>K
Offline goozgog
« Reply #13 on: December 25, 2022, 04:58:09 AM »
Merry Christmas everyone.
Looking Good Doc.
  I'm feeling a little bad that I'm posting
about the Stinker right next to the
Stunt Runt build since they're similar
planes.
  It isn't intentional. I promise !
Cheers! - K.
Keith Morgan
« Reply #14 on: December 25, 2022, 11:00:34 AM »
Don't feel bad.  They may be similer in appearance but there is difference in construction. D>K
Offline Chuck Matheny
« Reply #15 on: December 25, 2022, 03:25:24 PM »
You are an inspiration  John...!
Prissy the Chiwawa sounds like quite the spoiled Drama Queen though.
I know how these dogs think.
Tell her to either "suck it up" or you'll get her a night job working as a "security patrol agent" at the local wrecking yard... n1
I'm waiting for a PAW .030 diesel to show up...then get it fired up and then try to  get some sort of an idea about how much plane it can haul around the circle.
« Reply #16 on: December 25, 2022, 07:22:33 PM »
Depending on the plane and prop it should get off the ground and around the circle.    D>K
Offline Bruce Shipp
« Reply #17 on: January 01, 2023, 09:12:11 PM »
Pinned together.  Needs controls mounted and then finish
Offline Bruce Shipp
« Reply #18 on: January 01, 2023, 09:13:44 PM »
A few more pics.
Offline goozgog
« Reply #19 on: January 01, 2023, 10:14:59 PM »
Looking solid Bruce.  y1
Thanks for the pictures.
  Actually, I'm equally impressed by
how tidy your shop is. Mine looks
like it belongs in Fallout 4.
Whatever works I guess.
Cheers - K.
Keith Morgan
Offline Bruce Shipp
« Reply #20 on: January 02, 2023, 06:16:13 AM »
 Ha! I deliberately took those pics only showin one corner of the bench.  It’s all a lie  :)
Thanks.
« Reply #21 on: January 02, 2023, 10:57:37 AM »
That is about where the old DOC is with his version.    D>K
