  • June 15, 2025, 11:55:31 PM
Author Topic: Brodak Baby Clown ARF  (Read 3771 times)
Offline Ed Carlaw
« on: April 01, 2017, 04:18:49 PM »
I have a couple of these. Anything I should look out for? Planning on using either a Babe or Golden Bee. Line length? thanks, Ed.
Offline Larry Lindburg
Re: Brodak Baby Clown ARF
« Reply #1 on: April 02, 2017, 08:33:04 PM »
I have one with a fairly strong Babe Bee and external tank.  Flies great with 38 foot lines.
AMA 95707
Offline Ed Carlaw
« Reply #2 on: April 06, 2017, 03:45:51 PM »
Hey Larry, are you using a production engine with the tank or an integral tank drilled out? What size tank are you using? Ed.
« Reply #3 on: April 06, 2017, 04:46:34 PM »
Babe Bee with a 2/3 ounce Brodak tank.
AMA 95707
Offline Ed Carlaw
« Reply #4 on: April 08, 2017, 08:32:55 AM »
What type of lines are you using, Dacron, stranded, solids? Thanks, Ed.
Offline Larry Renger
« Reply #5 on: April 14, 2017, 08:05:49 PM »
That is an excellent model to be a a trainer with a Babe Bee, or full competition stunt model with a Norvel or APC WASP .061. Just select the correct line length for the available power!
Sadly, it is not an exact replica of the original model, but is an excellent design on it's own. I have had several of them, including adding flaps to make it a Baby Super Clown. In that configuration, it is actually closer to accurate scale then.
« Reply #6 on: April 19, 2017, 03:56:59 PM »
I generally use .012 stranded steel.  I would use .008s but my eyes and fingers have difficulty in finishing the eyelets.
AMA 95707
« Reply #7 on: April 19, 2017, 08:27:01 PM »
 What glow plug ya got in there Larry?
Offline Fredvon4
  • Central Texas
« Reply #8 on: April 20, 2017, 08:12:44 AM »
Looks like the insert adapter head and insert like Cox International or Merlin sells
https://coxengines.ca/cox-.049-glow-plug-adapter-insert-style.html
Fred von Gortler IV
« Reply #9 on: April 20, 2017, 12:42:29 PM »
Yes, it is a highly recommended Merlin plug with about five head gaskets.
AMA 95707
