  • July 08, 2025, 06:38:20 PM
Author Topic: Building Ray's Geo  (Read 2737 times)
Offline Larry Renger
Building Ray's Geo
« on: January 01, 2011, 12:36:08 PM »
Here are photos of the wing construction on Minnesota Modeler's Geo.  Naturally I had to tweak things by adding adjustable leadouts and a panel for tipweight.
The leadouts run through eyelets that may be moved from hole to hole with the wire sliding through the slot.  Once the model is trimmed, you glue the eyelets in.  The tip is a three-piece laminate with the thick inner piece only 1/4" deep forming a hollow tip.
For tipweight, that panel is drilled and tapped for a bolt, and you adjust the weight by varying the size and length of bolt.  Or you can glue a "T"nut on the inside and bolt washers to the outside.  Both work fine.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Building Ray's Geo
« Reply #1 on: January 01, 2011, 12:58:12 PM »
Both good improvements.  You're doing a beautiful job building (to be expected); keep the pictures up.
--Ray
AMA902472
« Reply #2 on: January 01, 2011, 07:03:43 PM »
Very nice, Larry.  I wouldn't expect less, though! ;D
I have never had to glue in the eyelets in....... they are too hard to take out on their own, most of the time! LOL!!
« Reply #3 on: January 01, 2011, 07:39:12 PM »
Actually, Ray's kit fits so well, I can't concieve how anyone but a total doofus could do less well in the assembly.  I know I could not custom cut the fits as well as he does, and the engineering is amazing.
Of course. you can't make things idiot proof, there are too many of them and they can be remarkably imaginative.  I do my share, now and then .....  :##
« Reply #4 on: January 01, 2011, 07:50:20 PM »
Hi Larry,
If I hadn't known it I would have easily believed his 1/2A Snapper kit was laser cut!  His wood working skills are top drawer.  His balsa selection is perfect, as are all the fits!  The lead out are already installed on the BC with both ends finished, the pushrod is prebent, LG has wheels mounted, the only thing I DON"T remember being in the kit (and ready to use) was covering, glue, paint and engine!  About the most "non ARF" kit I have ever seen!
We have some excellent kit makers now, I hope they can all stay in business!
« Reply #5 on: January 01, 2011, 08:27:06 PM »
Yes the leadouts were installed, I made some major mods to do my adjustable leadouts.  I expect that the model would fly just fine as designed and kitted, but I am a small plane, perfectionist nut.  (Do you think anyone has noticed?) I want it MY WAY, just like Burger King offers.
« Reply #6 on: January 01, 2011, 08:45:15 PM »
You?  "a small plane, perfectionist nut"??  NO WAY!!!!!!!
LL~ LL~
« Reply #7 on: February 11, 2011, 12:56:10 AM »
I have done some more work on this model, and apologise for not shooting more photos.  I only can work on it one evening a week at a friend's house.  We meet for building, gab and eating.  The guy has a 7 foot tall 8 foot long barbacue/smoker he built out of Stainless Steel!  And he ain't afraid to use it!
Anyway, the flaps and elevator are hinged, the wing, stab and landing gear are installed.  I'll shoot photos next week.
I am debating how to finish it.  It is coming out a bit heavy for the size, I think.  But brutally strong!  With the flaps, I suspect it will fly just fine.  I plan to put a Fox .049 on it.
    • Minnesotamodeler
« Reply #8 on: February 12, 2011, 04:15:47 PM »
There is actually more wood in that wing than a standard layout...what with the flaps and extra hardware it does tend to be a little heavier than the 5-oz. Snapper for instance! But the flaps do help carry the weight, and it may even be some advantage in a breeze.
Watching for some more pix.
--Ray
AMA902472
Offline jim ivey
« Reply #9 on: February 14, 2011, 08:44:13 AM »
Larry you old "crater maker"  AS I recall you reeeealy luuuuved that red n' black    "fire-cat"        Did you ever think of making a 1/2 a size? (red and black of course) ;D jimmy
« Reply #10 on: February 14, 2011, 08:59:38 AM »
Cratermaker yes!  But I never owned a Firecat!  Never owned an engine bigger than .049 until I got a Fox .35 in college.  I High School, my favorite plane was a rough copy of the Scarinzi Streak (Hmm wonder why the Sky Streak is forward swept?) Also the Lil Omega and the 1/2A Snapper.  Flew a lot of free-flights too.  Just as badly as I did control-lione.   LL~
« Reply #11 on: February 25, 2011, 10:00:41 AM »
Here, finally are some more photos of building the Geo.  Current weight with the Fox .049 engine is 5.7 ounces.  I would love to get it in under 7 ounces!
« Reply #12 on: March 11, 2011, 12:25:42 AM »
I have, for unfortunate reasons, missed the last two building sessions with Warren.  The first one I was helping out with one of my best friends who is having serious cardiac problems.  This week, I was rebuilding my Tech Terror to get it ready for VSC.  I splattered it a week ago due to binding line clips.  It is rebuilt, covered, and has a coupe of coats of dope on it.  I WILL fly it at VSC even if it disintegrates due to fuel soaking after the contest.   ;)
« Reply #13 on: April 11, 2011, 04:17:48 PM »
Here is the latest on the Geo.  #^ The trailing edge stock was like rock, so I added lightening holes as you can see.  HB~>
 Currently it is set up for the Fox .049, but after I fly it with that, I may switch to a Holland Hornet.   VD~
Offline jim gilmore
« Reply #14 on: April 11, 2011, 04:22:05 PM »
Not trying to sound stupid here, but what are the pin like things you use to plank the center section.
« Reply #15 on: April 12, 2011, 11:22:01 AM »
I don't know the name of them, but I think they are available from Control Line Specialties.  They are very nice to use as the pin is extremely fine and the plastic part makes them very easy to insert and remove.
You probably can get them from local craft stores, though I have never looked for them.
