  • August 04, 2025, 08:39:55 AM
Author Topic: Blackhawk Models PT-19 project  (Read 50806 times)
« on: February 14, 2016, 09:51:26 PM »
 I'm planning to start in on a Blackhawk Models PT-19 real soon. When finished this one will be used by our club as a basic flight trainer for "first-timer" kids interested in giving C/L flying a try. I'm looking forward to the project, it will be a nice simple, relaxing build. Power will be a good 'ol Cox .049, maybe even a Golden Bee or Black Widow. It would be fun to get a look at some others, does anyone here have any finished photos of their own examples?
« Last Edit: April 08, 2016, 10:12:24 PM by wwwarbird »
Offline Dane Martin
  • heli pilot BHOR
Re: Blackhawk Models PT-19 project
« Reply #1 on: February 14, 2016, 09:58:48 PM »
Hey Wayne! I don't have a bunch of pics, but the video here's shows it more complete. The pic is before the rudder and control system. I got it from bmjr models.
« Reply #2 on: February 14, 2016, 10:18:53 PM »
 Neat video Dane, thanks!
« Last Edit: February 17, 2016, 09:17:34 PM by wwwarbird »
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: February 17, 2016, 07:08:34 PM »
Wayne, I'm kinda surprised there's not a lot more responses. I always thought this was a very popular model by black hawk!
« Reply #4 on: February 17, 2016, 09:20:32 PM »
 Dane,
 It's been a little while since I looked at it, but my kit has some differences from what yours looks like. It's different from the photos on Blackhawk's website too. I do know that my kit has a built up sheet fuse with a top block, it's not a hollow log type. The fuse sides extend forward from the firewall along each side of the engine too. Also, per the kit design, the wing is rubber banded on like the original Cox model. As usual I'll be making some changes as I go, both for appearance and structural integrity.
 Once I get going on it I'll be posting updates and pics like I usually do, that might wake a few up.  D>K
« Reply #5 on: February 18, 2016, 09:00:19 AM »
Here are a couple thoughts if you really plan to make this a basic trainer, not a beauty queen.
You need to fly over grass with no landing gear.
If you do that with a low-winger, the wing hits the ground first & gets all beat up.  While the CoX PT-19 is a historic icon, it's not such a good trainer.  Cox ran programs in which they donated a lot of PT-19's that got splattered on the pavement without actually teaching many kids to fly.
A basic wood hollow log with the wing on top and goodly amount of tip weight is a better bet.
« Reply #6 on: February 18, 2016, 08:56:55 PM »
 Thanks for the tips Paul. There are definitely better candidates for basic trainers, and we already have some in the club, but this PT-19 will just be another to add to the group. You can only ask so much of a heavy sheet wing design. This one will have landing gear, I feel that takeoffs are typically easier that way than catching up with and recovering from a hand launch. The wing will be fixed too, not rubber banded on per the kit design. I'll end up making some other changes too that will help a bit with durability.
« Reply #7 on: February 19, 2016, 10:56:42 AM »
Rubber-banding the wing was never a really hot tip for CL.   But a rubber band engine mount is a good thing for 1/2A.   The firewalls were always coming off the old Scientific logs.
In one field repair I shoved an Allen wrench through the body and used it to anchor the rubber bands to hold the engine mount until the glue dried.  Then flew the plane that way for the rest of its life.
« Reply #8 on: February 19, 2016, 08:37:42 PM »
 Ok, the kit I've got is definitely different than Dane's version. I got a chance to dig it back out tonight and what I have is the "Deluxe" kit. Apparently Blackhawk offers both this and the hollow log version like Dane's.
 This one has a 25-1/2" wingspan and comes complete with a Cox .049 and prop. Everything is laser cut. The fuse sides and all the tail surfaces are plywood. I didn't measure, but they all look to be 3/32". I'm not sure I'm sold on using the ply tail surfaces, we'll see. I can already see myself laminating a 1/16" balsa sheet to the outside of the fuse sides, but we'll see about that too. There is a complete hardware kit including plastic wheels and a pair of U.S. Insignia decals that appear to be the good ones from Sig. All in all it looks like it should be a fun little project.
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: February 20, 2016, 10:05:58 AM »
Wow! I've never seen that one before Wayne. There's two different current production models from black hawk. I've built one, the other is on the to do list. One is kit number FS1000 and that's the hollow log. The other is actually a profile. Both look cool. But are much smaller than the one you have. I believe they are 18" WS
Offline LARRY RICE
« Reply #10 on: February 23, 2016, 11:17:29 AM »
At Black Hawk Models we discontinued the profile "PT-19" and replaced it with the NEW "Cox Trainer" (name change so as to not confuse buyers).  The reason that the tail pieces are made of plywood is that they are held in place with rubber bands that would cut into the balsa wood otherwise.  We did everything we could to make this plane as unbreakable as possible.  The slot in the center of the wing is for an alignment piece to make sure that the wing is put back into the correct place after a hard landing.  Dowel rods are added to the edges of the balsa wing to keep the rubber bands from cutting into the wing.  There are several other inovations to make this the perfect trainer.  You will find that with a Babe Bee engine the plane is heavy and will tend to not get away from the beginning flier.  Putting more power to the plane will make it able to loop, is that what you want in a basic trainer?
I hope that you all are aware that Black Hawk Models is currently shutting down operations and several kits are no longer available.
Larry
« Last Edit: February 23, 2016, 11:44:55 AM by LARRY RICE »
Online Fredvon4
  • Central Texas
« Reply #11 on: February 23, 2016, 03:02:51 PM »
Larry...wait a sec...I was understanding that the Canadian operation was imminent and we would see many of the discontinued modes re surface?
WTF....sorry that is hard... whats up brother, I am waiting for a few models I never bought and are now unobtanium
Fred von Gortler IV
Offline LARRY RICE
« Reply #12 on: February 23, 2016, 04:59:57 PM »
The models were due to start comming out last month - I have not seen any yet and have little contact with the Canadian company.  I am waiting to see - but I am not holding my breath.  I hope that he will start releasing model kits soon.  He has another business with large scale R/C kit manufacturing, I think that they are taking up his most of his time.
I hope to be out of all model business by late April, I may do some design work if things work out but I have had some major health problems this year.
Larry
« Reply #13 on: February 23, 2016, 06:27:51 PM »
 Thanks for the information Larry, it's nice to know the history of the series.
 I do understand the intended features designed into the kit, I'm just going to dress this one up a bit though and also build it as a "one-piece" model. It seems I can't ever get myself to simply build something right from the box.
 Sorry to hear of the dissolution of Blackhawk, I should have gotten my Phantom Mk XV while I had the chance.
« Reply #14 on: February 23, 2016, 07:51:03 PM »
... but I have had some major health problems this year.
I hope you get better.
Offline LARRY RICE
« Reply #15 on: February 23, 2016, 10:34:23 PM »
Thanks Tim, but I do not see that happening, I am just planning on going on as long as I can.  I worked every day of my life, usually two jobs at a time, now I am 71 it is time to spend as much time as I have left loving my beautiful wife.
Bless you all for letting me make a difference.
Larry
Offline Dane Martin
  • heli pilot BHOR
« Reply #16 on: February 23, 2016, 11:11:50 PM »
Larry, i want to thank you for everything you've done. Black hawk models have been a very fun part of my life. Wether it was airplane models or tether car kits, it was the most fun kit a person could get. I've collected the cards, and my field box is plastered with black hawk squadron stickers. I just bought my step son 2 tether car kits.
Thank you for all the kind emails. Thank you for all the nice things you've said about the pics I've sent to you. God bless you man!
Sorry for sidetracking the post Wayne
« Reply #17 on: February 24, 2016, 06:34:50 PM »
 You're not at all Dane, and yes, thank you Larry for all of your efforts and contributions to our hobby, wishing you the best! y1
 Started chipping away on the PT last night...
 So far, since I prefer to finish balsa more than I do plywood, I've laminated a 1/32" balsa sheet to what will be the exterior sides of the fuse. I used a very thin layer of 30 minute epoxy and then weighted it down to cure. I am also going to cut about 3/8" off all along the top of the sheet fuselage sides for a lower finished profile, simply for a better look.
 I razor sawed a centerline in the wing and gave it a 1/2" of dihedral at each tip, again only for a better finished appearance. I reinforced the bottom of the wing at that section with some cloth tape and 30 minute epoxy as well. Once the wing is attached to the fuse I'll then add a fillet using Aero-Fil and it'll be all good to go.
 I've decided to use the plywood stab and elevator and I have them sanded and ready for hinging with CA and some fishing line. I do think I'll make a new fin and rudder from 1/8" balsa.
 I'll also be bending up a new landing gear using some slightly heavier wire than what was provided in the kit. Another detail will be substituting a 2-56 threaded rod and clevis for the stock kit pushrod.
 I'll add some photos when I have a little more time... ;D
« Last Edit: February 24, 2016, 10:04:09 PM by wwwarbird »
Online Fredvon4
  • Central Texas
« Reply #18 on: February 25, 2016, 08:48:46 AM »
Larry
Thanks for the update and best wishes from our family to yours
Each and every BH model I did get was fun to read the box, a joy to build, and in the case of the Mongoose and Demon kits allowed me to re-live my youth
Thanks for all you have done and are doing still
I am enjoying the PT-19 build
Fred von Gortler IV
Offline LARRY RICE
« Reply #19 on: February 25, 2016, 09:57:41 PM »
Thanks for the kind words, but it has always been our fine customers who made Black Hawk Models everything that they were.
 H^^ thank to all of our customers and friends, you have made making these kits worthwhile.
Larry
Offline bob jablonski
« Reply #20 on: February 27, 2016, 10:08:11 AM »
Not good news Larry. I have been hoping the out of production would be coming back on line.
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
countylinhobbies@yahoo.com
www.countylinehobbies.com
Offline Larry Renger
« Reply #21 on: February 28, 2016, 07:28:32 AM »
I would like to clear up one point in reply to the comment that the Cox version didn't fly well. My club, the Knights of the Round Circle has trained truly hundreds of kids with the model. They fly well and take a heck of a beating.  Not only can they do loops and wingovers, I actually have done square loops with them (inside only, of course). I don't know who designed it, but he did a heck of a good job! It was in production for at least 25 years that I know of.
It is great that Blackhawk is producing a model with the same "bashability"!  H^^
Offline LARRY RICE
« Reply #22 on: February 28, 2016, 01:31:52 PM »
Larry, you are right, the last time that I flew a "Cox Pt-19" I was amazed by it's performance.  I based the "COX TRAINER" on the "PT-19" because I wanted a plane that could break apart and be ready to fly again in minutes.  Since I was looking for the perfect trainer for clubs running a program like yours, I opted to make this one a bit less responsive and more durable.  I hope that these kits will be available again soon.  Our first run of 35 kits sold out in about 3 weeks.
Larry
Black Hawk Models
« Reply #23 on: February 29, 2016, 12:39:32 PM »
We, Melvin Schuette and I had the privelage of helping Dale Kirn at the NATS.  It was not unusual for some of the youngsters to solo the Cox PT-19.   I wonder now if the young lad still has the kit Dale gave him at the end of the day.   I mean he was one of the first to sign up for a flight.  Every hour Dale would pull a name out of the box, names of those that had tried to fly.  This young man signed up every hour.  He also helped with retrieving the planes.  Needless to say at the end of the day when the last name was drawn he did not get his name drawn.  Talk about a sad face.   Then Dale called him to the table and said take this.  It was the full package with plane, lines, handle, fuel and battery.   That young man left with a grin from ear to ear and the hug he gave Dale was worth the time we spent that day.
Online Fredvon4
  • Central Texas
« Reply #24 on: February 29, 2016, 02:58:17 PM »
Not touting my horn...but the RC club I used to belong to partnered with an Army (Fort hood) senior Chaplin who ran a youth ministry that included modeling and we supported him
The story Doc just related happened to us also... one kid was Johnny on the spot to do anything and every thing but never won the monthly prizes...
At the end of one day I saw him sad sacking on the bleachers and asked him where his folks were... They were there, so I went over to them and asked if it be OK for me to donate a bunch of my stuff to the boy...mom was a bit hesitant but dad was ok so I took dad to my car and loaded him up with a few kits, two engines, fuel, starting stuff, props,  a bunch of glue and finishing materials and all the other bit of kit needed to successfully build and fly a RC or CL model... including a el cheapo Specktrum Dx5e, batteries, servos yadda yadda... mostly stuff excess to me and mostly my entry lever kit n bits
I really enjoy seeing him at local RC group fun flies with such a big grin and still running all over helping every body
He did build, fly and rekit the Brodak baby clown and is saving his allowance for a real CL plane like a Ringmaster so I gave him a good running Fox .35 and a few props about a month ago
If every body would just get ONE kid interested we DOUBLE our foot print
Fred von Gortler IV
« Reply #25 on: February 29, 2016, 08:36:39 PM »
 As the dust settles, here's a few updates on where I'm at...
 I've got the fuse sides trimmed down and sanded. I reshaped the cockpit openings as well. They were just plain round circle cutouts but I squared up the rear portion just a little bit. I then added a piece of 1/64" ply to the underside of the cutouts to close them up from the outside.
 I also reshaped the fin/rudder to a more scale appearing outline, sanded the offset angle into it, and have it ready to glue up.
 Next was some sanding to clean up the wing dihedral joint, and then I "fine-tuned" the wingtip outline a bit too.
« Reply #26 on: February 29, 2016, 08:38:19 PM »
 Fin/rudder, before/during/after...
« Reply #27 on: February 29, 2016, 08:41:02 PM »
 Wing center work and wingtip before/after...
« Last Edit: February 29, 2016, 09:47:54 PM by wwwarbird »
« Reply #28 on: February 29, 2016, 08:43:41 PM »
 Starting fuse assembly...
« Reply #29 on: March 06, 2016, 08:43:45 PM »
 To help with some activity through the winter months our Piston Poppers club holds a "Club Building Session" the first Sunday of January February and March. I brought the PT along today and got a few more things done. In between the usual BS-ing that goes on I glued the tail end of the fuselage together and then attached the fuselage top piece. After that I sanded the fuse sides flush with the top and squared it all up. Next on that will be rounding it across the top over the full length of the fuselage. Then I picked up the wing and got the L/E, T/E, and wingtips all rounded and sanded to shape. All the other parts are pretty close to ready to go now too, I'm almost ready to glue it all together and make an airplane out of it...
« Reply #30 on: March 06, 2016, 08:54:55 PM »
 Just by coincidence todays Club Building Session ended up being kind of a "1/2A day". I was working on the PT, Keith Sandberg put the finishing touches on his Stunt Rocket, getting the engine and tank all mounted and plumbed, and Rachel Sandberg did the same with her new Ringmaster. Keith brought along a Nobler he picked up on Ebay too. My eyes are still blurry from all of Rachel's polka dots... n~
« Reply #31 on: March 06, 2016, 09:15:07 PM »
 NOTE: I'd feel I should also mention in this thread that all of the modifications I'm doing here to Larry's Blackhawk PT-19 kit are completely unnecessary. The PT-19 would be a great build and fly well even if built straight out-of-the-box. My thing is I just can't seem to leave anything alone when building, I enjoy putting my own little "tweaks" in here and there as I go. In this case I mainly wanted to just build it as a "one-piece" airplane instead of the engineered-in rubber band assembly. That, and a few minor hardware and cosmetic changes, and we're moving right along. H^^
Offline Dane Martin
  • heli pilot BHOR
« Reply #32 on: March 07, 2016, 10:09:58 AM »
1/2A day looks like great fun Wayne! I like doing that with the kids.
« Reply #33 on: March 07, 2016, 08:24:26 PM »
 I was wondering, does anyone know if the Nobler pictured above is a kit or? This one came off of Ebay, already built.
Offline LARRY RICE
« Reply #34 on: March 10, 2016, 08:26:57 PM »
At Black Hawk Models our main goal was not to just to give you a simple to build, good flying model but to encourage the model builder to make the model their own.  To make our kit personal in color, shape and style, encourages creativity, and that is what model building is all about, or at least it should be.
Larry
BHM
« Reply #35 on: March 11, 2016, 08:53:37 PM »
 Got a few more things done on the PT over the past couple evenings...
 Last night I sanded a radius into the top of the fuselage and then epoxied the wing into place. Sanding that radius is a lot easier without the wing in the way. Tonight was mounting all of the tail surfaces, it is now officially a "one-piece" airplane.
 I also decided to move the bellcrank mount inboard from where it was. I made a balsa plug for the original laser cut hole, epoxied it in place, and then sanded it flush with the wing surface. I'm not sure why the mount was out so far on the wing, my moving it in will get the pushrod running closer alongside the fuselage. After that the leadout guide was also epoxied into the wing.
 Next will be bending up a new landing gear, laminating it into the firewall, and then mounting that as an assembly.  ;D
Offline Chancey Chorney
« Reply #36 on: March 12, 2016, 12:38:27 AM »
Coming along very nicely.
« Reply #37 on: March 16, 2016, 09:56:03 PM »
 A little more tinkering on the PT tonight.
 First was marking and drilling pilot holes for the engine mount in the kit firewall so that I could make sure and "miss" those with the L/G wire placement. Then I positioned the wire, traced it, and milled a groove into the firewall with the Dremel. After that the L/G was laminated into it with 30 minute epoxy and additional layer of light ply...
« Reply #38 on: March 16, 2016, 09:59:23 PM »
...next I made up a small block to add inside the tail end of the fuselage. I'm planning on sheeting the bottom yet with 1/16" balsa and then using a Carl Goldberg nylon tail skid. The block inside the fuselage will give a nice sturdy point for the pegs of the tailskid to bite into...
« Reply #39 on: March 16, 2016, 10:02:35 PM »
 ..and then I made up a couple little "fairing" pieces for each side of the vertical fin to cosmetically blend the fuselage to the tail. These will also add a bit of strength to the tail assembly.  ;D
Offline James Holford
Re:
« Reply #40 on: March 18, 2016, 05:08:32 PM »
Coming along really nice!!!!!
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
« Reply #41 on: March 18, 2016, 09:31:45 PM »
 Got a few more things done on the PT tonight.
 In preparing to mount the firewall assembly I first plugged the rectangular hole in the fuselage top block. This hole was intended as a locating hole for the rubber band "breakaway" firewall of the original kit design. I simply epoxied in a piece of scrap wood to fill it in, then I can cut it off and sand it flush later on...
« Last Edit: April 08, 2016, 10:17:40 PM by wwwarbird »
« Reply #42 on: March 18, 2016, 09:36:17 PM »
 After that the firewall assembly was glued in using 30 minute epoxy and I also added some balsa triangle stock supports on the inside. Notice that I had also predrilled the pilot holes for the engine mounting, it's much easier to do before the firewall is in the airplane...
« Reply #43 on: March 18, 2016, 09:41:23 PM »
 Another added detail was making a light ply bellcrank mount reinforcement for the bottom side of the wing. Once complete and with the bellcrank mounted this makes for a "sandwiched" assembly in the wing along with the top mount, greatly increasing the overall strength of the mount...
« Last Edit: March 20, 2016, 07:35:00 PM by wwwarbird »
« Reply #44 on: March 18, 2016, 09:44:09 PM »
 Next, I went around to the underside of the tail and added some stab "holder-onner-helper-thingies". These were made using some 1/4" balsa triangle stock. Combined with the upper "fairings" shown a few steps earlier this should make the tail assembly a bit more durable...
« Reply #45 on: March 18, 2016, 09:47:14 PM »
 Then, with 30 minute epoxy curing on all of this, it was time to walk away for the night and toss a pizza in the oven.  ;D
« Reply #46 on: March 19, 2016, 09:19:27 PM »
 On The Wheels. For some reason, even with a little 1/2A bugger, there's always something about getting to this point in any build.  o2oP
« Reply #47 on: March 20, 2016, 05:23:02 PM »
You are now at the part I dread most, finishing.   I love what you have done with this design. H^^
« Reply #48 on: March 20, 2016, 07:33:37 PM »
 Thanks Doc, this will be a pretty easy one to finish up.  y1
Offline Dane Martin
  • heli pilot BHOR
« Reply #49 on: March 20, 2016, 10:59:50 PM »
I don't know Wayne. That's a lot of tiny little curves to monokote.....
