Building Tips and technical articles. => 1/2 A building. => Topic started by: Vincent Corwell on April 26, 2007, 07:37:01 AM
Hi fellow addicts
1/2 A Pathfinder with
Brodak new 049 or Brodak 061
Any recommendations please ???
Vincent
Dunno about the Brodak II .049, but the earlier one (blue cylinder) is about on a par with a reed-valve Cox, pretty mild. Based on that, I'd go with the .061.
--Ray
Save yourself some dough and buy the AP Wasp .061. It will run circles around the Brodak in my experience (with 2 of them so far). See the Wasp thread above.
Thanks Larry
I ordered the AP 061 from Tower on my account
is it possible to use standard glow plug please?
( I ordered one spare with the motor )
do you use with carb locked open?
Many thanks for your help
Vincent
The Wasp uses a glowhead insert, not a standard plug. Replacements are readily available, though they cost about $6. Its retainer/head is threaded the same as C*x/Norvel/VA engines, so you have some alternatives available. The obvious one is C*x glowheads. Also a standard plug adapter head can be purchased from MECOA anytime you want to cut the power output down. Of course, the bright side of this is that the Galbreath/Nelson adapter head fits and gives a performance boost!
