  • August 01, 2025, 07:44:08 PM
Author Topic: BRODAK 061 OR NEW 049 ???  (Read 1962 times)
Offline Vincent Corwell
« on: April 26, 2007, 07:37:01 AM »
Hi fellow addicts
1/2 A Pathfinder with
Brodak new 049 or Brodak 061
Any recommendations please ???
Vincent
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: BRODAK 061 OR NEW 049 ???
« Reply #1 on: April 26, 2007, 08:07:16 AM »
Dunno about the Brodak II .049, but the earlier one (blue cylinder) is about on a par with a reed-valve Cox, pretty mild.   Based on that, I'd go with the .061.
--Ray
--Ray
AMA902472
Offline Larry Renger
« Reply #2 on: April 26, 2007, 01:15:52 PM »
Save yourself some dough and buy the AP Wasp .061.  It will run circles around the Brodak in my experience (with 2 of them so far).  See the Wasp thread above.
« Reply #3 on: April 27, 2007, 01:55:01 AM »
Thanks Larry
I ordered the AP 061 from Tower on my account
is it possible to use standard glow plug please?
( I ordered one spare with the motor )
do you use with carb locked open?
Many thanks for your help
Vincent
« Reply #4 on: April 27, 2007, 09:24:49 AM »
The Wasp uses a glowhead insert, not a standard plug.  Replacements are readily available, though they cost about $6.  Its retainer/head is threaded the same as C*x/Norvel/VA engines, so you have some alternatives available.  The obvious one is C*x glowheads.  Also a standard plug adapter head can be purchased from MECOA anytime you want to cut the power output down.  Of course, the bright side of this is that the Galbreath/Nelson adapter head fits and gives a performance boost!
