  • July 08, 2025, 02:53:25 AM
Author Topic: Brodak 1/2A stunt?  (Read 7017 times)
Offline John Rist
Brodak 1/2A stunt?
« on: August 22, 2014, 09:18:02 AM »
I have a Norvel 061 AMD looking for a ride.  What is the best Brodak 1/2A stunt ship for this size engine.  Possible the 1/2A Stork Kit, or the 1/2A Pathfinder Kit?
Re: Brodak 1/2A stunt?
« Reply #1 on: August 22, 2014, 10:25:40 AM »
My very best 1/2A flyer is a Big Mig .061 powered Baby Flite Streak. I would call it "sport" stunt, because it's so snappy you'd need to tame it for precision stunt. The Streak was the first 1/2A plane I ever flew that didn't feel like a toy on the end of the lines. You can stand still and fly out a whole tank or bladder, ripping off some pretty good tricks if you wish. I bet the pathfinder would do the job too, but I haven't flown one myself. On a calm day I like to fly the Streak on 40 or 45' with an MA 5.5x3. Or if I'm only in a small area, I put on an APC 6x2 and fly on 35', still fast.
Rusty
Offline John Rist
« Reply #2 on: August 22, 2014, 11:50:43 AM »
Does the Pathfinder have flaps? it looks like it does in the photo.
Offline david beazley
« Reply #3 on: August 22, 2014, 04:08:40 PM »
Baby Clown is an option.
AMA # 2817
Offline John Rist
« Reply #4 on: August 24, 2014, 08:56:12 PM »
It looks like next winter building project will be a 1/2A Pathfinder Kit.  Roger V sent me a picture (attached) of his Pathfinder and I am sold..
« Reply #5 on: August 24, 2014, 09:14:34 PM »
Oh yeah, that's sharp. One of those would look great in my fleet too. Flite Streak, move over.
Offline bob whitney
« Reply #6 on: August 25, 2014, 04:10:48 PM »
I have flown Rogers ,it flys great  dose the whole pattern   think he has a Norvel on it
rad racer
Offline Roger Vizioli
  • CLiner
« Reply #7 on: August 25, 2014, 08:37:07 PM »
Yep!
Norvel .061, 6x2 APC, 48' .008" lines.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Online kenneth cook
« Reply #8 on: August 27, 2014, 01:59:35 PM »
              John, can you enlighten us on the AMD version. When I contacted NV, they couldn't give me the differences. The 5 hole ported cylinder has always been standard as the Big Mig, the AME was the larger 3 hole ported cylinder. My suspicion tells me that the AMD has the 3 ported cylinders suggesting higher combat like performance. I would be curious to know actually and if that's the case, I would also suspect the venturi is larger than the Big Mig. If so, how does this engine run on suction? Have you already run this engine? The Pathfinder is a terrific flying airplane. It really flies like the big stuff. Good luck with it. Ken
Offline dennis lipsett
« Reply #9 on: August 27, 2014, 03:54:12 PM »
The best model that I've seen and even bought a kit of is the Pegasus by Pat King. 34 inch W/S and 235 square inches. Side mounted engine so you know it will run well. It's good looking easy to build and takes a Jim Lee 1/2 A spinner to give it that really classy finished look. I'll enclose a link but regrettably if your not a member of the Brotherhood of the Ring it probably wont work.
http://www.brotherhoodofthering.info/mbbs22/forums/thread-view.asp?tid=1282&posts=3&start=1  One really great thing about Pats kits is that the parts really fit well and you can build a true model
Dennis
Offline Larry Renger
« Reply #10 on: August 28, 2014, 09:21:51 AM »
Don't forget to take a look at Eric Rule's offerings. The Pinto, Hunter and Sky Sport all do killer patterns. rsmdistribution.com
Offline Bill Johnson
« Reply #11 on: October 12, 2014, 01:07:36 PM »
Looks like a nice plane, John. Is that a tricycle gear?
Best Regards,
AMA 350715
Offline John Rist
« Reply #12 on: October 13, 2014, 08:50:41 AM »
Not sure - all I have is the picture.   I suspect it is one wheel.
  • CLiner
« Reply #13 on: October 13, 2014, 09:27:54 PM »
No, it's a tricycle gear, see pic attached.
Roger v.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Dan Bregar
  • Field Marshall
« Reply #14 on: October 17, 2014, 03:07:24 PM »
Roger
What kind of fuel tank set up are you running on the little Pathfinder ?
AMA 33676
  • CLiner
« Reply #15 on: October 17, 2014, 07:37:45 PM »
Roger
Dan,
check your e-mail.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
