  • August 03, 2025, 04:59:07 AM
Author Topic: Norvell break in  (Read 1897 times)
Offline Jay
  • 1 Cross +3 Nails= 4 Given
Norvell break in
« on: October 19, 2013, 05:28:11 PM »
I did a search and couldn't find the thread on breaking in the Norvell.
I tried to run my Norvell on a modified Baby Flight Steak with a modified Perfect tank converted to uniflow and it would not hold a needle setting.  I assumed the engine was already broke in but could be wrong.
I was using 10l29 at first but then switched to 25% Sig fuel, not sure of the old content.
 I have some Norvell fuel but forgot to bring it with me.
How much fuel to get it to break in and run?
Jay
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
Re: Norvell break in
« Reply #1 on: October 20, 2013, 07:57:52 AM »
If it takes a while to break you may have a good one.   Don't rush it.
Offline Larry Renger
« Reply #2 on: October 20, 2013, 02:36:58 PM »
Too much nitro, unless you add a lot of head gaskets. I run 7% nitro, 11% castor, 11% synthetic. 5.5 x 2.5 APC prop. Unlike Cox engines, these will overheat and run badly if at all over propped, over nitroed or over compressed. Let the engine sing a 19k note on the ground minimum.
If you want the extra power that Nitro yields, you must add extra gaskets.
Offline John Kelly
« Reply #3 on: October 21, 2013, 09:05:52 PM »
  ...Hey Jay, Hope this helps.
AMA 11416
« Reply #4 on: November 07, 2013, 07:56:15 PM »
A little late, as I missed this thread, but here's a recent writeup I did on breaking in a Norvel. I opt for the old methods learned from the combat guys rather than new the quick and easy method from NV Engines.
http://stunthanger.com/smf/index.php?topic=32566.msg324763#msg324763
